Results 1 to 5 of 5
Thread: Abnormal Control Arm Bushing wear?
  1. Junior Member
    May 27th, 2009
    West Chester, PA, USA
    02-19-2012 10:17 AM #1
    I've had my 2006 Golf MKIV since July 2009, put 30K on it in that time, and this is the 2nd time my front lower control arm bushings have been shredded to hell and require replacement.
    I have a really good warranty that replaces them at no cost to me - except that I have to take it to the shop and not have my car for a day or two - which is a real PITA.
    What is the "normal" life expectancy for control arm bushings? Is it dependent on driving behavior/environment/bad roads etc? or?
    And any suggestions for more durable replacements?
    Any thoughts appreciated, guys
  2. Member greyhare's Avatar
    Dec 23rd, 2003
    Corvallis, OR
    '96 Jetta, '78 Rabbit, '79 GMC 3/4T 4x4, 2013 BMW F700GS
    02-19-2012 11:46 AM #2
    Are they using OEM bushings or cheap aftermarket junk?
    Is the car stock or lowered?
  3. Junior Member
    May 27th, 2009
    02-19-2012 12:28 PM #3
    Quote Originally Posted by greyhare View Post
    not sure what they are putting in..
    totally stock though - not lowered (yet!)
  4. Member greyhare's Avatar
    Dec 23rd, 2003
    Corvallis, OR
    02-19-2012 02:09 PM #4
    They are using junk or putting them in wrong. The standard bushings need to be correctly oriented and should not be that bad in 30k.
    You could go with the R32 bushing. It is solid so it does not need to be indexed.
    http://www.ecstuning.com/Volkswagen-...l_Arms/ES3893/
  5. Member Vaughan gti mk4's Avatar
    Aug 23rd, 2008
    Olympia wa
    02 Reflex GTI AWP, 03 Tornado red jetta AWP, 00 Flat Green Golf AWD
    02-22-2012 07:02 AM #5
    I replaced my first set of control arm bushing with a brand new complete OEM control arms and they started to get sloppy and tear at 20k so I went with Poly Energy mounts this time. My car is lowered quite a bit though so that would explain my bushings.
    x2 the R32 bushings are a good as well.
