VWVortex.com - Its not low, but itll go build.
    Page 1 of 6 12345 ... LastLast
    Results 1 to 25 of 146
    Thread: Its not low, but itll go build.
    1. Member Rmeitz167's Avatar
      Dec 15th, 2007
      Nashville
      bmp r32 and touareg
      02-15-2012 02:01 AM #1
      First off, this absolutely wouldn't be possible without my family and friends. Especially since i never planned to be able to to actually turbo this car. If Andy didn't offer me a deal i absolutely couldn't refuse on the eip stuff i never would have gotten started. People like Jeff at UM and Tom at APTuning both played instrumental roles in this with both advice and products. I did alot of reading for the better part of a year on these forums to plan this custom kit, and ide like to thank anyone who was gracious enough to post build threads and answer my questions.
      Well, the basis for my kit includes:
      Turbonetics 62-1 1.06 t4 hotside with a 70trim cold side
      EIP ram horn manifold
      EIP 3" downpipe converted to an open dump
      Tial MVS 38mm
      A 24.25"x9x2.5 bar and plate intercooler core
      2.5" aluminum intercooler piping
      3" exhaust back to the center of the car split to 2.5" oval to both the passenger and drivers sideskirts
      The intake piping is 4"
      Bosch 550cc injectors
      UNITEDmotorsport tune with launch control
      Fx400 clutch with an oem flywheel (streetwerke setup)
      ..The goal is 450-500whp on 15-17psi.
      This will unfortunately be a drawn out thing, as my deadline really isnt due until May/June
      I started with this mess of parts,
      Then, it progressed to pulling my car into my garage and to begin the teardown (don't mind the incredible amount of stuff Ive accrued in my short life)
      I quickly got to work making that turbo look better, or at least match my wheels Courtesy of Dave at Renewed Finishes
      Once the car was apart i wanted to go head on at the problems others were having with this type of manifold/s trim 4" inlet housing turbos. Mitch got crafty and notched his piping, Andy got mad and beat the hell out of his brake booster. After logically racking my brain for most of the thinking process involved in this car, it came down to 3 options. 1. i could copy Mitch...which seemed the most likely. 2. Run a non reinforced coupler and see it that would allow it to fit. 3. Cut **** until it fit like Andy did. I ended up deciding to try the coupler first...It worked
      After that issue was addressed, we started cutting and mocking up the intercooler.
      Long story short, the brainstorm came about to go against the norm and put the intercooler piping through the core support, this turn into turning the core support into intercooler piping and the monstrosity your about to see was made.
      As a finished product, this is what the front mount looks like
      After we finished that it was time to connect the dots
      Next we got started on the hotside piping, which to be honest with you if it wasnt for Mitch(JDM-JTI) having to figure this out before me, it never would have went as smoothly as it did. We ended up welding a v band onto the turbo to make this work.
      ^-4an to my wastegate.
      After that it was time to address the fact i wanted to do an open wastegate dump on my Tial 38mm MVS. I had to have the downpipe recirc piece welded shut and the dump tube made. Because of the mess of piping behind the motor, this was how we had to route the dump tube.
      ...That is where im at right now. The piping is all done. It will be sent off to have the cold side piping, intake manifold, diverter valve, and core support powdercoated. The hotside piping, downpipe, and exhaust manifolds will be ceramic coated.
      Anddd... the car in question
      WunderWagens June 10,2012 in Gilbert, PA... 2nd year http://www.wunderwagens-show.com
      UnitedMotorsport r32 cam flash... get one
      My Turbo .:R Build Thread
      WunderWagens Vortex Forum
      WunderWagens Facebook
    2. Member Rmeitz167's Avatar
      Dec 15th, 2007
      Nashville
      bmp r32 and touareg
      02-15-2012 02:03 AM #2
      In for updates, and to tell you that its gonna probably be May until its fully done .I still need to order a tune, install the clutch/spacer/crackpipe/ possibly do chains(96k) Exhaust will be done after that.
    3. Member Jonnymooshoo's Avatar
      Apr 16th, 2011
      Richmond, BC Canada
      1995 MK3 GTI, 2004.5 MK4 GLI, 2009 CIVIC DX-G, MK4 R32T (Let's forget the Civic)
      02-15-2012 02:09 AM #3
      Nice! Aside for the painted wheels our cars are twins... thinking of painting my superleggeras white actually.
    4. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      02-15-2012 02:11 AM #4
      Looks good.
      -Josh
      1-12-5-8-3-10-6-7-2-11-4-9
    5. Member BOUDAH's Avatar
      Aug 15th, 2008
      New Haven, Connecticut
      2007 F250 PSD, 2004 BMP .:R32 / 2013 Island Grey Metallic CC Sport 6 spd ; 2002 Passat 30V V6 5 Spd
      02-15-2012 02:13 AM #5
      Rice Ross, i think the coolest thing is the intercooler mounting setup. Ur deff spending a lot less on this than i am, haha
      U.S. Army
      OIF / OEF Veteran
    6. Member Rmeitz167's Avatar
      Dec 15th, 2007
      Nashville
      bmp r32 and touareg
      02-15-2012 02:17 AM #6
      Quote Originally Posted by BOUDAH View Post
      Thats half the fun. This isnt a shop building this car, its me and freinds so its alot cheaper. The welds on the piping were done by a friend who pretty much honed his skills building his lsx turbo nova and hasnt stopped since
    7. Member Rmeitz167's Avatar
      Dec 15th, 2007
      Nashville
      bmp r32 and touareg
      02-15-2012 11:48 PM #7
    8. Member newcreation's Avatar
      Nov 23rd, 2003
      HBG, PA
      04 R32T
      02-16-2012 12:05 AM #8
      Looks good. Always best to do it yourself that way a problem arises you can fix it quick. Plus doing it yourself and if your are knowledgeable it will be reliable because you will take more car than a shop you are paying
      -JAMES CRIST JR-
      DRIVEN/Built /UM Turbo R
    9. Member Rmeitz167's Avatar
      Dec 15th, 2007
      Nashville
      bmp r32 and touareg
      02-16-2012 01:10 AM #9
      Quote Originally Posted by newcreation View Post
      precisely
    10. Member benyates's Avatar
      Jun 10th, 2009
      FL and Snowta
      MkIV BMP R32
      02-16-2012 01:16 AM #10
      what's the grenade looking thing, ross? (in one of the pictures looks like it's 90 deg coming off intake pipe) on the next it is gone.
      BMP .:R32
    11. Member Rmeitz167's Avatar
      Dec 15th, 2007
      Nashville
      bmp r32 and touareg
      02-16-2012 01:18 AM #11
      Quote Originally Posted by benyates View Post
      eurojet diverter valve
    12. Former Advertiser gabe@bwperformance's Avatar
      Mar 4th, 2011
      02-16-2012 01:59 AM #12
      Nice to see my old kit is being moved around some more and still being improved upon.
    13. Member BIG DUB's Avatar
      Feb 13th, 2001
      MD/VA/DC Area
      1980 turboed moped
      02-16-2012 07:10 AM #13
    14. Member Rmeitz167's Avatar
      Dec 15th, 2007
      Nashville
      bmp r32 and touareg
      02-16-2012 10:49 AM #14
      Quote Originally Posted by gabe@bwperformance View Post
    15. Member Rmeitz167's Avatar
      Dec 15th, 2007
      Nashville
      bmp r32 and touareg
      02-17-2012 09:10 PM #15
      The intercooler and dump tube are all done. Picked up a used cm fx400 and pressure plate the other night, going to be sending that off to get rebuilt. Next step is to tear it all apart and send it to powder/ceramic coating and begin to pull the motor/trans for the clutch,headspacer, etc.
    16. Member OCaf04's Avatar
      Feb 17th, 2008
      Monroe, Ny
      JB 20th 3769(sold), Jazz Blue BT 20th(Sold), DBP R33...T, 2005 Aspen STi(gone), 97 jeep!
      02-17-2012 09:17 PM #16
      your kits a little hoe
    17. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      02-17-2012 10:26 PM #18
    18. Member deeeGLI's Avatar
      Feb 28th, 2006
      Brodheadsville PA
      90'GLI,02GLX,07 B6 Wagon
      02-17-2012 10:49 PM #19
      Nice!
    19. Member Rmeitz167's Avatar
      Dec 15th, 2007
      Nashville
      bmp r32 and touareg
      02-17-2012 11:01 PM #20
      Quote Originally Posted by deeeGLI View Post
      Nice!
      ^your turn to make it all pretty. www.renewedfinishes.com... i cant wait to post the pics when its all done and coated haha.
    20. Member Rmeitz167's Avatar
      Dec 15th, 2007
      Nashville
      bmp r32 and touareg
      02-18-2012 11:54 PM #21
      I decided to tear down the car to get everything ready for the powdercoater.
      ^where the hotside piping connects to the core support-intercooler
      Everything torn out and ready for the powdercoater
    21. Member resilientsoma's Avatar
      May 31st, 2011
      NEPA
      2016 Toyota 4Runner Past: Tensioner Failed 11' GTI
      02-20-2012 03:40 AM #22
      Looks great man! I bet she is a beast. Just wondering why the intake is behind the battery?
      PART OUT - BUY MY STUFF!
      VIPModular| GIAC | AWE | APR | ST Suspensions | BSH | Magnaflow | WRD | SouthBend | Tyrol | OEM | Etc. |
    22. Member Rmeitz167's Avatar
      Dec 15th, 2007
      Nashville
      bmp r32 and touareg
      02-20-2012 01:21 PM #23
      Quote Originally Posted by resilientsoma View Post
      Theres really not a better place on my setup to run it. Cold air intakes on turbo cars are stupid. The difference they make vs the harm they can cause isnt worth it. Where its at i can run the factory plastic peice that would pull cold air out of the fender well an into the intake box if i want, the filters placed at the perfect spot for it.
    23. Member r32dub88's Avatar
      Dec 9th, 2007
      NH
      BMP Golf, F-150
      02-20-2012 01:39 PM #24
      Looking good ross! Been tracking the progress on FB.
      Random question, have you given any thought into running water/meth? I ask because your intercooler looks a bit smaller compared to other turbo'd R's that I have seen (I am sure you won't have heating issues but I always say rather safe than sorry).
    24. 02-20-2012 01:43 PM #25
      I like this.. a lot.
