VWVortex.com - Need help piecing together a BT setup
    Page 27 of 39 FirstFirst ... 1723242526272829303137 ... LastLast
    Results 651 to 675 of 965
    Thread: Need help piecing together a BT setup
    1. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      2001 Audi TT Quattro
      06-24-2012 01:28 PM #651
      Do the kinetic instructions include a step where it says take a crowbar to the firewall
      Sep 24th, 2009
      CT
      2001 Jetta Wolfsburg Edition
      06-24-2012 03:58 PM #652
      Quote Originally Posted by formerly silveratljetta View Post
      instructions?
      CTS/Kinetic Top Mount Kit (Garrett GT3071R), Eurodyne Maestro 630cc, Siemens 630cc Injectors, Walbro GSS340 In-tank, New South Column Mount Boost Gauge, TT/R32 Control Arm Bushings, 18x8 ASA AR1's wrapped in Continental Extreme Contact DWS, BFI Stage 2 Dogbone Inserts, Eurojet Street FMIC, 42DD Stealth Catch Can, BFI Stage 1 Engine and Transmission Mounts, 42DD 3in. Turboback Exhaust, TSI Ignition Coils w/ IE Adapter Plates
    3. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      '05 Volkswagen Jetta GLI
      06-24-2012 04:20 PM #653
      I'm running two springs for 20 psi. Call me brave.
      I ran across one major issue on first start hence why my car is sitting at the garage right now because I ran out of time to work on it. The oil return line was leaking a fair amount of oil at the turbo. So I'm thinking the line will need replaced. Also from what I was told it's blowing a small amount of smoke on gear shifts. Not a major concern as I was contemplating replacing the precision down the road anyway.
      I didn't have time to get the Walbro in or fine tune anything however it fired right up. Idle was a bit rough but nowhere near bad. It drove nice with no problems other than those I listed. I'm calling it a semi success.
    4. 06-24-2012 05:19 PM #654
      Please tell me you primed that Turbo before startup Travis
      Quote Originally Posted by gdoggmoney View Post
      There's been too much butt sniffing before this dog fight.
      PagPartsTurbo www.speeding-g60.com INTEGRATEDengineering
    5. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      01 Jetta Wolfsburg Ed, 04 Jetta GLI 24v 6spd
      06-24-2012 05:41 PM #655
      Quote Originally Posted by travis_gli View Post
      do you have an oil return gasket in there? also, no surprise it smokes between shifts it's a PTE
      My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
    6. Member schwartzmagic's Avatar
      Apr 29th, 2007
      MIA
      2011 Jetta TDI; 05 VW Jetta GLI 5857BT
      06-24-2012 10:11 PM #656
      Quote Originally Posted by Big_Tom View Post
      Come on Tom... Enough with the PTE smoking crap... I'm almost at 2 years with mine. No smoking whatsoever. Blah :p
      Sent from my MB860 using Tapatalk 2
    7. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      06-24-2012 11:12 PM #657
      Quote Originally Posted by schwartzmagic View Post
      don't get mad i see mad PTE's smoking a lot of times they do it's a fact.
    8. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      06-25-2012 09:04 AM #658
      Didn't know I was suppose to prime it... it's a used turbo... I did crank it a little and let off before actually turning it completely over. However probably not near enough to actually prime it. I feel like a total dumb@ss at this point. Could that have caused enough damage for the turbo to blow oil?
      It appears to be leaking somewhere in the AN fitting to the turbo. I ran out of time yesterday so she's sitting at the garage waiting for them to have a look. If it keeps smoking I'm buying a Garrett or having it rebuilt.
      EDIT: After reading a few different opinions over the intertubez I feel comfortable that me not priming it isn't the cause of it blowing oil. If anything its because its a used Precision. I won't get into the details that I have read.
    9. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      06-25-2012 11:08 AM #659
      installer error
    10. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      06-25-2012 11:33 AM #660
      installer error
      Being that its a used turbo there was still oil in there from the previous install. I doubt it would have caused that much harm. I'm going to run it and if it gets worse probably pull it and have it rebuilt.
    11. 06-25-2012 12:08 PM #661
      In the future always prime the turbo no matter new or used.
    12. Member codergfx's Avatar
      Jan 10th, 2009
      Cali
      03 GTI GT3076r, 03 JETTA K03, 03 AUDI A4 GT3076R
      06-25-2012 12:18 PM #662
      Quote Originally Posted by Twopnt016v View Post
      Used precision though is meh been there lll
      MY BUILD | - GT3076r, 3" to 2.5" turboback exhaust (vbanded), Tial 38mm wastegate, fx400 6 puck, Peloquin LSD, VF Poly Engine Mounts, Greddy Profec B Type II, walbro 255 inline fuel pump, ID1600cc @ 3bar running on e85. AMB head, AWD bottom end. 434whp 369wtq @ 30psi (OLD: 383 whp 333wtq @ 23 psi)
    13. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      06-25-2012 12:23 PM #663
      We all make mistakes.
    14. 06-25-2012 12:41 PM #664
      Quote Originally Posted by codergfx View Post
      Its best to prime...period.
    15. Member
      Feb 21st, 2004
      Stanceville
      94 Jetta scrapin pinch welds
      06-25-2012 12:42 PM #665
      Not terribly sure on turbo priming logic.
      Shut your car off, pull your oil feed line. Does oil pour out of the filter housing and back out the line? Not on any of the BT cars I have owned.
      Now that doesn't mean there is not some in the line left further down where it doesn't curve, up and over but I bet some drains back.
      I've had my oil line off at least 6-7 time and it never leaks massive amounts, on the turbo side maybe a drop or two. Same for the oil filter housing side......
      Food for thought. Oh and my 3076 does not smoke, has no play and is peachy keen still.
      By the time it fires up, after a few good cranks you will have oil in that line. Someone start their car with the line off the filter housing and take a video
    16. Member
      Feb 21st, 2004
      Stanceville
      06-25-2012 12:52 PM #666
      Quote Originally Posted by T-Boy View Post
      Always a good thing to try and reduce under hood temp. Won't kill you if you don't, but it'll keep things like wiring harness, plastic rain tray, and rubber/silicone lines from getting super heated and cooled (constant extreme heat cycles deteriorate things).
      Actually it can. Enough glowing red turbo will set off the firewall insulation blanket material BEHIND the aluminum layer.
      Just ask how I know!
    17. Member T-Boy's Avatar
      Jul 16th, 2003
      ATL
      06-25-2012 01:02 PM #667
      Well anything is possible, but for the majority of people (at least from past experiences) that didn't wrap haven't had too many issues. Can oil drips cause a fire? Sure just ask Stu... I've seen stock cars catch fire also, but most have been pretty isolated incidents and not too common.
      APR Stage 3071R+
    18. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      06-25-2012 01:20 PM #668
      Updated the signature.
      Also what should I do about my injectors? The connectors are completely different but they still fit in one another and make full contact. Do they make some sort of adapter?
      EDIT: I believe I need these?
      http://www.034motorsport.com/fuel-in...4-p-20128.html
    19. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      06-25-2012 01:39 PM #669
      I wasn't being serious. If the turbo was bad it would smoke all the time not just between shifts
    20. Member
      Jun 21st, 2010
      '68 912, '07 STI
      06-25-2012 01:48 PM #670
      Yep - USCAR > Jetronic adapters for the 550s.
    21. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      06-25-2012 02:05 PM #671
      Soooo... you don't really save money getting the 550's.
    22. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      06-25-2012 02:31 PM #672
      No just headaches
    23. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      06-25-2012 02:45 PM #673
      I wouldn't say headaches. It idled like a champ on first start up. And I only ran it for maybe 2 minutes.
    24. 06-25-2012 04:00 PM #674
      Proper spray pattern = one less thing to tune around.
    25. Member
      Feb 21st, 2004
      Stanceville
      06-25-2012 04:32 PM #675
      I have two sets of 630's. Both drive entirely different and idle entirely different on the same tune.
      630's vary highly in response time, dead time and output for a given known pulsewidth near and under 2ms.
