Results 1 to 5 of 5
Thread: RNS-510 coding help
  1. Junior Member
    Dec 28th, 2011
    Northern Alberta
    '12 Golf Wagon TDI / '08 Toyota Tundra
    02-18-2012 01:20 PM #1
    Hi all,
    Purchased a RNS-510 and I'm looking for some help getting it coded. I've read through all the DIY's and still cannot get it recognized to be coded. Car is a 2012 Canadian spec'd Golf Wagon that came with the RCD-510 originally. So far I've swapped the CECM for a highline version and added bi-xenon GTI lights.
    So far I've lowered the rear headliner and disconnected the compass, installed a wiring harness to allow the use of voice commands with the RNS-510 like in this post: http://forums.vwvortex.com/showthrea...mmands-to-work and hooked everything back up. The unit works fine but I cannot change any coding on it.
    When I open the nav or radio module there is a window popping up saying that it cannot communicate with ECU. Any help is greatly appreciated
    Scan:
    Monday,18,February,2013,10:43:51:65343
    VCDS Version: Release 11.11.2
    Data version: 20120126
    Chassis Type: 7N0
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 37 42 44 46 4F 52 56 62 72
    77
    VIN: 3VWML7AJ4CM60XXXX
    01-Engine -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    1C-Position Sensing -- Status: Cannot be reached 1100
    2E-Media Player 3 -- Status: Malfunction 0010
    37-Navigation -- Status: Not registered 0011
    42-Door Elect, Driver -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
    Part No SW: 03L 906 019 EE HW: 03L 907 309 AA
    Component: R4 2,0L EDC G000SG 1181
    Revision: 12H14--- Serial number:
    Coding: 0050072
    Shop #: WSC 00066 000 00000
    VCID: 72C50F126DB4003
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 114B600C49220000881306E692210042310000
    VCID: 7BDB2236FAFE41B
    Address 08: Auto HVAC
    Cannot be reached
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 087 M HW: 1K0 937 087 M
    Component: BCM PQ35 H+ 104 0614
    Revision: 00104 AF
    Coding: 2D380E3F802F3EC400880001700089CC41042086535D0560E4 8020240040
    Shop #: WSC 12345 123 12345
    VCID: 3B5BE236BA7E81B
    Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer 14071 26 0512
    Coding: 009795
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
    Component: AirbagVW10G 013 0724
    Serial number: 003GVRA05D9S
    Coding: 00003134
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: 3FA39626A6669DB
    Crash sensor for side airbag; driver side:
    Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME634A225EZZZ$
    Crash sensor for side airbag; passenger side:
    Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME0339365EZZZ.
    Crash sensor for side airbag; rear driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3511HSME665E1927ZZZV
    Crash sensor for side airbag; rear passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3521HSME3B0F3C27ZZZZ
    Crash sensor for front airbag; driver side:
    Component: F.Sens.Fahr --- ----
    Serial number: 35527SME216F2327ZZZE
    Crash sensor for front airbag; passenger side:
    Component: F.Sens.Beif --- ----
    Serial number: 35627SME18702327ZZZ7
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90422KEA001H5
    Coding: 108A140000
    Shop #: WSC 00066 000 00185
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_VW36.rod
    VCID: 72C50F12A5B4003
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H09 0013
    Serial number: 0363145
    Coding: 820000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 872 A HW: 5K0 920 872 A
    Component: KOMBI H32 0310
    Revision: X0032006 Serial number:
    Coding: 370F00
    Shop #: WSC 00066 123 00119
    ASAM Dataset: EV_KombiUDSMM9RM10 A04305
    ROD: EV_KombiUDSMM9RM10_VW36.rod
    VCID: 2D7FDC6E7C0A1FB
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 K HW: 1K0 907 951
    Component: J533 Gateway H40 1620
    Revision: H40 Serial number: 10071101291405
    Coding: 352002
    VCID: 3851FD3A8B48AA3
    2 Faults Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 7
    Mileage: 7883 km
    Time Indication: 0
    Date: 2006.14.18
    Time: 13:40:11
    00484 - Vehicle Position Recognition Control Module (J603)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 159
    Mileage: 7883 km
    Time Indication: 0
    Date: 2006.14.18
    Time: 13:40:15
    Address 1C: Position Sensing
    Cannot be reached
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 920 872 A
    Component: IMMO H32 0310
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
    ROD: EV_ImmoUDSMM9RM10_VW36.rod
    VCID: EAF597720D64483
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Component: SG EXT.PLAYER H13 0240
    Revision: A1001003 Serial number: 7660181644
    Coding: 010000
    VCID: 2977287E40E203B
    1 Fault Found:
    00457 - Control Module for Network (J519)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 7413 km
    Time Indication: 0
    Date: 2006.14.18
    Time: 10:27:01
    Address 37: Navigation (J0506) Labels: None
    Part No SW: 3C8 035 684 F HW: 3C0 035 684 F
    Component: RNS-MID H61 3690
    Revision: AB001001 Serial number: VWZ6Z7L5310034
    Coding: 00000400000000000000
    ASAM Dataset: ------------------------- ------
    VCID: 2E7DDB62790C643
    2 Faults Found:
    01042 - Control Module; Not Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 199
    Mileage: 7880 km
    Time Indication: 0
    02635 - Tuner Not Enabled/Activated
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 199
    Mileage: 7880 km
    Time Indication: 0
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 701 HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0501
    Revision: 13110009 Serial number: 0002560450
    Coding: 0004B5
    Shop #: WSC 01383 790 50316
    ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
    ROD: EV_TSGFPQ35BRFVW46X.rod
    VCID: DB9BC2B6D23E21B
    Slave Driver:
    Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 3C0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 006 1401
    Serial number: 00000005678371
    Coding: 000490
    3 Faults Found:
    68098 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 7413 km
    Date: 2006.14.18
    Time: 10:26:58
    68100 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 7413 km
    Date: 2006.14.18
    Time: 10:26:58
    68107 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 7413 km
    Date: 2006.14.18
    Time: 10:26:57
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 70 3201
    Revision: 00H20000
    Shop #: WSC 02069 000 90108
    VCID: 3449C90A57204E3
    Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 1K0 907 951
    Component: EZE_2 H40 1620
    Coding: 050B0500
    VCID: EFC386663E86ADB
    Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
    Component: J245EE20SKB13 H02 0220
    Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
    Component: J394EE20SKB13 H02 0220
    Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 702 HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0501
    Revision: 15110009 Serial number: 0002488929
    Coding: 0004B4
    ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
    ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
    VCID: DC99C1AAD730263
    Slave Passenger:
    Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 3C0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 006 1401
    Serial number: 00000005699158
    Coding: 000490
    3 Faults Found:
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 7413 km
    Date: 2006.14.18
    Time: 10:26:58
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 7413 km
    Date: 2006.14.18
    Time: 10:26:58
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 7413 km
    Date: 2006.14.18
    Time: 10:26:57
    Address 56: Radio (J0506) Labels: None
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 199
    Mileage: 7880 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 199
    Mileage: 7880 km
    Time Indication: 0
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
    Component: TELEFON H09 2730
    Revision: 1B001001 Serial number: 00007660123129
    Coding: 0A00000000010100
    ASAM Dataset: EV_UHVNA A01015
    ROD: EV_UHVNA_VW36.rod
    VCID: 354FF40E945A57B
    End ---------------------------------------------------------------------
  2. Classified Advertiser Peteski's Avatar
    Sep 29th, 2000
    Chicago
    2012 R CW 4Dr
    02-18-2012 05:23 PM #2
    This has been resolved by Ross Tech
    http://forums.vwvortex.com/showthrea...3#post75828933
    Cheers,
    -Peter
    // OEM Recaros // RNS-510 // RVC // RLS // OPS // OEM Auto-Dimming Auto-Folding Exterior Mirrors // OEM Homelink // OEM LED Tails // OEM Golf R Black Headlights // OEM Door puddle lights // OKADA Plasma Coils // APR Stage 3 // 034M Catch Can
    RNS-510 Guru // VWNavi.com // Instagram: PeterDNA
  3. Junior Member
    Dec 28th, 2011
    Northern Alberta
    02-18-2012 09:27 PM #3
    Quote Originally Posted by Peteski View Post
    Cheers,
    -Peter
    Can someone walk me through how to save the redirect files in C:\Ross-Tech\VCDS\Labels\User\ like listed in the thread above? When I open the links it's just text in a new window, no files...think I'm missing something simple here...
    Thanks
  4. Classified Advertiser Peteski's Avatar
    Sep 29th, 2000
    Chicago
    2012 R CW 4Dr
    02-18-2012 10:02 PM #4
    Quote Originally Posted by 96CI View Post
    Thanks
    Just save as both files and copy and overwrite them in VCDS/Labels directory of your Ross Tech install folder.
    Cheers,
    -Peter
  5. Junior Member
    Dec 28th, 2011
    Northern Alberta
    02-18-2012 10:48 PM #5
    Cheers,
    -Peter
    Got it!
    'Puter skillz lacking
