Page 2 of 20 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Results 36 to 70 of 684
Thread: Billburt's DIY/build thread
  1. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    02-22-2012 02:29 PM #36
    OK so we got the IDF drop plates, rear wheel bearings rotors and pads on last night. I documented as much of it as possible...sorry if some came out blurry bc we were kinda excited to get the job done
    Before every DIY I will do a bit of explaining for the parts so the newer members can understand the functionality as well as the importance of doing such items. first up are the IDF drop plates. these plates are awesome little tools for the MKIV because the lower you go with your car the more you will begin to notice the rear wheel come closer to the front of the wheel well. The plates go on the rear beam and essentially re-locate the whole hub assembly back (the thing the wheel attaches to and allows it to roll down the road ). Not only do these center the wheel up in the wheel well, they now allow for more of a drop (about an inch), if you are on bags, because your tire will no longer be hitting towards the front, but at the top. Now you also need to know that these plates add -2 camber (leans the top of the wheel in a little which can cause increased un-eaven tire wear). Everyone says messing with the rear hub is a PITA but with the right tools this is actually a fun job. When I ordered these plates (i was the first to submit payment for them), I looked at my rear brakes and noticed that the rotors were very worn (there was a big lip on the out edge) and very rusty. the pads were also at a low point and needed to be changed. I ordered pads, rotors, and new rear hubs (wheel bearings) because all of it would be coming off anyway to get to where I could put the drop plates on.
    now for the fun part! A big thanks go out to Ryan V., Christian, and my brother for helping me with this DIY/install.
    NOTE: make sure you DO NOT have your e-brake cable pulled at all during the entire project
    IMG_0132
    there are two bolts that hold the caliper to the car and another two that hold the caliper together. I started by taking the caliper carrier bolts off (took a lot of pb blaster and patience hammering on a wrench to avoid stripping them).
    IMG_0106
    carrier bolt
    IMG_0110
    while we were working on the one side my brother was cleaning the caliper on the other
    IMG_0111
    the next thing we did was unscrew the set screw holding the rotor in place.
    IMG_0116
    it was stuck so we used a drill
    IMG_0114
    the lip was so big on the old rotors that we had to grind it down to slide the caliper off. to get the rotor to pop off we had to hit it with a hammer.
    IMG_0117
    IMG_0120
    We then took the cap off by hammering on a flathead to access the axle nut.
    IMG_0124
    The old cap off
    IMG_0125
    Now with the cap off we can get to the 30mm axle nut.
    IMG_0126
    OK, so this is where I dropped the ball and didn't take a pic of the gear puller. basically you can rent one from your local auto parts store if you don't have one. My uncle happened to have one in his garage across the street so we were able to pop the hub off quickly. below is a pic of what a gear puller looks like.
    IMG_0127
    The hub off and getting cleaned up a bit
    IMG_0128
    IMG_0129
    it was then time to get the inner race off the hub via dremel, flat head, and hammer.
    IMG_0133
    IMG_0134
    IMG_0135
    we then cleaned up the hub with some sand paper to ensure a good fit for the new wheel bearings.
    IMG_0137
    and then put white lithium grease on it to help the wheel bearing slide on.
    IMG_0139
    application of the lock for the bolts holding the drop plates on.
    IMG_0140
    while my buddies were getting the drop plates ready I cleaned up the dust shields and prepped them for paint. i decided to go with silver caliper paint because I have always liked the look and it kind of makes the rear brakes look bigger rolling down the road.
    IMG_0142
    IMG_0143
    after letting them dry for a little bit we brought them over and put them on with the drop plates and then put the new wheel bearings on.
    IMG_0145
    we then put the rotor on and applied more white lithium grease onto it to help prevent it from seizing with the hub. Don't forget to put your set screw back in (or your new one if it came with it).
    IMG_0151
    OK, another part where I dropped the ball. I forgot to show the process of putting the new axle nut on. Basically all you have to do is spin it on and torque it down with an impact, then spin it off of tight and then torque it back down with a torque wrench (I set mine at 129ft-lbs). Then we put the new cap back on.
    IMG_0152
    it's also important to note that when you put new rotors on that they have a coat on them that helps prevent rust before they are shipped. you can use a can of this to clean off the coat. just spray it on and wipe it off.
    IMG_0154
    Then we put half of the caliper back on and set the pads in place, and bolted down the rest of it.
    IMG_0155
    IMG_0156
    IMG_0157
    NOW, since the drop plates have set everything back a little the reach on your e-brake cable will need to be extended, so just unclip it and slide some slack back a little and clip it back on...then pop your e-brake cable back into place.
    IMG_0159
    IMG_0158
    After all that is done hop in the driver seat and pump the brake to set the pads in place. go back over everything and check for tight. Make sure you double check all your work seeing as this is your stopping power on the road .
    Once that is done you can torque your wheels back on and enjoy! Now that they are on i have taken the car to the alignment shop to determine how many toe shims I need. I will DIY this at a later date to help reduce the tread wear.
    IMG_0161
    IMG_0164
    IMG_0165
    IMG_0166
    UROTUNING__The SteveGangBang 11.21__TheHazeBang_2012_TheGreatCatTakeover2012_
  2. Member oldskool1963vw's Avatar
    Aug 28th, 2005
    Tampa
    2001 Jetta TDI/ 1963 type 1
    02-23-2012 08:46 PM #37
    Quote Originally Posted by Mr.Tan View Post
    so essentially you are telling people that your car is inspirational to others? nothing like being a bit cocky eh?
    That's exactly what I thought when I read the title....but Will's not really THAT kind of guy.
    He does forget to give props to those that help sometimes and return tools in a timely fashion, but other than that hes tits
  3. Member urban_assaualt_mk2's Avatar
    Oct 6th, 2010
    lexington nc
    91 golf 1.8v, 02 1.8t jetta
    02-23-2012 09:47 PM #38
    Seriously thank you for this tread! I just got my first mkIV and have so many questions and this thread I'm sure will answer them all.
    I'll drive
  4. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    02-24-2012 03:02 AM #39
    Quote Originally Posted by oldskool1963vw View Post
    speaking of which I would like to hang on to your 30mm 12pt for when I go back and do the tow shims...that cool?
    Quote Originally Posted by urban_assaualt_mk2 View Post
    I hope this helps man. PM me if you have any questions
  5. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    02-24-2012 03:34 AM #40
    Looking good buddy
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  6. Member xjasongli814x's Avatar
    Jun 6th, 2011
    NWPA
    OEM GLI
    02-24-2012 11:05 AM #41
    Yeah man, this is exactly what I want to be reading. That DIY on the pads and rotors above just made me want to finally order new stuff because I've been meaning to. I love the silver brake shield too. Nice touch!
  7. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    02-24-2012 11:08 AM #42
    Thanks guys. We put the eurojet street FMIC in last night and changed the fuel filter. Next DIY should be up later today.
    Sent from my TI 83 plus silver edition using tapatalk.
  8. Member oldskool1963vw's Avatar
    Aug 28th, 2005
    Tampa
    02-24-2012 08:07 PM #43
    Quote Originally Posted by Billburt View Post
    Of course. I don't think I will need it anytime soon anyway.... When u doing the shims?
  9. Member JettaGotBoost's Avatar
    Nov 27th, 2010
    Cleveland OH
    Corrado 16v Big Turbo.
    02-24-2012 09:23 PM #44
    Anyone know what wheels are on that mk5?
  10. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Mark 5 R32 (track), Mark 4 GTI (bagged)
    02-24-2012 09:32 PM #45
    Your mintex pads arent squeaky? Mine are loud as a bitch.
    Quote Originally Posted by mk4boost View Post
    If you don't want to break the bank you have the wrong hobby
    My Thread
    Rochester Performance Euro (Roc-Euro)
  11. Junior Member
    Mar 30th, 2009
    London, ON
    1975 VW Super Beetle
    02-24-2012 09:38 PM #46
    Looks great, nice attention to detail in your work, even the small jobs, good on you
  12. Member livinzlyfe's Avatar
    Jan 8th, 2008
    MD
    dark red girl car, cop car.
    02-24-2012 09:38 PM #47
    contemplating some of those drop plates.
    Flickr l the internet sucks. l it's all about the e-fame.
  13. Member jolf43's Avatar
    May 10th, 2011
    East Cleveland
    Transgender Girl Car
    02-24-2012 09:39 PM #48
    Quote Originally Posted by JettaGotBoost View Post
    52 designs snowflakes and this is a mk4 bud
    http://fifteen52.us/
    -Dan
    Instagram: dan_berhent
  14. Member jolf43's Avatar
    May 10th, 2011
    East Cleveland
    02-24-2012 09:40 PM #49
    i retract my statement. the mk5 on the first page has tarmacs that can also be found on the same site by 52 designs
    -Dan
  15. Member Alfredo_mk3's Avatar
    Nov 6th, 2008
    Tukwila, WA
    99.5 VW Golf
    02-25-2012 01:49 AM #50
    Quote Originally Posted by Bierce IV View Post
    yeah i got some mintex pads on mine, and one of them gives out a slight squeak, ridiculous..
  16. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    02-25-2012 02:24 AM #51
    remind me we should make a "not so cheap mods" and "maintenance" thread, the current DIY sticky thread has too many missing pictures and content IMO
    if you guys think it's a cool idea i'll go ahead and create those two thread following the same rules from the cheap version and make them sticky if the get a lot of valuable content
    Kudos to you Billburt for doign this thread , great pics
    BIODiesel Powered | MKx Channel VW/Audi Videos United
    MKIV Forum User Guide | Forum Rules
    Quote Originally Posted by dele
    The guys on coils can pull off their own Airless pride thread cos they clearly are the underdogs in the air/static debate, kinda like the equality movement for women.
  17. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    02-25-2012 04:27 AM #52
    Quote Originally Posted by kilimats View Post
    Thanks man, yea I would love to contribute to those. The next DIY im putting up is on the eurojet FMIC which to my knowledge has no good DIY at all.
  18. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    02-25-2012 04:29 AM #53
    They are as quiet as can be, and my last set never made noise either (knocks on wood).
  19. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    02-25-2012 04:29 AM #54
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  20. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    02-27-2012 10:26 PM #55
    DIY for eurojet FMIC will be going up tonight. I finally got around to uploading the photos
  21. Member Niagara_V_Dub's Avatar
    Sep 25th, 2007
    Las Vegas, NV / Lemoore, CA
    hoopty on air
    02-28-2012 01:47 AM #56
    These plates are on my list of to do's once I FINALLY (been piecing it together slowly over the last few months) and while I am at it might as well do the brakes, rotors and bearings too. Reall clean looking car though.
    This thread is the wind beneath my wings.
    Insert witty quote
  22. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    02-28-2012 01:59 AM #57
    and now for the Eurojet Street FMIC install. I'm truly sorry in advance for this one will not be as detailed in term of pictures but, I will try my best to make up in text description. I must say that this is my second time installing this intercooler system and I am pleased to say that it has gone better this time and I have found it easier and cleaner than the latter.
    I must once again thank Ryan V., my brother, and Christian P. for helping me with this install.
    You will want to jack the car up and put the fronts on jack stands. You must begin by removing the front bumper. some may wish to take the front wheels off in order to better access the front wheel well cover screws, but with the proper tools it is not necessary.
    the engine bay before
    IMG_0171
    Then take the front grill and lower side grills out. the front grill can be removed by popping the hood and utilizing a screw driver for popping off the metal retaining clip and twisting the screw driver to pop loose the plastic hood latch pull. once that is done you can pry from the top of the grill towards you and carefully pop out the grill from the bumper. The lower side grills can pop off with no tools and the use of your fingers. Press down on the left and right sides of the grill where the slits are. my thumb displays where to apply pressure for the left side. It should pop right out with no trouble at all.
    IMG_0168
    IMG_0169
    IMG_0170
    IMG_0177
    Now that the grills are off it is time to remove the bumper cover. you will need a torx bit set because there are two different sizes needed in order to remove it. if my memory is correct there are 5 in the area below where the grill is, one behind each lower side grill and three on each side holding the bumper cover to the wheel well covers. all are pictured below being removed. Once all 13 screws are removed you can (with the aid of an extra set of hands) safely remove the bumper cover; it should just slide off. As the bumper is sliding off you will need to un-plug the side marker bulbs and if you have a special edition that reads outside temp you will need to un clip that as well which simply slides off. the bumper cover is then free to be removed and set aside safely.
    IMG_0172
    IMG_0173
    IMG_0178
    IMG_0182
    IMG_0188
    IMG_0189
    Now that the bumper is removed the removal of the front beam and stock side mount intercooler can begin. I would suggest by starting with the removal of the front beam. This might seem like a rudimentary task but it is far more difficult than it seems. There are two bolts and two screws per side. Each one of these plays a very important roll in holding a different portion of the front end together. Once the beam is removed you will notice that the front end has sagged. Unless you re-bracket the new (eurojet) front beam in the same position as the OEM one your bumper cover will not fit properly, the hood latch may not latch the hood as easily as before. Essentially you will need to fine tune this in order to ensure proper fitment. We adjusted it several times and opened and closed the hood multiple times until it was found to be as close to original as possible. Unfortunately when I purchased this kit used it did not include the Eurojet rebar (front beam), so I had to make due with the my old rebar from my old car and ground the plates off the OEM front beam and painted them so that I could continue to hold my front end together. I have included a photo of the Eurojet rebar for you to know what it looks like if you have not purchased it yet.
    IMG_0190
    IMG_0193
    IMG_0191
    IMG_0194
    test fitting the brackets
    IMG_0204
    In this photo you can see the painted brackets I have made from the old beam.
    IMG_0207
    The images of the Eurojet rebar as promised
    Uploaded with ImageShack.us
    And now it is time to remove the side mount intercooler. we started by removing the piping in the back of the engine bay that starts at the top of the turbo and heads down the passenger side to the intercooler. after the intercooler a pipe goes up to the side of the intake manifold which can be seen from the engine bay. All of these pipes are very easily unbolted/ unclamped to be removed. This is where I was unable to photograph some of these parts. I have been recovering from an internal injury and am unable to climb under the car to record that part of the removal process.
    It is important to unclamp and disconnect the diverter valve and all the other hoses related to the turbo inlet pipe as well as the top pipe that comes out of the turbo, because all of it will be re-routed.
    IMG_0241
    IMG_0187
    then you can unclamp the the top pipe as well as the pipe that heads down towards the pancake pipe which leads to the intercooler.
    IMG_0184
    IMG_0180
    IMG_0183
    IMG_0185
    IMG_0186
    This is the pipe that heads down towards the bottom of the car towards the pancake pipe
    IMG_0232
    IMG_0231
    If you would like to clean up the engine bay a bit more there are two of these pipe supports that are no longer needed and can be unbolted very easily.
    IMG_0237
    The next pipe to remove is the pancake pipe which can be removed from under the car in the front passenger side behind the wheel. once removed the bracketing for the side mount can be un-done. Before removing the intercooler it is important to unscrew the MAP sensor from the body of the side mount so as not to pull and damage the wiring. The hose between the side mount and the intake manifold in the engine bay can remain inside and attached to the intake manifold for it will be re-used with the eurojet FMIC. it may be difficult to keep it in there while removing the side mount so if is possible to remove it with the side mount and put it back in (as I have done).
    the pancake pipe removed
    IMG_0230
    the plastic side mount duct being removed
    IMG_0208
    IMG_0210
    The side mount being unbolted and removed
    IMG_0211
    IMG_0214
    IMG_0217
    IMG_0219
    IMG_0222
    IMG_0220
    IMG_0223
    NOW that everything has been removed from the old system you can now begin to install the new FMIC. I started with the mounting of the front mount itself in place on the front of the car. i have painted the front of the intercooler with semi-flat black paint to add for a stealth look and avoid ruining the clean look of the front of the car
    IMG_0250
    I would recommend that you start with the pipe in the engine bay and the routing of the boost hoses underneath it. The new routing is slightly different. The pipe from the turbo no longer goes to passenger side but now goes up and over towards the drivers side and down next to the battery so as to reach the right side of the intercooler. this portion is a bit tricky because you need to take an OEM hose you removed and cut it down to the right size for the diverter valve to reach the intercooler pipe. Below you can see the routing I have done. It is a very tight fit but it will work until I do the emissions delete which will once again simplify and clean the engine bay.
    IMG_0242
    Attaching the intercooler pipe to the turbo
    IMG_0245
    IMG_0248
    IMG_0243
    IMG_0249
    IMG_0257
    After this pipe there are two more for this side: the one that goes down and turns towards the outside of the car and the "U" shaped pipe that turns the routing to attach to the intercooler. below are the photos of this side being attached to the intercooler. NOTE: a hole must be cut out in the plastic splash guard so that the piping may go through to the intercooler. You also must make sure every clamp is properly set on the proper side of the bead and tightly secured. YOU WILL blow the pipe loose if it is not properly secured. you will also want to make sure every clamp screw is easily accessible in case you do blow a clamp loose or need to work on the car.
    IMG_0255
    IMG_0256
    In order for the pipe to clear I flipped the top horn on it's bracket and turned the lower one.
    IMG_0263
    IMG_0261
    The last thing to do is to secure the passenger side piping between the hose attached from the intake manifold in the engine bay and the right side of the intercooler pipe.
    IMG_0251
    NEW MAP SENSOR LOCATION
    IMG_0252
    NOW that all connections are complete i urge you to go back and check every clamp and connection there is in the system prior to putting the bumper back on. with this intercooler and piping it is not necessary to do any trimming to the bumper; it should slide back on properly and everything should go back on as it was before the installation. I am very pleased with the way it turned out as well as the fact that the cars modifications remains stealth.
    IMG_0267
    IMG_0264
    IMG_0265
  23. Member rains's Avatar
    May 30th, 2008
    Sherwood Park
    2000 GTI [1.8t], 1993 Jetta [ABA-T]
    02-28-2012 02:27 AM #58
    now is inspired
    LULZ
    This thread is now about car cakes.
  24. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    02-28-2012 10:16 AM #59
    Hopefully the next DIY will be the emissions delete/engine bay cleanup. I'm just waiting on 034 to send us the silicone hoses we need. if they get here this week we will start Friday night.
  25. Member Oly1975's Avatar
    Sep 28th, 2011
    Bremerton, WA
    '04 PG GLI 1.8T, '66 Pontiac Ventura 4DHT, '68 Fatchic, '69 Fatchic
    02-28-2012 10:51 AM #60
    I love this thread. Thanks Billburt
    Giac x+ (pump), NewSouth Performance 0-30 psi turbo gage w/center steering column mount, Euro Sport "CAI" heat shield w/ITG foam filter, N75J valve, Eurojet Mini Grenade DV, Forge motorsports TIP, APR 2.5" turbo back, NGK BK7RE Plugs gapped to .037, Koni full adj Coil Overs, ECS Adj endlinks, H&R 28mm adj rear sway bar, 20mm rear spacers, vented passenger liner for SMIC.
  26. Member pGLi's Avatar
    Apr 27th, 2009
    Finger Lakes/Orange County, NY
    MK IV
    02-28-2012 12:31 PM #61
    helpful DIY
    PG
    Quote Originally Posted by 87vr6 View Post
    having a car and not driving it to keep miles off of it for any future owner is like having a girlfriend and not screwing her so she doesn't get worn out for her future boyfriends...
    She was just admiring... my ride
  27. Member
    May 8th, 2010
    24v GLI
    02-28-2012 06:20 PM #62
    Lol that side mount wasss Sloopyyyy
    Some day we'll do a bagging DIY for mkivs mkvs Mr. W.
  28. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    02-29-2012 12:11 AM #63
    Quote Originally Posted by Loud View Post
    indeed we will
  29. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    03-01-2012 01:55 PM #64
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  30. Member Dutchmastr9's Avatar
    Sep 13th, 2004
    Boston
    2 Door bugatti coupe...er, i mean Golf Racecar
    03-03-2012 12:38 AM #65
    watching
    You Aint About That Life | ETYolo
    Ruined Blue Golf | 42 Draft Designs
  31. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    03-03-2012 01:46 AM #66
    I'm new and I would like some inspiration.
    Quote Originally Posted by pentaxshooter View Post
    Ant's car doesn't actually move. He just drives a rollback as a daily. A GTI happens to reside on it.
    Maintenance is paramount.
    Corn Status l Podi l Gonzo GTT l ORT
  32. Member
    May 21st, 2010
    Lebanon IN
    05 GTI
    03-03-2012 02:30 AM #67
    wait your handing out inspiration for free??
    looking good duder
  33. 03-03-2012 03:02 AM #68
    ---- CHECK IT --> imagoodboy.com <----
    OMG BUILD THREAD!!!
  34. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    03-03-2012 10:26 AM #69
    Quote Originally Posted by .Ant View Post
    maintenance is paramount is about the best I can give you
    Quote Originally Posted by senad187 View Post
    looking good duder
    rare around these parts haha thanks man
  35. Member Billburt's Avatar
    May 2nd, 2006
    sLUTZ, FL
    03-03-2012 10:31 AM #70
    some updated camber shots
    come at me bro!
    IMG_0273
    IMG_0272
    IMG_0269
    IMG_0270
    IMG_0166
    and this was the before
    IMG_0262
