VWVortex.com - NEW! Vw Golf Jetta Rabbit Automatic Transmission Fluid (ATF) Filter Change Kits
    Results 1 to 1 of 1
    Thread: NEW! Vw Golf Jetta Rabbit Automatic Transmission Fluid (ATF) Filter Change Kits
    1. Banner Advertiser Blauparts's Avatar
      Dec 26th, 2007
      Manitowoc, WI
      02-21-2012 05:03 PM #1
      NEW BLAU™ Vw Automatic Transmission Fluid (ATF) Change Kits
      New Kit Listings:
      Vw Golf Automatic Transmission Fluid Filter Change Kit - 2010 2.5L w/ 6 Speed Tiptronic Transmission
      Vw Golf Automatic Transmission Fluid Filter Change Kit - 2006-2011 w/ 6 Speed Direct Shift Gearbox (DSG) Transmission
      Vw Jetta Automatic Transmission Fluid Filter Change Kit - 2005-2010 2.5L w/ 6 Speed Tiptronic Transmission
      Vw Jetta Automatic Transmission Fluid Filter Change Kit - 2005-2010 w/ 6 Speed Direct Shift Gearbox (DSG) Transmission
      Vw Beetle Automatic Transmission Fluid Filter Change Kit - 2006-2010 2.5L w/ 6 Speed Tiptronic Transmission
      Vw Beetle Automatic Transmission Fluid Filter Change Kit - 2002-2008 w/ 6 Speed Direct Shift Gearbox (DSG) Transmission
      Vw Beetle Automatic Transmission Fluid Filter Change Kit - 2002-2008 1.8T and 2.0L w/ 6 Speed Tiptronic Transmission
      Vw Passat Automatic Transmission Fluid Filter Change Kit - 2006-10 w/ 6 Speed 09G Tiptronic Transmission
      Vw Passat Automatic Transmission Fluid Filter Change Kit - 2010 2.0L w/ 6 Speed Direct Shift Gearbox (DSG) Transmission
      Vw Rabbit Automatic Transmission Fluid Filter Change Kit - 2006-2009 w/ 6 Speed 09G Tiptronic Transmission
      Vw CC Automatic Transmission Fluid Filter Change Kit - 2009-2011 w/ 6 Speed Direct Shift Gearbox (DSG) Transmission
      Vw Eos Automatic Transmission Fluid Filter Change Kit - 2007-2010 w/ 6 Speed Direct Shift Gearbox (DSG) Transmission
      Vw Touareg 4motion Automatic Transmission Fluid Filter Change Kit - 2004-2010 w/ 6 Speed Tiptronic Transmission
      Vw automatic transmission fluid levels should be checked at regular intervals. Changing your Vw automatic transmission fluid helps extend the life of your transmission by properly lubricating the main shaft bearings and synchros. The intervals depend on your operating conditions. The Vw automatic transmission fluid and filter should be serviced every 30,000 miles when driving in heavy city traffic, hot weather, trailer pulling, and other severe driving conditions. The 60,000 miles change interval applies to those who mainly put on highway miles. With the exception of the DSG transmission, which the factory manual recommends be changed every 30,000 - 40,000 miles. Vw ATF Fluid Details / Specifications
      Some suggest that you don't need to change your Vw's automatic transmission fluid. See our illustrated write-up as to why feel free this isn't the case. Many Vw models came with several transmission options. Looking to locate your transmission codes? See our 'How To Find Vw Transmission Codes' write-up.
      CURRENT SPECIAL!
      Free FedEx ground shipping to the 48 contiguous 48 US states on all in stock ATF kits. Offer Ends 2/29/2012.
      Website: www.blauparts.com
    Tags for this Thread
