Page 2 of 2 FirstFirst 1 2
Results 36 to 53 of 53
Thread: Vag Com code 2294
  1. Junior Member
    Mar 7th, 2010
    Doylestown, PA
    2010 GTI
    03-28-2012 07:04 PM #36
    they replaced the throttle body wiring harness but issue came back yesterday. Back at dealer.
    GIAC Stage2 - AWE TOP w/ S3 Intercooler and AWE hose kit - AWE CCB - AWE Turbo Back Exhaust - Unibrace XB - 28mm Front H&R Sway Bar (Soft) - 24mm Rear H&R Sway Bar (Stiff) - Driver's Gear Springs
  2. Junior Member
    Mar 7th, 2010
    Doylestown, PA
    2010 GTI
    03-28-2012 07:04 PM #37
    Quote Originally Posted by zucchini View Post
    2 Faults Found
    008504 - Accelerator Position Sensors (G79) / (G185): Implausible Correlation
    P2138 - 000 - - - Intermittent
    Freeze Frame
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 25471 km
    Time Indication: 0
    Date: 2012.03.24
    Time: 17:55:17
    Freeze Frame
    RPM: 1408 /min
    Load: 12.9 %
    Speed: 40.0 km/h
    Temperature: 100.0°C
    Temperature: 48.0°C
    Absolute Pres.: 910.0 mbar
    Voltage: 13.589 V
    008487 - Accelerator Position Sensor 2 (G185): Signal too Low
    P2127 - 000 - - - Intermittent
    Freeze Frame
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 25473 km
    Time Indication: 0
    Date: 2012.03.24
    Time: 18:01:29
    Freeze Frame
    RPM: 1468 /min
    Load: 9.8 %
    Speed: 41.0 km/h
    Temperature: 53.0°C
    Absolute Pres.: 920.0 mbar
    Voltage: 13.589 V
    Readiness: 0010 0001
    These are my new faults....
    Any tips?
    These look like throttle position sensor failure.
    Aug 30th, 2009
    Santo André SP Brasil
    Passat Wagon 2.0 TSI 09; APR K04 ;carbonio; DP APR;cat 200 cels inox;paddle shifts; VCDS;
    03-28-2012 07:59 PM #38
    Quote Originally Posted by Bender. View Post
    Again! What are they going to check now? Grounding? I believe I have some grounding issue.....
  4. Junior Member
    Mar 7th, 2010
    Doylestown, PA
    2010 GTI
    03-29-2012 09:34 AM #39
    Went over all the grounding already. Has to be sensor itself in my mind.
    Sent from my DROID RAZR using Tapatalk
    Aug 30th, 2009
    03-29-2012 02:22 PM #40
    "crossed fingers"........
  6. Junior Member
    Mar 7th, 2010
    Doylestown, PA
    2010 GTI
    03-29-2012 03:42 PM #41
    Mine too. They have a call into the tech line waiting for guidance from above...
  7. Junior Member
    Mar 7th, 2010
    Doylestown, PA
    2010 GTI
    03-30-2012 07:19 AM #42
    Sigh... i am getting close to just taking it back and switching fuel pump out myself or training it in...
    Aug 30th, 2009
    03-30-2012 11:26 AM #43
    Which codes are you getting now? New or the old ones?
  9. Junior Member
    Mar 7th, 2010
    Doylestown, PA
    2010 GTI
    03-30-2012 01:06 PM #44
    Same...
  10. Member
    Aug 30th, 2009
    03-31-2012 11:31 AM #45
    Same...
    Any news?
  11. Junior Member
    Mar 7th, 2010
    Doylestown, PA
    2010 GTI
    03-31-2012 05:26 PM #46
    None.
  12. Junior Member
    Mar 7th, 2010
    Doylestown, PA
    2010 GTI
    04-02-2012 06:59 AM #47
    Had some messages on my work phone. Fuel pump went in Friday. Light returned Saturday.
  13. Member
    Aug 30th, 2009
    04-02-2012 12:42 PM #48
    Holy S.... man! Why is it so hard to find the real issue?
  14. Junior Member
    Mar 7th, 2010
    Doylestown, PA
    2010 GTI
    04-02-2012 12:53 PM #49
    I dunno man... i dunno.
  15. Junior Member
    Mar 7th, 2010
    Doylestown, PA
    2010 GTI
    04-06-2012 10:27 AM #50
    New ECU being ordered...
    I gotta give props to the dealer... they are trying...
  16. Member
    Aug 30th, 2009
    04-06-2012 11:21 AM #51
    This must be the "final" option!
    Good luck again!
  17. Junior Member
    Mar 7th, 2010
    Doylestown, PA
    2010 GTI
    04-13-2012 09:11 PM #52
    So far so good... havent gotten it back yet but dealer is optimistic
    Sent from my Touchpad using Tapatalk 2
  18. Member
    Aug 30th, 2009
    04-14-2012 08:35 AM #53
    Great news! Happy for you man.....
