Page 1 of 2 1 2 LastLast
Results 1 to 35 of 55
Thread: 1985 GTI on a college budget
  1. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-22-2012 11:32 PM #1
    Picked this up the other day, Needs work but hey it's 27 years old... Replaced the rear wheel bearings, pads and rotors, new front tires, and ordered some weather stripping to replace the drip rails which are toast and leaking. Runs great other than an idle issue which I'm working on.
    Progress will be slow since I am in college, most of the work will have to be done on weekends. anyways here it is....
    I thin the front pas. side fender is the wrong year or something... the driver side curls in at the end and the pas. side is more straight. Not sure, that's just something to add to the list...
  2. Member PDXGTI8V 2.0's Avatar
    Oct 11th, 2005
    Portland ORYGUN
    + over 7500 posts pre-ban
    02-22-2012 11:44 PM #2
    Thats probably not a fender problem..it appears you need to loosen up your core support and align it, as the grille is completely out of alignment...
    My 91 GTI 8V, original owner stylz, yo!: http://www.flickr.com/photos/4144775...13544433/show/
  3. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    :faceplam: :beer: :thumbup:
    buncha junk
    02-22-2012 11:50 PM #3
    funny, my fenders fit JUST like thats as well
    Crooked Euros | Low is NOT a lifestyle | Slow & Quiet
    WTB - 04.5 GLI REAR VALANCE
    Pennsylvania Volkswagen Owners & Enthusiasts Page
    O/R/T
    We Do It Big In PA
  4. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-23-2012 12:08 AM #4
    I think it's the fender and the core support combined. when you look at the fender vs. the hood it doesnt line up quite right but the grill looks off too
  5. 02-23-2012 10:31 AM #5
    cool car
    paint the lower grill strip and the lower valance red when you have the chance
    is the roof painted black?
  6. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-23-2012 11:38 AM #6
    Yes the PO painted it black for some reason A paint job is in her future but not for a while since as the title states, I'm a broke college kid haha
  7. Member 99VWJETTA's Avatar
    Feb 20th, 2002
    SW FL
    81 caddy 87 Golf 00 new beetle(vapor Blue) 02 jetta wagon 02 eurovan
    02-23-2012 08:34 PM #7
    Good start
  8. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-25-2012 01:30 PM #8
    Thanks
    So I cleaned the ISV and then decided to take a look at the TB which I found to have oil on it. Then I started pulling hoses and everything had a bit of oil on it all the way to the MAF. Found out that the PCV system was sucing in a little bit of oil. It also had a lot of condensation coming out of it. some of the oil was yellow/brown and there was some water that dripped out as I started pulling the PCV system apart. the tube that goes from the PCV to the MAF was clogged full of the yellow stuff There was also a nice little blob of the yellow oil on my air filter (which was trashed anyways).
    SO....
    Cleaned all the oil out, got a new filter, cleared all the PCV hoses, cleaned the MAF, sprayed carb cleaner into the Intake manifold and TB to clean it off.
    Result....
    Runs BETTER, but still has a small idle problem (dips down below 950 and the car vibrates a bit before the RPM's return to normal) and still have a problem when starting after the car has been warmed up. COld starts great, but if I drive to the store and come out to start it it gives me trouble, acts like it's missfiring a bit and tries to die unless I hold the RPMS up untill it is warmed up more.
    No pics sorry I wasn't thinking about it
  9. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    02-25-2012 02:01 PM #9
    did you ever think of painting the lower portions under the bumpers like an 87-88 GTI? it could be ddone really easily, and it would look really good in my opinion
    Like so -
    O/R/T
    We Do It Big In PA
  10. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-25-2012 05:01 PM #10
    I havn't put much thought into paint yet because I'm trying to get it running better but that could be a good way to get that lower section looking better without paying for a paint job. Thanks for the tip I'll keep it in mind
  11. 02-25-2012 06:34 PM #11
    Damn...you've got the front lip spoiler I want for my GTi race car.
  12. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-26-2012 12:41 AM #12
    Yeah I love that spoiler, It's seen it's better days but no biggy
  13. Member Hater GTI's Avatar
    Sep 14th, 2011
    Avondale, AZ
    Mk2 Jetta coupe, and many more in the past
    02-26-2012 03:53 AM #13
    Get some raclands " there cheap" a westmatlan front end and some bbs RA " there cheap" and call it a day 👍
  14. Member Hater GTI's Avatar
    Sep 14th, 2011
    Avondale, AZ
    02-26-2012 03:57 AM #14
    westmoreland****
  15. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-26-2012 11:39 PM #15
    It's Lowered on HKS struts right now and has a Eurosport strut brace in the front.
    Updates today...
    -ALMOST got a headliner, then found out it was trashed
    -Worked on the Body fittment up front. moved the fenders, core support, and hood around a little
    -Put the first coat of tint on my restored junkyard tails
    Pics soon
  16. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-28-2012 08:40 PM #16
    I know the grill is off but alignment is better, and the plastics got the heat gun treatment....
    Started waxing with Turtle Polishing compound, will finish next weekend as long as it's nice. New drip rails should also be going on this weekend
  17. Member gti3097's Avatar
    Feb 11th, 2005
    Ft Myers FLA
    90 jetta coupe, 03 20th AE #3097, 01 GTi
    02-28-2012 09:12 PM #17
    looks good
  18. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-28-2012 10:54 PM #18
    Quote Originally Posted by gti3097 View Post
    looks good
    Thanks man she's gettin there
    Forgot the interior pics. Has a couple of rips in the driver seat and missing a headliner but other than that it's just little things....
  19. Member jimothy cricket's Avatar
    Jul 9th, 2008
    NIU / CHI-TOWN
    Carb'd 16V
    02-29-2012 11:12 AM #19
    I'm in the same boat, college budget and what not.
  20. Junior Member jeffrw's Avatar
    Feb 10th, 2012
    near SLC Utah
    1998 Audi A6 Avant (Family mobile), 1989 Jetta GLI
    02-29-2012 11:21 AM #20
  21. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-29-2012 12:14 PM #21
    Check the DIY thread for drip rails. I bought it from JC whitney, $30 for 10ft vs. $100 per side sounds like a win to me.
  22. Junior Member jeffrw's Avatar
    Feb 10th, 2012
    near SLC Utah
    02-29-2012 01:02 PM #22
    I wonder if thats a part you could pick up and a local auto parts store. I'll find out.
  23. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-29-2012 01:41 PM #23
    Doesnt seem like it but It would save a lot of trouble if you could. Good luck
  24. Member Hater GTI's Avatar
    Sep 14th, 2011
    Avondale, AZ
    02-29-2012 03:38 PM #24
  25. Member itschrisb's Avatar
    Jun 7th, 2007
    Wilkes-Barre, Pa
    88 Jetta GLI
    02-29-2012 03:59 PM #25
    If I could find pictures from my old Jetta I replaced the drip rail with something similar to the JC Whitney stuff from a local auto part store I think I found it at autozone for under 10$ it worked wonderful.
    If you just go into the auto body paint section they usually have universal weather stripping in bags hanging up. Look at them and pick which one you think would work out best.
  26. Member Hater GTI's Avatar
    Sep 14th, 2011
    Avondale, AZ
    02-29-2012 04:04 PM #26
    [/QUOTE]
    This really don't look bad at all.
  27. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    02-29-2012 04:27 PM #27
    Quote Originally Posted by Hater GTI View Post
    Thanks It needs some love but it's a good start for sure! The seats need some love I may be buying some from the GF's dad soon, havn't decided yet. Leather buckets with the forward tilt and recline and on rails. Look sweet but idk yet
  28. Member
    Jun 5th, 2010
    NNJ
    '86 GTI, '89 Supra
    03-01-2012 02:42 AM #28
    automatic seatbelts?????????
    SWEET '85 though
  29. Member itschrisb's Avatar
    Jun 7th, 2007
    Wilkes-Barre, Pa
    88 Jetta GLI
    03-01-2012 08:17 AM #29
    http://www.autozone.com/autozone/acc...er=267100_0_0_
    thats what i used. It says $20 but i know ive seen similar things for much cheaper. That one worked out the best for me. hope this helps.
    PS i like the interior a lot!
  30. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    03-01-2012 10:59 AM #30
    Quote Originally Posted by avengerxix View Post
    SWEET '85 though
    I HATE the seat belts... they will be changed to 3 points sooner or later I just need to figure out how.They are unsafe and a PITA. they are not automatic though they just stay put
    Quote Originally Posted by itschrisb View Post
    Thanks! Already got my weather stripping but this might help out down the road. And other than the big rips in the driver seat and lack of headliner I love the interior too!
  31. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    03-05-2012 05:41 PM #31
    Updates from this weekend:
    -Lower Drip rails replaced (wind noise is much quieter now)
    -Chased a water leak, found that my vapor bariors were toast, patched them up
    -Went to the junk yard and found an 85 jetta which I robbed of it's 7 slat grill, pass. headlight, and 3 point seatbelts
    -Been sick for a week now
    -Drove another 300mile round trip with no major issues
    Pics as soon as I get done being sick
  32. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    03-07-2012 06:41 PM #32
    3rd post in a row, no shame...
    pics
  33. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    03-16-2012 10:47 PM #33
    Well finally got a bit of an update. It's spring break so hopefully I'll get lots of work done. Went to the yard today and picked up this headliner backing that's pretty beat up, but It'll work with some love. Did some more work to my DIY half tint tails. blah blah blah nobody's reading this anyways...
    after a few repairs with 5min epoxy, more to come, then some FG resin to finish it up before getting new fabric...
    Trim pieces that dont match, need to be painted black....
    Dome light works now .......but not the door sensors
    Roof is hopefully to be painted this week... Gloss black. and hopefully fix the sunroof seal to get rid of the tape
  34. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    03-21-2012 01:43 PM #34
    Thanks for the feedback guys
    Started painting the roof. Prepped to 400 grit, will get wet sanded at 600 before clear coat. More work on the headliner backing, 3 point seatbelt swap done, tail lights on (pics later), got some materials
    Felt strip to redo the sunroof gasket....
    Black Micro-suede for the headliner....
  35. Member MustangluvR1967's Avatar
    Feb 13th, 2012
    Bellingham, WA
    1985 Golf GTI
    03-27-2012 04:21 PM #35
    DOnt know why I'm still updating this, nobody seems to care
    Finished the roof and headliner, went out to take pics with a buddy....
