Originally Posted by
AFRich337
I just picked up a pair of 034's Audi 90 track-density strut mount bushings. I also got the barrel nuts to go with them. I was going to replace my compressed and worn stock bushings in my GTI with these shorter ones so I could raise my Bilstein coilovers to get a little more damper travel and hopefully have longer-lasting strut bushings with less play.
Compared to stock, are the Audi 90 bushings smaller in diameter at the top portion, and does the bushing have a smaller contact area? My concern is that with the harder material and reduced contact area mixed with high load may possibly force the mount through the strut tower opening.
If the diameter and contact area is the same, I won't be worried. I'm considering just exchanging these for the MkIV-specific track-density mounts instead just for the piece of mind.
