#1
Used for so little miles I cant even remember.
Less than 1k miles.
For a ko4.
Had it installed on my franken turbo. but meant for oem ko4. works on both.
Worked great.
Comes with the spring kit.
What you see is what you get.
$175 shipped OBO
42 Draft Designs
#3
Do they work on thw ko3?
Miss spelled words courtesy Motorola electrify via tapatalk
infinity front,votex rear,st coilovers,eurodyne tapp 1000cc tuned,hks ssq bov, pte 5857 pagparts turbo kit with 38mm tial wastegate. spec stage 3, custom intake, bbm fuel rail, modded 225 exhaust,ecs bleeder block,mbc,fmic,bfi mounts,cm flywheel,
#4
42 Draft Designs
#7
this will work with a STOCK ko4s (225) ??
What spring is in it (how many psi does it hold with spring pressure)?
why are you selling it ?
Thx
#8
Yes it is made for the ko4.
All springs are included.
I don't use a ko4 anymore.
42 Draft Designs
#9
Bump for a great WG
I loved mine on the Ko4. It's going on the F23![]()
#10
42 Draft Designs
#15
No...specific to ko4....180TT is ko3s. They do have a acutator for it though.
The mounting brackets are quite different between the two.
On a side note....i am still interested in the spring kit if you want to sell it or "1" of them separately....in particular the blue and red springs....
Yellow is what most will upgrade to...
Joe
