Ive been researching the same thing recently. As I'm wanting to run carbs and have a clean looking setup. Most wiring diagrams can be found directly on the MSD website. I believe the 16v dizzy is locked out and controlled by the ecm. My biggest question is the trigger. I dont know if it will work of a crank trigger or the cam sensor. A 6AL would be fine just to get you running, the 6al-2 has a 2 step built in for flat foot shifting or launch control. You can buy a separate box to run 2 step on the 6-al. I'm leaning towards the programable 6-al2 which you can set timing curves a retards for n2o or boost. Its 400$ but the others are in the 200$ range
