Results 1 to 4 of 4
Thread: f me in the a
    Apr 16th, 2011
    Lancaster , PA
    Mk5 Rabbit
    02-18-2012 08:26 PM #1
    changing out all the rotors and pads today on my mk5 going good till i go to compress my rear calibers both are stuck ,,, any suggestions?
  2. Member VR6 GLX Man's Avatar
    May 19th, 2008
    El Centro, CA
    1992/VW/JETTA/GLI 2.0 2006/ACURA/TL
    02-18-2012 09:07 PM #2
    I think you have to rotate the rears while compressing I changed my front brakes today, but fronts you just compress rears you have to rotate either clockwise or the counter clockwise while you compress, think its clockwise, but maybe someone can give more advice. I have an mkIV, and I know they need to be rotated for sure on those. Not sure about mkV thuough.
    VRSociety #293
  3. Member VR6 GLX Man's Avatar
    May 19th, 2008
    El Centro, CA
    02-18-2012 09:11 PM #3
    I reread that again, alright so the calipers are still on well I'm not sure haven't done rears before. Sure someone will give some advice. This is one video I saw about the rear brakes. http://www.youtube.com/watch?v=y5cWaqmCiT4
    VRSociety #293
  4. Member GTijoejoe's Avatar
    Oct 5th, 2001
    OH
    '98 GTi, '06 Evo Mr
    02-20-2012 04:49 PM #4
    Just about any caliper which also acts as a parking brake will have a power screw inside which will require you to screw the piston in as you press. They make a special tool for this.
    2.0T+034efi+meth = 300+whp = Part out PM me for anything
