Results 1 to 4 of 4
Thread: Audi 5cyl 20V turbo swap - AAN - 01E
  1. Member NOTORIOUS VR's Avatar
    Sep 24th, 2002
    Toronto
    E36
    02-15-2012 09:42 AM #1
    The swap is from an Audi UrS6, it's a complete AAN 20V 5 Cyl motor, 5 speed 01E tranny, wiring harness, ECU, MAF, IC, etc, etc.
    The motor has roughly 171k km on it, compression #'s are as follows 156-164-168-164-160.
    The timing belt/wp has under 30k km, the clutch kit has under 25k on it.
    The missing part of the AAN swap was the turbo and the manifold which I have acquired separately. Stock exhaust mani and your choice of either a K26 or K27 turbo as I have both. I also happen to have an exhaust manifold w/ I believe a T3 flange if any of you are willing to make more power with a larger turbo.
    If you're worried about engine management I can help you with that as I am the distributor of VEMS in Ontario so just let me know.
    This is a complete 5 cyl turbo swap... legendary 20V turbo power.
    Contact me only if you're serious. $2500 is a steal for everything included.
    Location Toronto, Canada
    Contact via PM or email: notorious.vr [(at)] gmail(dot)com
    E36 · VEMS · TUNING
    Google Talk: NOTORIOUS VR
  2. Member Wolfcars Tuning's Avatar
    Dec 30th, 2004
    South Florida
    2001 Audi S4, 1996 Audi S6
    02-23-2012 12:36 AM #2
    Hi I'm interested, just a couple of questions, motor and trans are out of a good running car? Was it crashed? How is the engine harness and ECU? Does it include the stock exhaust manifold wastegate and turbo? If yes can you do 2400 shipped to florida. I have cash on hand. Let me know. (786)436-9836 Adam, thanks.
  3. Member NOTORIOUS VR's Avatar
    Sep 24th, 2002
    Toronto
    E36
    02-23-2012 09:24 AM #3
    Yes it's out of a running car, everything is in great working condition... txt sent.
    Thanks
    E36 · VEMS · TUNING
  4. Member Wolfcars Tuning's Avatar
    Dec 30th, 2004
    South Florida
    03-21-2012 05:50 PM #4
    Any estimate for bringing all those goods into South Florida?
