#176
RNS-315 install update: The geniuses at my dealership bricked my control unit while attempting to install my new headunit. A process that should take 4-5 hours is now going to take over 7 days. It's taking all of my strength to not drive over there and beat the crap out of someone.
#177
Current VWs: 2012 VW Passat TDI SE with Sunroof (mine); 2012 Jetta Sportwagen TDI (wife's)
Past VWs: 2007 VW Passat Wolfsburg 2.0T; 2001 VW Passat GLX V6; 2000 VW Jetta GLX VR6
#178
Side question. Not only am I experiencing the diminished sound, I cannot grab tags. I've tagged both in HD radio and Sirius. In each case, a message saying that no tagging device was connected comes up.
I've tried both of our Iphone 4s, a friends 3gs and my ipad.
Natureboy
#179
#180
#181
Don't get your hopes up. The response you get will most likely be one of the following:
A) "The device is working to designer specifications" - if they say this, ask them to send you this response in writing, as well as a copy of the specifications that say it should be doing what it is.
B) "Your files are incompatible with the stereo, please use the MDI port instead" - again, ask for this in writing. It will be hilarious to bust it out in court. I've saved mine.
C) "This feature is not supported by your car" - just laugh at them.
Unfortunately, I was given each of these answers by three different people, so maybe you will hear them all too!
I hope I am wrong, and please update us when you hear back from them!
#182
I'm so ready for this...by their logic, if this is per designer specifications, then VW made a conscious choice to change from full stereo streaming (early 2012 RCD-510: AD) to purposely streaming only half of every song (late 2012 RCD-510: AE). I can't imagine they could say that with a straight face...but per your advice, I'm doing everything in writing...
#183
#184
I'd be happy just to hear any music from my iPhone. I picked my new Passat up Monday and to this point I still haven't been able to get music to play via the MDI cable or BT. It's starting to annoy me.![]()
#185
#186
So, i showed my guy at the dealership how to test the streaming issue using the L/R slider on the iPhone. I know the Regional Case Manager contacted the dealership and they were working through it.
He said he tried it on all the other RCD-510's on the lot and found the same problem (not a surprise, but confirms the problem). VW Customer Care is supposed to contact me by end of day Monday...
#187
#188
#189
I'm ready...and in fact almost looking forward to it...I dig a good fight. I sent the Regional Case Manager and the dealership the following e-mail prior to today's appointment.
To whom it may concern,
Thank you for looking into this case. In order to expedite solving this problem, I wanted to e-mail you with the details around this problem and what I've found out through research and experimenting. My car will be at the dealership tomorrow (Friday, 5/17/2012)
A little over a month ago my wife and I purchased two new VW's. I purchased a 2012 VW Passat TDI SE and my wife purchased a 2012 Jetta Sportwagen TDI. Both have the same Premium VIII radio (RCD-510).
One of the features we were really excited about was the ability to stream music via Bluetooth A2DP. After listening for awhile, many songs didn't sound quite right and some sounded awful. It took a bit, but we finally figured out what it was. The audio only streams part of each song.
I wanted to explain the next part explicitly. Every song recorded in stereo has two channels, the left and right. This radio only receives the right channel. Therefore anything that is recorded on the left channel doesn't play. If there are vocals or guitar, etc. on the left channel...it doesn't play. It's very noticeable on certain songs, where you could be missing entire parts of a song. When I tried to show the dealership the first time, they thought it was fine because sound actually comes out of all speakers, however that sound is actually only from the right channel. The radio therefore only plays half of every song. (See illustration attached).
It doesn't seem to matter what type of Bluetooth device you have...same result every time...only the right channel. We happen to have iPhones (4 and 4s), but it also happens with iPads, Laptops and Android devices.
Through friends who also have new VW's we also found the following. VW's that were early in the 2012 production cycle (ours are later in the production cycle) with the same type radio, actually stream music correctly in stereo - both left and right channels. Music also streams correctly on the cars equipped with the RNS-315 and RNS-510. We have found that the early production 2012 models came with a different version of the RCD-510 (the "phone" button is actually a "mute" button instead) and has a different part number. We both have the newer version of the RCD-510. It seems odd that the newer version of the radio actually performs not as intended wheras the older version performs as intended. (See part numbers below.)
Early production 2012 RCD-510's (streams correctly) - Part Number: 1K0035180AD
Late production 2012 RCD-510's (doesn't stream correctly - OURS) - Part Number: 1K0035180AE
So, through trial and error with our cars and our friends we have narrowed the issue to our version of the RCD-510 head unit (part number: 1K0035180AE). We know it's not the phone and not the 9w7 Bluetooth module.
I wanted to make sure I explained the problem thoroughly so that it could be verified and then corrected. I am a loyal VW customer having bought my last 5 cars new from VW. We just spent $60,000 on new cars and are optimistic that Volkswagen will do the right thing to acknowledge it and fix them both.
#190
#191
I just got my 2012 Passat TDI back from my dealer yesterday. BT problem is solved. Well kinda. Because VW wouldn't give them any solutions to fix the problem. VW upgraded my RCD-510 to a RNS-315 Nav system. At no cost to me. VW paid for labor and parts 100%.
Take it to your dealer and demand they fix it. I can't believe that some of your dealers will not help you as a customer. The dealer was on my side on this project and helped convince VW of the problem.
I'm wondering if more and more people are having the RNS-315 installed to replace this. My dealer told me there was only 1 available in the US. They ordered the part before VW even agreed to replace it. But after they agreed to replace it they installed it for me. They have to remove your compass and install a NAV antenna to make the new Nav system work.
Good luck to you all!
#192
#193
#194
Sorry I never got one. My dealer did all of the complaining to VW. The only calls I got from VW was we are working on it. Then I got a call saying that they decided to replace the radio for me.
#195
#196
#197
They know about the problem and know how to fix it. Yet we'reexpected to individually prove to a local service center, the fact that we have a problem, at expense of hours and days of wasted time
#198
Here is My Dealer Information. I don't know how much it's going to help because they really didn't fix the problem. They just did a work around by giving me a new radio.
Eich Motor Company
www.eichvw.com
Hope this helps. Have your dealer contact them.
#199
#200
#201
#202
#203
I heard from Dolores today, same # but 2288....She said if I thought my dealer made a mistake in claiming my radio met specs, I should try a different dealer to 'get a second opinion'
My dealer called some kind of VW "tech line" who supposedly tested their RCD-510, which also streams one channel, and then told the dealer that the car was working to spec. When I suggested to Dolores that a different dealer would call the same # and get the same answer from VW, and hence it was VW and not the dealer who needed to act, she had nothing to say. In fact, most of what she said was gibberish designed to confuse me.
I think the point is they don't allow the RCM's to admit there's a problem unless there are told to do so by someone else, and thus until there's a TSB, or we write letters, no fix.
I spoke with the service manager at my dealer....he agreed with me that it seems wrong that the unit only streams one channel, but again, with tech line saying it was working correctly, he thought my sending a letter to VW would be more effective than him raising the issue. He indicated that tech line will say everything is working fine one week, only to issue a TSB on the same issue the very next week.
I think it's send a letter and hope for a fix of some kind....
#204
I know this is the Passat board, but just wanted to chime in and let you guys know that our 2012 Tiguan (built December 2011, purchased March 2012) has the same mono Bluetooth streaming you all are experiencing in the Passat with the RCD-510 (with the phone button).
We have our 90-day courtesy checkup in 2 weeks and I'm going to raise hell about the Bluetooth. Using the MDI cable is not an solution because I listen to Rdio and Pandora often, and for starters it's a pain in the ass to get Rdio/Pandora to play through the MDI cable instead of iPod music to begin with. Once you have the app streaming through the MDI cable, you better not hit "Next" on the radio or the steering wheel controls or else it'll start playing from the iPod again.
We did not pay extra to have a half-functioning advertised feature. The only acceptable resolution will be to fix the existing radio, or give us an equal or better radio that will provide us the advertised functionality.
The Tiguan boards are pretty dead, so hope you guys don't mind me joining in on the "fun"
#205
#206
Thanks! It's always bugged me that VW's trim levels aren't consistent across models. You'd think that a Passat SE would at least have the same standard features as a Jetta SE (and then some). I realize they have price points they need to hit, but really, can't spare a $60 module and cable?
I'd get away with the SD card if I could, but I listen to podcasts a lot (in addition to music) and so it's just easiest to use my phone so I can pick up where I left off and not have to jump around trying to find my spot on the SD card. The SD card works well for music I already have, but for how I actually use the radio in the car: I'm with you, Bluetooth is the best and only option, and the MDI cable might as well be non-existent for as poorly as it works for apps other than the iPod music.
#207
#208
Just got back from the dealership with my brand spanking new RNS-315 installed. NO BLUETOOTH STEREO ISSUE!
Send the letters guys. Make VW pay for their bull**** antics and broken stereos.
#209
Well, now, for all of your trouble you have a Nav, can watch DVD and, if you so desire, outfit er with a rear view camera . That and play music over A2DP![]()
Just might take the route ... Tired of having to use a $30 bluetooth adapter (via AUX) on a car that has a built-in BT
#210
Actually, I found out the geniuses at VW didn't bother to update the firmware on the stereo they sent me. So now, I am missing some VERY IMPORTANT Bluetooth features. The firmware on my RNS-315 doesn't support AVRCP (Audio/Video Remote Control Profile), which gives me the ability to prev/next tracks directly from my car, either on the steering wheel control panel, or the headunit itself. THIS IS NOT OKAY! I have called the dealership to see if they can update it, but they haven't called back yet. Luckily, this is something they SHOULD be able to do, in no time at all. It just sucks because I have to take MORE time off work to drive my ass back to Santa Monica to get it done!
The nightmare continues![]()
