some vag com logging..!
i want to make sure the car runs PERFECT!![]()
#1
This thread is long overdue. We all know that the MKV forum is flooded with dimwits
Today I installed my BFI torque arm insert and stg 1 transmission insert. Install was a breeze and thanks BFI for such a fast turnaround. Shifts feel much smoother and the engine feels less sloppy. There are a bit of vibrations in the cabin but it should settle down once they break (mainly the transmission insert) in.![]()
#3
took off my suitcase muffler. I can put it back on in 5 min. Goes from nearly stock quiet to very very loud. Single manaflow straight through and usp catted pipe. Sounds a little ricey at low rpms.
5 cylinder FTW
#4
just drove her all day, been deciding what kind of muffler i want to use for a custom exhaust...![]()
Upper Deck Dubs
www.throwthevee.com
#5
It was really nice out today, so i gave my 2.5 a good beating on some back roads![]()
#6
#7
ultimately i would want my car to sound like this...but SO MUCH MONEY
http://www.youtube.com/watch?v=ne4a5w-hr80
Upper Deck Dubs
www.throwthevee.com
#8
#11
Put it on jacks stands with the intent to change the tranny fluid only to then realize I did not have a 17mm HEX. Dropped her back down and met up with some friends at Starbucks.
#12
Mine sounds like this and I love it!!!!!
... Well I just finished the SB Stage III endurance install... man i don't think there is enough space on this forum for this story lol.
But in brief:
The concentric spacer for the flywheel was radially 1 mm (0.04 in) too small. So that pushed it back two days with no transmission installed. Got it all buttoned up (a thunderstorm in there to that really p*ssed me off) and I star the car like normal. I'm like wow, no noise, no nothing sweet. I pump the clutch a couple times. *WOW what a difference, there is a clutch in there. I go to shift into reverse CRUNCH!!!!! And I'm like SOB!!!! so none of the gates will open (except reverse) when the car is running. It is rather tough when the car is off. I did not have time to bleed the line or re-adjust the shifter cables. I hope that fixes it or I have no clue what to do. It is 4:45AM here and I'm off to bed. Sadly another day w/o my vw...![]()
C2 tune, Peloquin LSD, .717 TDI 5TH gear swap, USP test pipe, AWE exhaust (AMAZING), BSH CAI, H&R street sport coilover + 25mm RSB, neuspeed short shifter, 17x8 BBS RGR. **********FOR SALE THREAD:********** http://forums.vwvortex.com/showthrea...-%28OEM-LED%29*****http://forums.vwvortex.com/showthrea...0#post76396880
#13
Cant wait for my mani to come in today... Waking up, and im stoked!
sent from tapatalk
#14
#15
#16
Ready to do a trans fluid change. My car has never had one, and it has 100,000 driven......Probably will change again in another four months or so
**- 2005.5 VW Jetta Package 2 with 2008 2.5L -**
BFI stage 2 transmission mounts
#17
#18
Trying to figure out data logging/graphing with my new vagcom.
#20
set up the works for the 5 seperate throttle bodies coming acrossed the pond![]()
www.nothingleavesstock.com
NLS's full line of parts on our online store!http://nothingleavesstock.com/online...=0&sort=normal
Email us at sales@nothingleavesstock.com 230 E. landis st. Coopersburg PA 610 282 5487
#21
#22
#23
Shoulda tried out the old lug bolt trick. I might be wrong on this but Ive heard that you can take out one of your lug nuts and it will fit right in the screw for the tranny. Just gotta use a wrench to brake it loose. Pretty sure this works will mostly all of VWs trannys but again, I could be wrong. Anyone else wanna chime in on this?
http://s529.photobucket.com/albums/d...abbit%20build/
2006 Sage Green Rabbit 5spd| UM SRI manifold | UM 93 SRI tune | NLS Cai | Custom Eurojet exhaust | USP testpipe | ECS lightweight crank pulley | BSH motor/trans mounts |034 Dogbone core| NLS SS w/42DD bushings | GTI brake swap w/SS lines | Koni yellows w/H&R race springs | GTI rear sway |
#27
All I see is a box...![]()
#28
#30
my jelly is in beast mode
#32
Yesterday I replaced my front lip, put in new fog bulbs (3000K), and today I hardwired my detector![]()
#33
Washed her and then used Lucas Oil Slick Mist Speed Wax - I love this stuff! Highly recommend
http://www.lucasoil.com/products/dis...id=79&loc=show
Then I took a few photos since it was almost 70 here today
#34
I need a job I have too much time on my hands![]()
#35
Drove my car for the first time in 3 weeks...and drove it hard![]()
United Motorsports 2.5T
