Results 1 to 14 of 14
Thread: Boost leak?
  1. Member V-DUBchic's Avatar
    Oct 22nd, 2007
    North AL
    04 Jetta 1.8t
    02-21-2012 09:45 AM #1
    Hey guys, looking for some advice. i've got an AWP with FMIC, 3" TB, TIP, CAI, DV, DIY'ed catch can, secondary air deleted, and chipped with C2 Motorsports. When i was first chipped, it was great! At WOT I spiked at 22 and held around 17-18psi. But after adding a couple mods (maybe it was the catch can? or the splitter dv?) and lots of mileage, ive noticed that now at WOT I spike MAYBE at 18-19 and hold at 14-15psi. The car doesnt feel like its got that pep it had when first chipped. Another fact to keep in mind is before it was chipped, the car pulled 195hp at the wheels. NOW, after being chipped for several months with alot of mileage, it dynos at 193hp at the wheels. WTF?!? i'm assuming i have a boost leak? or should i be concerned about any component about to fail? Thanks!
  2. Junior Member
    May 25th, 2011
    Southwestern Ontario
    2002 VW Jetta 1.8t
    02-21-2012 11:54 AM #2
    My setup is similar, a few things you can check that I've experienced:
    -Ensure the bolts on your wastegate actuator rod haven't backed off (common problem)
    -Test diverter valve + check for slightly torn hoses in the vacuum system (I've had a forge 007p with a bad rubber seal in the past, would bleed off boost, but was still able to hold pressure)
    -Turbo to manifold gasket could be going (This caused lag and loss of boost for me in the past)
    -Replace MAF (this worked for me, I had no leaks at all and regained 4 psi from a new MAF)
    Those are good places to start. Pop off a charge pipe close to your front mount and see if there's any oil clogged in there. (unlikely, but you never know)
    02' AWP :: UniStage2+ @25psi--Frankenturbo F4H :: Bosch 440cc :: NGK BKR7E@.028 Gap :: B&B 3" TurboBack :: Boostvalve MBC+N75F Parallel :: Forge007p DV :: VMaxx Coilovers
  3. Member V-DUBchic's Avatar
    Oct 22nd, 2007
    North AL
    04 Jetta 1.8t
    02-21-2012 02:20 PM #3
    thanks! i swapped my DV with another known good one and no luck. but i'll use this as my check list.
  4. Junior Member
    May 25th, 2011
    2002 VW Jetta 1.8t
    02-21-2012 07:16 PM #4
    No problem. Again, since you are still able to hold some amount of boost it doesn't always point to a boost leak. If your max boost gets lower and lower I would definately pressure test the system if you can get ahold of one.
    Also check your backpressure if you have a vacuum gauge, a clogged cat could also do that if I'm not mistaken.
  5. Member V-DUBchic's Avatar
    Oct 22nd, 2007
    North AL
    04 Jetta 1.8t
    02-22-2012 01:39 PM #5
    looked at the wastegate. nothing seemed to be loose or out of place. i did notice a hose under the manifold wasnt securely connected, but it was coming off a check valve near the oil filter housing. that did nothing i also noticed that my boost is getting slightly lower. it now spikes at about 16-17 and holds at 12-13psi .
  6. Member V-DUBchic's Avatar
    Oct 22nd, 2007
    North AL
    04 Jetta 1.8t
    02-22-2012 01:40 PM #6
    i think i'll swap out the N75 for a known good one and maybe even the MAF.
  7. Junior Member
    May 25th, 2011
    2002 VW Jetta 1.8t
    02-26-2012 02:13 PM #7
    Know anyone with a smoke tester? That would rule out any air leaks pretty quickly.
    Did you check the turbo to manifold gasket?? Or even exhaust manifold gasket? How's your spool?
  8. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    02-26-2012 05:21 PM #8
    build a boost leak detector, it's in the FAQ thread and such.
    also do some little stuff cleaning, like hte throttle body, run some 44k, and of course, make sure all connections are tight and squeeze test all vacuum lines. they look ok but can still be junk.
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  9. Banned dubinsincuwereindiapers's Avatar
    Jan 16th, 2008
    InYourMom
    Bugatti Veyron
    02-26-2012 06:22 PM #9
    Quote Originally Posted by Vegeta Gti View Post
    This.. x10000000
  10. Member V-DUBchic's Avatar
    Oct 22nd, 2007
    North AL
    04 Jetta 1.8t
    02-28-2012 07:20 AM #10
    ok, so i swapped the MAF and N75 with a known good car and no luck. Part numbers matched right up with the donor car too. I keep looking at all my hoses and see no physical defects. what is this 44k stuff? i'm assuming fuel injector cleaner? if so, i ran some pretty potent stuff called 4-power about 2 months back. the throttle body should be clean, because when i took off the intake manifold to paint it, i cleaned the hell out of the TB. that was about a year ago. Maybe a small exhaust leak? I cant hear on at all! I was planning on upgrading the ko3s to a ko4-001. I guess it's time now! maybe swapping the wastegate, changing the gaskets, etc will fix the problem!
  11. Member V-DUBchic's Avatar
    Oct 22nd, 2007
    North AL
    04 Jetta 1.8t
    02-28-2012 07:21 AM #11
    i'll also, check out this DIY for the detector. thanks everyone for your advise
  12. 04-28-2012 09:49 PM #12
    Having the same problem. Did you resolve yours?
    .:WordsThatMakeSenseAlliance:. #1
    Ill=Doctor-Sick=Hospital-Dope=Jail-Static=Shock-Bagged=Groceries
  13. 04-30-2012 12:39 AM #13
    There is no substitute for a pressure test. PERIOD.
    Progressively pressurize the system up to your spike level and listen for leaks. They will manifest themselves as a loud hissing or whining sound. You will find several, undoubtedly.
    I thought my system was solid until I pressurized it to 20 psi and found 3 boost leaks and one vacuum leak.
    2003 Jetta 1.8T, APR Stage II ECU Upgrade, Forge 007 DV, 3" DP + 2.5" CB, Neuspeed Cone Filter, Silicone TIP, Forge TB Hose, FMIC, Snow Performance Stage II MAF actuated dual nozzle Water/Methanol Injection, NewSouth PowerGasket, 2.0TFSI igntion coils w/ IE adapters, Denso IK22 Iridium plugs @ .040", Ultimate N249/SAI/PCV/EVAP delete,catch can, ECS Stage II clutch w/ lightweight flywheel Need VCDS in Hampton Roads VA? PM me!
  14. Member V-DUBchic's Avatar
    Oct 22nd, 2007
    North AL
    04 Jetta 1.8t
    04-30-2012 10:43 AM #14
    never did a pressure test. just kinda lived it. i rarely go WOT anymore anyways, but i DID however have a KO4 installed and it seemed to fix the problem. Turns out, the turbo had a crack in it and the gasket had two leaks in it. i now spike at 24 and hold a strong 17-18psi. I'm going to take it easy until i get the software for it. gonna get flashed at SOWO!
