Results 1 to 4 of 4
Thread: mk2 aba swap question
  1. Member dillweed983's Avatar
    May 25th, 2009
    91 aba jetta, 89 gmc shortbed, 82 GPz550
    02-15-2012 08:54 PM #1
    I found a 91 jetta gl on craigslist with a 99 aba swap. It is the entire engine,trans, dash and cluster swap. As the owner explained it to me, the driver side axle is binding because the mk3 control arms and driver side axle are too long. I'm being told that to get this thing back on the road I need to get a mk2 driver side axle and mk2 lower control arms. I've been searching and can't find anything on this subject. I found one thread that seemed to hint that the entire mk3 subframe can be swapped without issue but it made no mention of control arms or axles. I've tried the mk2 forum but hopefully I can get some faster answers here.
    I'd love to kick your poodle. I'd love to slig your cat. I'll bust your yanni cds with a baseball bat. I'd send your fat-mouth mama sailing like the flying nun. I'd like to shoot you in the a$$ with a bb gun.
    Dec 1st, 2009
    1991 gti 1981 rabbit
    02-24-2012 10:46 PM #2
    To fix the axle binding problem all you have to do is get 16v mk2 axels they are 3/4" shorter then the mk3 axles. As for the control arms I don't think there is any difference from mk3 to mk2 just the subframe is different.
  3. Member flood514's Avatar
    Jun 3rd, 2011
    Montreal,QC
    2000 a4 1.8TQM, 1998 passat 1.8TM
    02-25-2012 07:43 PM #3
    The control arms are different, I almost F'd that up years back.
    http://forums.vwvortex.com/showthrea...rol-arm-length
    Dec 1st, 2009
    02-26-2012 10:03 AM #4
    Quote Originally Posted by flood514 View Post
    Ok thanks for informing me of this
