VWVortex.com - Burning oil - 5w30 to 10w40?
    The Car Lounge
    Results 1 to 25 of 25
    Thread: Burning oil - 5w30 to 10w40?
    1. Member ssaffioti's Avatar
      Apr 9th, 2006
      '14 IS350, '00 F-150 V6 5MT, '30 Ford A
      02-22-2012 10:00 AM #1
      Friend of mine has a 160k-mile '00 Saturn coupe that is using enough oil to foul spark plugs in two years of driving. He's a student and needs to affordably nurse it along at least until graduation.
      I was going to suggest using a heavier oil than the 5w-30 it calls for. I think a 10w-40 would be safe, but I have seen many owners manuals over the years that specifically say to not use a 40 weight oil. I assumed that was mainly for economy reasons, and especially living in Texas, that there wouldn't be anything wrong with it.
      Do you agree that 10w40 would probably be a better (and perfectly safe) choice here? Will it make much difference in the oil consumption? Any other product he should use?
    2. Member cryption's Avatar
      Mar 27th, 2006
      Houston
      99 Miata, 2013 F150
      02-22-2012 10:05 AM #2
      Give it a shot, and try a high miles oil
      Team 30k Jetta - Frat Boys
    3. Member DustinM's Avatar
      Apr 1st, 2008
      Tallahassee, FL
      2013 Chevy Sonic Sedan 1.4T Manual
      02-22-2012 10:09 AM #3
      Do what my friend did with a car burning oil. Stop leak + 20w50. Lasted him another 4 years when he junked it, and bought a new STi.
      Offikial Minister of Bad Judgements and Floridian Truths of the Independent People's Republik of Offtopikstan
    4. Senior Member urogolf's Avatar
      Dec 10th, 2000
      Somerset, MA
      13 Plug In Prius, 15 Venza
      02-22-2012 10:32 AM #4
      Quote Originally Posted by DustinM View Post
      THIS
      if its a beater, who cares
      ................................................www.CCCIS.com
    5. Member adrew's Avatar
      Aug 14th, 2003
      Texas
      '12 Yaris, '17 Corolla
      02-22-2012 10:34 AM #5
      The 40-weight helped a bit in my old Trooper.
      Improving the signal-to-noise ratio
    6. Member GermaniuM's Avatar
      Mar 29th, 2001
      Toronto, ON
      02-22-2012 10:36 AM #6
      I agree with the guy a above. Try 20w50.
    7. Member compy222's Avatar
      Apr 7th, 2005
      Pothole, Midwest
      Honda Fanboy Collection
      02-22-2012 10:40 AM #7
      more viscosity will slow the seepage past the rings/seals in general. it will generally make for slightly harder starts and potentially more engine wear in very unpleasant weather conditions.
      Quote Originally Posted by capsaicin View Post
      AP1 S2000? I can not in good conscience talk you out of that. May your slip angle be great and your bed not be the couch!
    8. Member mhjett's Avatar
      Oct 16th, 2000
      Northern Virginia
      '08 VW Jetta SE 2.5
      02-22-2012 10:43 AM #8
      ^ any colder weather concerns are probably a non-issue in Texas.
      I'd give it a shot. At 160k miles in a Saturn, that car is well beyond its 9th life.
      2008 VW Jetta SE 2.5
      1995 VW Jetta GLX VR6 [07.2003 - 03.2012]
      Jun 22nd, 2006
      Maryland
      Fiesta ST, Flex
      02-22-2012 10:46 AM #9
      Sure it's burning oil, and not leaking past the spark plug tube seals? (I assume all coupes have the DOHC engine?)
    10. Member ssaffioti's Avatar
      Apr 9th, 2006
      02-22-2012 11:25 AM #10
      saron81 :
      That I couldn't tell you... I haven't seen his car in quite some time. He had the car towed to a mechanic when it started misfiring - mechanic changed the plugs but made no mention of leaking spark plug tube seals.
    11. Member
      Jun 22nd, 2006
      Maryland
      Fiesta ST, Flex
      02-22-2012 11:47 AM #11
      Quote Originally Posted by ssaffioti View Post
      Might want to take a look at that. It's a pretty common failure on a lot of DOHC engines.
      Some cars have them built into the valve cover gasket, some are seperate o rings. Mechanic didn't try to determine the source of the oil? Time for a new mechanic.
    12. Member ssaffioti's Avatar
      Apr 9th, 2006
      02-22-2012 12:29 PM #12
      Quote Originally Posted by saron81 View Post
      I should have answered your question more accurately, sorry! I meant to say, I have no idea about the condition of the tube seals, but we do know it burns oil. It's smoking a bit and the electrode end of the plugs was completely fouled.
    13. Member
      Jun 22nd, 2006
      Maryland
      Fiesta ST, Flex
      02-22-2012 12:38 PM #13
      Right... but where is the oil coming from? It could be leaking past the spark plug tube seals, which would be a cheap and easy fix, or it could be worn valves/guides/seals/piston rings which probably wouldn't be worth fixing. If it's the later, just drive it 'till it breaks, or needs new plugs again.
    14. Member DustinM's Avatar
      Apr 1st, 2008
      Tallahassee, FL
      02-22-2012 12:48 PM #14
      The fact that the electrodes are fouling tells me it's not likely to be the tube seals. That would just cause a miss with a rich condition, and a small amount of oil seeping in. This seems more like bad rings, or valve seals.
      Just from my experience, and the few details we're getting.
    15. Member
      Jun 22nd, 2006
      Maryland
      Fiesta ST, Flex
      02-22-2012 12:51 PM #15
      We had a Mini here the other day with the tube seals leaking so badly it wouldn't start at all.
      Plugs were coated.
    16. Member Süsser Tod's Avatar
      Aug 3rd, 2001
      Mexico City, Mexico
      KLE650, XJR1300
      02-22-2012 12:51 PM #16
      If it was that, the oil wouldn't make it into the cylinder.
    17. Member DustinM's Avatar
      Apr 1st, 2008
      Tallahassee, FL
      02-22-2012 12:54 PM #17
      Plugs were coated.
      but did it burn oil when it was started? I'm assuming when he says burning, the car is blowing blue smoke, and it's not just leaving the oil pan via any way possible.
    18. Member DustinM's Avatar
      Apr 1st, 2008
      Tallahassee, FL
      02-22-2012 12:55 PM #18
      Quote Originally Posted by kerridwen View Post
      There'd be a small amount that made it around the threads. I've had a slight leak on an old honda that in turn would cause it to blow a tuft of blue smoke. replaced the VC gasket and tube seals, and it never did it again.
      (That honda also only had like 100psi compression across all 4, it was beat to death.)
    19. Member compy222's Avatar
      Apr 7th, 2005
      Pothole, Midwest
      02-22-2012 01:09 PM #19
      good lord, it probably had about 12hp left...
    20. 02-22-2012 01:44 PM #20
      Quote Originally Posted by compy222 View Post
      Out of 13, not bad.
      Did you know that it's not pronounced Em Kay ? ALL OF THE CAR LOUNGE WILL BE HAPPY TO LET YOU KNOW THAT. SERIOUSLY. IT STANDS FOR MARK. DID YOU KNOW THAT? BEFORE THAT A1,A2, A3, ETC WAS USED. LIVE UP TO TCL STANDARDS BEFORE YOU GET ON MY ASS. THAT'S DISGUSTING.
      Example of TCL's standards
    21. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      '05 Volkswagen Jetta GLI
      02-28-2012 11:58 AM #21
      Quote Originally Posted by emkaytree View Post
      Out of 13, not bad.
      Thats hilarious :-P
    22. Member DustinM's Avatar
      Apr 1st, 2008
      Tallahassee, FL
      02-28-2012 12:04 PM #22
      I have to LOL at that, but the honda cost a whole hundred bucks, and had most of its interior. The engine got some type of stop leak that I swear was the consistency of almost dried superglue.
      It lasted me almost a year, and I sold it for a profit.
    23. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      A Few Alphas
      02-28-2012 12:07 PM #23
      Try 20W50.
      I'd avoid using stop leak, unless the heavier weight does not fix it.
    24. Member DustinM's Avatar
      Apr 1st, 2008
      Tallahassee, FL
      02-28-2012 12:09 PM #24
      Quote Originally Posted by Aonarch View Post
      Try 20W50.
      It's definitely evil stuff, but I'm going to guess it'll need to gum up some of the non existant seals.
    25. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      02-28-2012 12:13 PM #25
      10w40 is going in the g/f's GTI this weekend. It's burning about a quart between oil changes. When I still worked at the garage we use to switch all high mileage cars over to a heavier weight. Works like a charm.
