VWVortex.com - Questions on AWDing the Jetta Coupe...
    Results 1 to 6 of 6
    Thread: Questions on AWDing the Jetta Coupe...
    1. Member SavageMotorsport's Avatar
      Jun 24th, 2006
      Go Reds!!!
      02-17-2012 12:13 PM #1
      Hey guys, I am thinking about doing a AWD set up on the coupe. The engine that is going in the car is MKIII 3.0L VR6T that is fully built!
      Here is the car...
      http://s11.photobucket.com/albums/a1...5782611052.mp4
      I am looking to buy a whole R32 shell that also includes:
      -linkage & shifter
      -4 ABS Sensors
      -ABS Control Module
      -ESP Control Module
      -The two Combination Sensors (Accelerometers)
      -Steering Angle Sensor
      -Undamaged rear floor pan (salvaged title on shell)
      -Drive shaft
      -Rear end w/ suspension, diff, controller, brake lines, etc.
      -Exhaust w/ cats
      -Gas Tank w/ evap
      -Fuel pump and sending unit
      -Heat shields
      -O2M transmission
      I have no problem doing all of the sheet metal work on the rear. What I am concerned about is what electrical work am I going to need to make the haldex work???
      Any idea's would help!!!!
      Allan
      1999 Jetta "Coupe" (Project X) (soon to be AWD with a 3.2 BT)
      2011 Jetta SEL (coilovers, wheels, etc.
      2005 Golf 4 door TDI (coilovers, BBS RC's, etc..)
      2002 Beetle 1.8T (turbonium edition)
      1999.5 Cabrio VR6T (project)
    2. Member fouckhest's Avatar
      May 22nd, 2003
      Up on the Mtn
      Danger Ranger
      02-17-2012 12:28 PM #2
      you can get a stand alone haldex controller, that is what i am going to be running on my gti....
      http://www.f-town.info/index.html
      here is your shell in NC R32 shell
      p.s. - glad to see your thinking about this....tried to get Nate to do the swap for years....
      p.s.s. - this guy is doing the same http://forums.vwvortex.com/showthrea...wd-jetta-coupe
    3. Member SavageMotorsport's Avatar
      Jun 24th, 2006
      Go Reds!!!
      02-17-2012 12:48 PM #3
      THanks for the info. I just need to find a way to go get the car/ AWD kit.
      Right now, this is the biggest problem I am having...
    4. Member fouckhest's Avatar
      May 22nd, 2003
      Up on the Mtn
      Danger Ranger
      02-17-2012 01:22 PM #4
      Quote Originally Posted by SavageMotorsport View Post
      did you click on the link i put in my last post? that is one of the better deals i have seen in a while, that way you get the tank and all the running gear...its in NC...you could have it shipped to you....or get a tow dolly
      http://forums.vwvortex.com/showthrea...1#post75361478
    5. Member SavageMotorsport's Avatar
      Jun 24th, 2006
      Go Reds!!!
      02-17-2012 02:16 PM #5
      Quote Originally Posted by fouckhest View Post
      That is the car I am trying to get....I have already talked to him and everything is cool. I just need to find a way to go get it!!!
    6. Member fouckhest's Avatar
      May 22nd, 2003
      Up on the Mtn
      Danger Ranger
      02-17-2012 02:45 PM #6
      right on!
      that is the perfect situation for a swap! sounds like a long weekend road trip!
      if didnt have a project car already i would buy that shell and build a monster 1.8t and make it a nasty track car!
