Page 1 of 2 1 2 LastLast
Results 1 to 35 of 40
Thread: FS: 1983 Jetta Deluxe $1500obo Effingham, IL
  1. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    '86 Jetta Deluxe, 16v, GLX 5-lug
    02-21-2012 02:47 PM #1
    Up for sale is a 1983 Jetta Deluxe 1.7L 5spd.
    New ignition control module, Beru plug wires, Napa Echlin dizzy cap and rotor, NGK platinum plugs, OE clutch cable, OE clutch cable grommets, rebuilt shifter relay w/OE parts, and short shift bracket is being welded now. The steering rack boots are torn, I have new OE replacements for that.
    I am heading to Bommarito VW in St Louis tomorrow for a shifter dust boot and a throttle pedal cable bushing. The bushing is keeping me from driving the car.
    I drove it around a little before rebuilding the shifter/short shift and tune up. I am suprised how the 1.7 pulls and that's with the distributor clamp very loose from the previous owner, which has been tightened.
    The spark plugs that came out were a bit sooty. I'll go through that vacuum lines and check things out. The front brakes are a bit rusty from lack of driving, I have been looking into GTI Rabbit brakes as an upgrade to the solid non-vented that comes on the car.
    Previous owner had tires put on recently, a locally bent cat-back exhaust (which needs a cat to pipe gasket), and there's a new coil spring in the trunk (I don't know the story about that).
    Driver's seat cushion is broken down a little bit, the rest of the seats are in great condition. No structual rust, there is some surface rust here and there on the body. Strut towers are just fine. The dash is in fantastic shape. I have not tried the moonroof. The parking brake works great. The radio is a Pioneer cd player and rear speakers appear to be JVC, I don't know about the front speakers. Half shafts and tie rods are in great condition.
    I plan to bring the car down the Feb 25th stlvw.org gtg and have some better pictures taken of it.
    Parts list:
    -EP541 Napa ignition rotor
    -EP274 Napa ignition cap
    -211905351D OE Huco ignition module
    -7084 NGK spark plugs
    -MDO385 OE Beru Spark plug wires
    -171798211 OE shifter rebuild kit
    -171711574B OE gear shift selector shaft
    -171711593E OE gear shift selector shaft
    -171711163E Gear Shifter Shaft Relay Lever
    -171721335E OE clutch release cable
    -171721308 Clutch cable grommet
    -171721307 Clutch cable grommet
    -1H0422831B steering rack boots
    -171412031B Sachs/Boge frt struts
    -171412329A Febi frt strut mounts
    -191837207 Driver's door handle
    -171711210 shifter dust boot plug
    -171711195C Shifter dust boot
    -431721559 throttle pedal/cable bushing
    -OP6066 oil pressure sensor (at cyl head)
    -171407365F ball joints
    -277-5226 Coil springs
    -171498625D Wheel bearing kit
    -155422803 x2 Complete tie rod assm's
    -N90206103 clutch bolts
    -BS40427 rear main seal kit
    -056103609A oil pan gasket
    -027141999 LUK OE clutch kit
    -020141073A throw out bearing cover (cover with clutch kit leaked)
    -893407237 CV joint bolts
    -N10013401 clutch cover bolts
  2. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    02-25-2012 04:50 PM #2
    Making a 200 mile round trip bump!
  3. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    02-26-2012 03:36 PM #3
    A friend took some better pictures of the car last night. I did about 300 miles of driving the last two days. The front right strut is blown, the heater works great, oil pressure switch replaced, and there's a hard start issue when the engine is warm. I'll be looking into this issues soon.
    And for the pictures:
    http://www.flickr.com/photos/4814564...th/6786028768/
  4. Member
    Aug 7th, 2011
    MKE, Scompton
    65Beetle
    02-26-2012 04:06 PM #4
    What kinda fuel mileage are you getting with the car? Looks killer
  5. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    02-27-2012 07:39 PM #5
    Quote Originally Posted by StaticAir View Post
    I did a 200+ mile round trip from Effingham to St Charles, MO to Ladue, MO then back to Effy on about $25 with gas at $3.45
  6. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    02-29-2012 11:04 AM #6
    PMs replied bump
  7. 03-01-2012 12:37 PM #7
    Looks great!
    What type of springs/shocks are on the car now? What's the miles on it?
  8. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    03-01-2012 07:17 PM #8
    Quote Originally Posted by Rewind4 View Post
    Looks great!
    It has worn out stock shocks and stock springs now. The RF spring is saggin a lot. A local club member has a set of stock springs I will pick up and could install with some Sachs/Boge strut inserts, or if a buyer wants me to install something different (at buyer's cost), I am just fine with that.
    The mileage is just under 145xxx
    I picked up a throttle pedal bushing, shifter dust boot, driver's door handle, and aftermarket antenna that I haven't added to the parts list yet.
    All repairs have been preformed with a A1 Bentley manual. The Bentley manual is not included with the sale of the vehicle. The library that I have it loaned from would not like that very much.
  9. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    03-01-2012 07:18 PM #9
    BTW, thanks for the compliments.
  10. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    03-11-2012 05:36 PM #10
    Bump for replacing a few parts.
    I have Febi German made frt strut mounts in hand, I am wanting on German Sachs/Boge frt struts. They should be here Monday.
    While diggin on the car, the right inner tierod is rusted and the steering boots is very torn (no biggie, I have new ones already). Good thing I have struts coming, the RF strut is not letting the spring drop, like it is stuck compressed. That may leave a mark when I take it apart.
    The steering wheel started "clunking". The lower bearing has slipped out of the steering collumn tube. I checked with the local VW dealer, a couple parts are still available but most have been discontinued. If it sticks around long enough, I'll check into that. Also, the oil light still flashs at me occasionally. I bump the dash and it goes out.
    Parts list in first post will be updated.
  11. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    03-14-2012 03:21 PM #11
    Got new struts and mounts today.
    Anyone want 30 year old "lowered" suspension? Yeah, suspension work is much needed.
    Also, the RF wheel bearing doesn't sound healthy free-spinning, just another project.
  12. 03-16-2012 01:08 PM #12
    Could I get your contact# to ask a few questions about the car? Thanks!
  13. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    03-17-2012 01:32 PM #13
    Quote Originally Posted by Dogginu2 View Post
    PM sent
  14. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    03-26-2012 07:28 PM #14
    Been doing some work.
    I replaced the RF wheel bearing, no more ticking noise. Ball joints boots were ripped but still moved firmly, not bad for 30 year old ball joints. They were still riveted in. Those got replaced. I ended up getting new springs, 4dr Automatic Rabbit springs. They have a lil heavier spring rate. Should have all that in tomorrow night. The tie rod boots are ripped so the inner tierod joints are rusted bad, tierods are on order.
    Pleasant suprised, this is the only rust on the front strut towers.
    parts listed updated.
  15. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    04-10-2012 11:30 AM #15
    Still for sale bump.
    The car was ticking from the RF, while replacing the suspension, I found the wheel bearing was bad. That got replaced.
    I also picked up some Meyle tie rod assm's to put in soon.
    parts list updated.
  16. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    04-16-2012 07:07 PM #16
    pm's replied.
  17. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    04-26-2012 07:30 PM #17
    Still up for sale.
    The car has developed a vibration coming from the RF. Since the ball joint, wheel bearing, and strut mount are new, they are it (I checked them, they are tight). Half shaft is firm, but there is a tear in the outer boot. There is a bit of play at the output flange of the trans. I have a couple transmission lined up if that turns out to be the problem.
  18. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    05-05-2012 10:58 AM #18
    The car is at the www.mamotorworks.com swap meet today. Stop by and take a look...... Bump
  19. Member kp88713's Avatar
    Jan 25th, 2009
    alot, all vw tho
    05-08-2012 04:59 PM #19
    damn it you are so far away
  20. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    05-20-2012 05:20 PM #20
    Quote Originally Posted by kp88713 View Post
    I would gladly meet in the middle. South side Chicago looks to be the center.
  21. Member violentaesthete's Avatar
    Oct 27th, 2008
    uwstout or johnsburg illinois or MKE
    LA6U 1991 Jetta D | 1998 Dodge Dakota 2.5L (beater/parts/motorcycle truck) | 1983 Yamaha Virago 500
    06-07-2012 01:22 AM #21
    Still F/S?
    LOWERIT
    Quote Originally Posted by dankvwguy View Post
    saw your car at sowo. my gf didnt like your wheels so i slapped her
  22. Member Nostalgia's Avatar
    Sep 25th, 2003
    Mankato / Minneapolis, MN
    1993 SLC, 1992 900 Turbo Convertible
    06-07-2012 05:17 PM #22
    Quote Originally Posted by truckmaniac View Post
    This is like a story problem I would give my algebra class.
    If gas was $3.45, and he spent $25, he bought ~7.25 gallons.
    Since he traveled 200 miles on that gas, divide that by 7.25 to get the miles per gallon.
    Comes out to ~27.59 mpg. Not too shabby.
  23. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    06-14-2012 07:08 PM #23
    Yes, still for sale.
    Darn vortex for not sending me notification of replies.
    Pm'ing you now.
  24. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    06-14-2012 07:10 PM #24
    Quote Originally Posted by Nostalgia View Post
    That's funny.
    And the mileage has only got better!
  25. Member vwkid_Zach's Avatar
    Dec 14th, 2007
    DeKalb, IL
    1987 Scirocco 16V 1998 Chevy Blazer LS
    06-18-2012 10:55 PM #25
    I don't mean to correct a math teacher......... but,
    I plugged the locations he mentioned into google maps and that's actually roughly 251 miles. All of the fancy math aside, that's actually ~34.6 mpg!
    Zach
    Quote Originally Posted by Amsterdam087 View Post
    drive backwards, you will have the advantage of rwd
  26. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    06-27-2012 01:46 PM #26
    Either way, BUY THE CAR!!!
    I replace the right half shaft and got rid of the vibration. Now I have an 210mm OEM A2 clutch on order and swapping the flywheel to replace the clutch. I'll probably replace the timing belt soo also.
  27. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    07-07-2012 01:25 PM #27
    The clutch started dragging so I parked it till I had time to look into it and not pass out from the heat!
    Found the problem, the thrust plate retainer spring popped out and lodged itself into the pressure plate. (11 o'clock posistion)
    Thank God a customer with an air conditioned shop let me use his lift!!!!! :up:
    I upgraded to a 210mm A2 8v LUK clutch. I also did a rear main seal and oil pan gasket. I'll update the parts list eventually.
  28. Member Maggiolone's Avatar
    Aug 20th, 2007
    Illinois
    84 Jetta Coupe, 07 Impreza
    07-31-2012 06:29 PM #28
    Hmmm. The Illinoisan in me wants to give this a good home :/
  29. Member vwkid_Zach's Avatar
    Dec 14th, 2007
    DeKalb, IL
    08-01-2012 02:01 AM #29
    PM sent
    Zach
  30. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    08-01-2012 10:22 PM #30
    Quote Originally Posted by Maggiolone View Post
    I have no cash in hand from anyone, you are very welcome give it a good home.
    Quote Originally Posted by vwkid_Zach View Post
    PM sent
    replied
  31. 08-11-2012 07:56 PM #31
    Pm sent
  32. Member xthechadx's Avatar
    Sep 6th, 2005
    Denver CO
    81 dasher mTDi, 03 GTi 24v
    08-12-2012 08:50 PM #32
    With all the work done would you trust it on a 800 mile drive? I would stop in ks so not all at one but VERY intrested in this car, also I didn't see a price
  33. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    08-13-2012 09:00 AM #33
    Quote Originally Posted by xthechadx View Post
    I have made several 300+ mile round trips recently with this car with no issues.
    The price is listed in the title.
    A friend said he is buying is but no money has changed hands, so technically it's still available.
  34. Member bherman13's Avatar
    Sep 9th, 2010
    The Village of 7,400 Location:___ and the City of 3,100
    MK3 VR6 Jetta Vehicles:___ B4S TDI Passat
    08-30-2012 09:36 PM #34
    IDK if this is still for sale, but I'm gonna bump it for you for being probably the most local vortexer to me. I've spent a lot of time in Effingham, who knows, maybe I've seen you. I live in Newton and am currently going to SIUE, so I'm making the trip up and down I-70 almost every weekend. If you need parts from down here, maybe you could PM me and we could make a deal of some sort, save you some fuel.
  35. Member truckmaniac's Avatar
    Dec 26th, 2006
    Effingham, IL
    09-06-2012 08:03 PM #35
    Quote Originally Posted by bherman13 View Post
    Hmm... if you take 33 to I-70, you are about two blocks from my house as you travel through Effy. I work in St Elmo if you ever passing by.
    I'll keep you in mind with the parts idea.
