Doesn't the clutch master share the fluid supply with the brake master by way of the nipple/port on the brake fluid reservoir? The two systems don't share pressure, only fluid supply/reserve.
The brake fluid reservoirs on ABA cars have a sealed off nipple/port where the hose that feeds the clutch master attaches on a VR6 car. So can't you simply cut the sealed nipple/port open, or get the brake fluid reservoir for/from a VR6 car?
. I know that the Corrado uses a slave cylinder and was wondering if I could get away with using a master cylinder from a Corrado? Input is greatly appreciated.
