Page 2 of 2 FirstFirst 1 2
Results 36 to 45 of 45
Thread: Dyno - New Beetle Turbo S
  1. Member .:Ryan99:.'s Avatar
    Aug 16th, 2001
    Charleston, SC
    2004.5 GLI
    02-24-2012 11:46 AM #36
    If you have the v-tune option with your apr flash you can up the boost with a laptop and a vag com cable. Not sure if your ecu supports this or not but it definitely makes a difference.
    Formerly hookedup4door
    04.5' PG GLI
    03' Jetta wagon TDI Greasecar conversion (Hers)
    96' Supercharged Golf (sold)
    Jan 8th, 2010
    Texas
    01 TT Roadster F4H-T 02 GTI GT28RS
    02-24-2012 11:56 AM #37
  3. Member Justacar's Avatar
    Feb 8th, 2012
    02-24-2012 09:20 PM #38
    Quote Originally Posted by Big_Tom View Post
    i would switch to unitronic stage 2 first. that should net you 20 to 30whp alone. if you want more look into a frankenturbo setup
    IM running a unitronic stage 2, and my mods are , 2.5 TT turbo back, Hatachi bolt on coils, .028 gap, 007 forge dv, evotution intake to turbo hose, and evolution CIA, and soon to switch to a thicker Side mount. And I run totally fine. stock injectors, 3 bar, and brand new Ko3s, works fine. Boosts to 20, holds @ 18 with no diving. deffently get the unitronic. Being in a stock 03 GTI is like doing time in a 2.0
  4. 05-09-2012 03:14 AM #39
    I ran apr on my new beetle and a 4 bar fpr is not required .I even asked them and they said no ,that the 3 bar works fine with the software. I now have giac software and also running stock 3 bar. Both apr and giac told me if you go to a ko4 or bt ,then you need to run 4 bar
  5. Junior Member OneFiftyThree's Avatar
    Aug 26th, 2009
    Millville, NJ
    2002NBS 2007GTI
    05-09-2012 12:09 PM #40
    Quote Originally Posted by raponte123jr. View Post
    Yeah the atmospheric temperature was 101 degrees.
    ^^^That might keep your numbers low^^^
    Have you seen this:
    http://www.tyrolsport.com/index.php?...=52&parent=220
    2002 New Beetle Sport - APR - Stop Tech - Hotchkis - Bilstein - TyrolSport - Quaife - South Bend - 42DD - BFI
    2007 Farenheight #799 - APR Stage 2
  6. Member gtimitch's Avatar
    Nov 19th, 2006
    Augusta GA
    02 Golf GTI 1.8T
    05-09-2012 06:50 PM #41
    I like this little Beetle:
    [IMG][/IMG]
  7. Junior Member
    Feb 16th, 2012
    2002/VW/New Beetle Turbo S
    06-05-2012 01:44 PM #42
    I actually did another dyno two months ago and made 216 whp. I think the numbers are better now. I replaced some vaccum, lines changed the spark plug gap to .028 and installed polyurethane dogbone inserts.
  8. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    06-05-2012 03:33 PM #43
    much better i'll prob go dyno again on friday
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  9. 06-05-2012 05:43 PM #44
    Mine on APR stage2 with around same mods and made 190whp too with 240ftlb tq no octane files loaded.
  10. 06-05-2012 05:50 PM #45
    Quote Originally Posted by Justacar View Post
    Upto what rpm does yours hold 18?? Mine APR hits 20 but then drops off here mine graph also have forge cranked actuator too.
