Results 1 to 19 of 19
Thread: Golf/GTI Dynaudio Amp.
  1. Member cosmicgreenGTI's Avatar
    Feb 16th, 2001
    Norcal SF Bay
    04 R32, 10 Golf TDI, 96 993 C2
    02-22-2012 01:55 AM #1
    SOLD!
  2. Member waloupis's Avatar
    Nov 1st, 2009
    CT
    2010 GTI - 2001 GTI 1.8t
    02-22-2012 08:36 AM #2
    ANY idea if this will plug & play on a RNS-510 deck? If so, I'll take it!
  3. Member R32dreamer17's Avatar
    Oct 11th, 2007
    Central Coast
    2012 DBM GTI
    02-22-2012 04:18 PM #3
  4. Member cosmicgreenGTI's Avatar
    Feb 16th, 2001
    Norcal SF Bay
    02-22-2012 05:48 PM #4
    Quote Originally Posted by waloupis View Post
    no idea. I bought this with the speakers, I wanted the speakers. I think it depends more if your car has the harness in the vehicle going under the passenger seat.
  5. Member cosmicgreenGTI's Avatar
    Feb 16th, 2001
    Norcal SF Bay
    02-29-2012 01:52 AM #5
    TTT
  6. Junior Member
    Mar 24th, 2009
    College Park
    1997 MK3 GLX, 1998 MK3 GLX, 2004 GTI 1.8T, 2004 B6 Audi A4, 2011 MK6 GTI
    03-28-2012 09:19 AM #6
    Still for sale?
    dub life
  7. Member cosmicgreenGTI's Avatar
    Feb 16th, 2001
    Norcal SF Bay
    04-01-2012 09:13 PM #7
    yes...
  8. Member mhjett's Avatar
    Oct 16th, 2000
    Northern Virginia
    2008 VW Jetta SE
    04-03-2012 04:34 PM #8
    What's the part #?
    1995 VW Jetta GLX VR6 [07.2003 - 03.2012]
  9. Member cosmicgreenGTI's Avatar
    Feb 16th, 2001
    Norcal SF Bay
    04-04-2012 11:37 PM #9
    everyone...I dont know if this will fit in a non-dynaudio equipped car. search the vortex.
  10. Member mhjett's Avatar
    Oct 16th, 2000
    Northern Virginia
    2008 VW Jetta SE
    04-05-2012 09:29 AM #10
    A part # would confirm that
  11. Member cosmicgreenGTI's Avatar
    Feb 16th, 2001
    Norcal SF Bay
    07-29-2012 09:15 PM #11
    still available, 50 shipped!
    part # is 5K0 035 456
  12. 07-30-2012 12:51 PM #12
    im interested. could you tell me where can i get the dynaudio speakers and where i can find the instalation for this?
    or may be you could tell me where to put the amplyfier.
  13. Member mhjett's Avatar
    Oct 16th, 2000
    Northern Virginia
    2008 VW Jetta SE
    07-30-2012 02:50 PM #13
    Quote Originally Posted by Fabiomozzone View Post
    Oh Lordy....
  14. Member cosmicgreenGTI's Avatar
    Feb 16th, 2001
    Norcal SF Bay
    07-30-2012 10:33 PM #14
    um, no. your on your own.
  15. Junior Member xiviperi's Avatar
    Feb 25th, 2012
    Chicago
    B6 Passat 3.6 4motion
    08-02-2012 01:12 PM #15
    I know you probably don't know, but if anyone does I will take it today. I have a 06 passat w/dynaudio I just looked under the seat its the old bigger black one with black fins. The drivers door ch likes to cut off from time to time. If anyone could tell me if its the same plugs/wiring I will send you paypal today.
    Thanks,
    Ed
    2006 Passat 3.6 4motion
    2012 GLI Autobahn w/nav
    2011 Jetta TDI
  16. Member type17volkswagen's Avatar
    May 2nd, 2004
    Alexandria, VA
    All original 77 Rabbit; 12 Prius C; 13 Jetta
    08-03-2012 07:50 PM #16
    Quote Originally Posted by xiviperi View Post
    Thanks,
    Ed
    I've done no research BUT
    1. This is from a 2010 GTI which only had 300 watts. Your Passat has 600 so it's pretty certain it's not the same amp. But you could get the part number off yours and match it to the number he listed in his post to confirm.
    2. Did you check the B6 forum for a TSB related to Dynaudio cutting out? I recall a TSB about a wire grounding out over time. You should definitely check that before you buy an amp.
  17. Member mhjett's Avatar
    Oct 16th, 2000
    Northern Virginia
    2008 VW Jetta SE
    08-04-2012 11:02 AM #17
    Passat B6 amps and mkVI Dynaudio amps are not compatible. If they were, I would have bought OP's a long time ago.
  18. Junior Member xiviperi's Avatar
    Feb 25th, 2012
    Chicago
    08-04-2012 11:13 AM #18
    thanks for the info and i will check to see if it is a short. How simple and cheap that would be. Good luck on the sale.
    2011 Jetta TDI
  19. Member cosmicgreenGTI's Avatar
    Feb 16th, 2001
    Norcal SF Bay
    08-07-2012 11:13 PM #19
    amp is SOLD!
