Results 1 to 16 of 16
Thread: Modifying Stock Headlights on MK3 Jetta
  1. Member 20jetta98's Avatar
    Feb 8th, 2012
    CT
    1998 Jetta 2.0
    02-19-2012 08:09 PM #1
    I was wondering if anyone ever took the stock headlights apart and painted them like the e-codes u can buy for the jetta??? if so can u please guide me on how to do it without ruining the headlights?
  2. Member leftside's Avatar
    Sep 25th, 2005
    Specific Time
    MK4 / STI Limited
    02-22-2012 12:39 AM #2
    Yes, it's been done. FYI It's super difficult to get the lenses off the MKIII Jetta headlights. The OEM sealant is some form of silicone adhesive. Heat helps, but not much.
    There are some DIY's floating around. Pretty sure there's one in the MKIII DIY/FAQ thread
    (_fartbowl society_)
    HiDplanet
  3. Member 20jetta98's Avatar
    Feb 8th, 2012
    CT
    1998 Jetta 2.0
    02-25-2012 12:53 PM #3
    I looked and couldn't find anything. I'm afraid to melt the back of the headlight hence its Damn plastic... Any suggestions?
  4. Member sk8too's Avatar
    Dec 22nd, 2004
    Offutt AFB, NE
    97 Jetta VR swapped. 2010 CC VR Executive
    02-25-2012 03:12 PM #4
    you need to work on your searching ability. took me 2 seconds
    http://img651.imageshack.us/img651/7...eyheadligh.pdf
    97 Jetta GL, OBDI VR swapped, 262 cams, GIAC chip, turn 2 style CAI, Magnaflow catback, 2.9 clone manifold, eurospec flywheel, B&G RS2 coilovers, MKIV front and rear seats
  5. Member 20jetta98's Avatar
    Feb 8th, 2012
    CT
    1998 Jetta 2.0
    02-25-2012 06:43 PM #5
    thanks alot dude... im deff gona do that tomorrow!!!
  6. Member 20jetta98's Avatar
    Feb 8th, 2012
    CT
    1998 Jetta 2.0
    02-25-2012 11:23 PM #6
    Not much to paint on the gti headlights hopefully there's better results for the jetta lights... With there was a write up for jetta lights.. thanks guys.
  7. Member 20jetta98's Avatar
    Feb 8th, 2012
    CT
    1998 Jetta 2.0
    02-27-2012 09:20 PM #7
    i tired yesterday doing my headlights and put the temp up to 250 degrees and still couldnt get the adhesive to separate the light... idk if i have to put the temp higher or what..? please help...
  8. Member BooglesMcGee's Avatar
    Jul 27th, 2009
    Minot, ND
    1994 MK3 Jetta GL
    02-29-2012 05:19 PM #8
    http://forums.vwvortex.com/showthrea...&highlight=DIY
    Here ya go
    Edit: I remember reading on some other DIY that instead of masking off the entire reflective area, you should use as little tape as possible and just tape some cut out paper to it. Also, put the tape on a sweatshirt or something a few times to make it less sticky, less chance of pealing off the reflective paint. One more thing, don't paint the top and bottom of the reflective area like the DIY did, it will make the already poor light output on the stock NAs even worse.
    "What monstrosities would walk the streets if some people's faces were as unfinished as their minds." Eric Hoffer
  9. Member 20jetta98's Avatar
    Feb 8th, 2012
    CT
    1998 Jetta 2.0
    03-01-2012 07:10 AM #9
    thanks dude i appreciate it.... yea i put the temp up higher and after 250 i didnt feel comfortable unless i had spare headlights u know... thanks again.
  10. Member 20jetta98's Avatar
    Feb 8th, 2012
    CT
    1998 Jetta 2.0
    03-01-2012 07:51 AM #10
    isnt it being at 350 a little too much and might start to melt the back plastic??? did u leave the oven door open or close it for the duration?
  11. Member BooglesMcGee's Avatar
    Jul 27th, 2009
    Minot, ND
    1994 MK3 Jetta GL
    03-01-2012 12:30 PM #11
    I haven't tried it yet, but I'm planing to soon. I'm not sure if you should close the oven door or not, but I'm guessing you would, because the DIY says to leave it in for only 5 min, so I guess that's just enough to loosen the seal, but not long enough to warp the plastic.
  12. Member 20jetta98's Avatar
    Feb 8th, 2012
    CT
    1998 Jetta 2.0
    03-02-2012 09:42 PM #12
    idk i think ima try it on sun.. i just dont wana ruin my headlights and be screwed u know... when do u plan on doing urs... id like to know how urs comes out...
  13. Member BooglesMcGee's Avatar
    Jul 27th, 2009
    Minot, ND
    1994 MK3 Jetta GL
    03-03-2012 02:54 AM #13
    Next month maybe. I'm going to wait till it warms up a little so I can go to the pick apart and pick up a cheap 2nd set to do it to. I'm so paranoid about screwing up that whenever I modify a stock part, I buy another to do it to.
  14. Member 20jetta98's Avatar
    Feb 8th, 2012
    CT
    1998 Jetta 2.0
    03-03-2012 03:16 AM #14
    Deff a great idea... I'm just so tight with money right now its not even funny.. so idk.. see what happens.
  15. Member tykiers's Avatar
    Nov 12th, 2009
    wainfleet
    '95 vw golf sport 2.0L, 94 diesel 4 door golf(parts car), 95 vr6 passat, 97gti vr6
    03-22-2012 10:45 AM #15
    joey mod is all u need to know, and there are alot of construction materials u can use to seal it back up after that are better than silicone, ex. pl premium
  16. Member 20jetta98's Avatar
    Feb 8th, 2012
    CT
    1998 Jetta 2.0
    03-22-2012 12:51 PM #16
    hey boogles it does work... just takes time with the adhesive separating... takes about 45 min or a little more to get it separated then u have to wait for it to cool down to clean the old crap off...
