Page 2 of 2 FirstFirst 1 2
Results 36 to 68 of 68
Thread: Golf 7 Spy Shots
  1. Member XM_Rocks's Avatar
    Jan 29th, 2005
    Austin, TX
    '07 Mazda 3 Hatch and '10 Golf
    02-24-2012 08:30 AM #36
    Quote Originally Posted by wky View Post
    Hate how the car is getting bigger and bigger. VW, time bring over the UP or Polo.
    The GTI will be 250 - 300lbs less than the Mk6.
  2. Member Golf_kris's Avatar
    Dec 1st, 2001
    Norfolk, VA
    2001 Golf 1.8T, 2008 DBP .:R32, 2010 CW GTI
    02-24-2012 09:47 AM #37
    Quote Originally Posted by XM_Rocks View Post
    Jamie's article on the MQB says the platform will be 88-132 lbs lighter. Where is the extra weight loss coming from?
  3. Member blighty's Avatar
    Jan 18th, 2011
    Sarf Carolina via Yorkshire lad
    Candy White 1.8T dog hair transporter
    02-24-2012 09:59 AM #38
    Quote Originally Posted by Golf_kris View Post
    New welding techniques "around 150 pounds lighter than the Mk6 (which is essentially a slightly modified Mk5) thanks to molten-molded, extra high-strength steel used throughout the chassis, along with reworked suspension components, lightened engines and auxiliary bits. "
    http://autoecommerce.org/what-we-kno...-next-gen-gti/
    Free 3D Photogrammetry.
    AutoCAD123D Catch HERE
    Camaro SS
    1978 MkII 1.0 Polo/1983 MkI Golf Campaign Model (German import) MkII 1800 engine/1986 MkII 1100 GL/1998 MkIII Golf GTI 16v/2002 Mkiv Golf Wagon 1600/2000 Mkiv Golf 1.8T
  4. Member XM_Rocks's Avatar
    Jan 29th, 2005
    Austin, TX
    02-24-2012 10:46 AM #39
    I believe the 88-132 may be for Golf?
    I am quoting the below Top Gear Article.
    The extra weight savings over the current GTI is stated to be 220lbs due to aluminum roof.
    Ok I stretched a little on my 250-300lbs... I just need to loose a bit of weight.
    Top Gear MK7 Article
    Oct 21st, 2002
    Maryland
    2001/Rave Green GTi, 2000 New Beetle
    02-24-2012 11:06 AM #40
    MK6 was really a MK5 with cost cutting production.
    In reality this is the next gen from the MK5.
    I am excited if it is as described.
    230HP, 2850lbs, mechanical LSD.
    As long as they can keep the NVH at MK6 levels sign me up.
    My thoughts exactly. And it isn't really too soon because it will be a while before it makes it to the states after its release in Europe.
    Revo Stage2 | 4 Bar FPR | GHL Downpipe | Milltek Catback Exhaust | Forge 007 DV | Neuspeed P-Flo | Neuspeed Turbo Inlet Pipe | Neuspeed Short Shift Link | Eibach Pro Kits | Koni Sport Yellows | 25the AE body Kit | 25th AE Aluminum trim | BBS RCs
  6. Member Golf_kris's Avatar
    Dec 1st, 2001
    Norfolk, VA
    02-24-2012 11:39 AM #41
    Thanks for posting up the Top Gear article. Mk7 seems like a pretty exciting evolution of the Golf/GTi. I may just hold on to the R until then. Hopefully the Mk7 comes out with the a la carte options like the 2010 GTi instead of these stupid packages.
  7. Member UmbroVR6's Avatar
    May 23rd, 2000
    Miami, FL.
    98 GTI VR6, 01 Jetta 1.8T
    02-24-2012 11:46 AM #42
    i for the life of me cannot make an educated guess in my mind on how this will look.
    but that is one ugly mofo car with all that disguise
    LEASE THIS SPACE
  8. Member ronin1's Avatar
    Feb 5th, 2006
    Northern Virginia/DC Metro
    2008 CW R32 #3549, 2009 Precor EFX 576i (normally aspirated)
    02-24-2012 12:19 PM #43
    Yeah the camo disquise does a good job of what it's meant to do so honestly if you told me this was an MKVI I'd believe it.
    I'm sure the styling won't be drastically different than the current MKVI which to me is a good thing.
    So will the MKVII's actually be sold in 2013 or are we going to have to go through the usual waiting game of it coming out a year or two later, after they release it in Europe?
  9. 02-24-2012 12:34 PM #44
    looking at the front end, I see the corporate headlights, ala Passat. Maybe someone can photoshop a Passat front end on a Golf VI and then you get the Golf VII.
  10. Member
    Jan 23rd, 2004
    Lincolnton, NC
    2011 Golf TDI
    02-24-2012 12:55 PM #45
    Will it be available with that "Zebra" paint option...
  11. Member koston.'s Avatar
    Aug 20th, 2003
    Smell you laterville, Bellevue WA
    1996 VW GTI, 2005 Forester XT
    02-24-2012 02:50 PM #46
    No HIDS?
    2.0 for life, 224k miles (unless I'm in the 2.5xt)
    Saw the light, now rocking fender gap on RPF1s
  12. Member XM_Rocks's Avatar
    Jan 29th, 2005
    Austin, TX
    02-24-2012 03:51 PM #47
    Quote Originally Posted by koston. View Post
    No HIDS?
    That's pretty standard... its a test car.
    Even if this isnt a base Golf they probably didn't want to show any design cues from the headlights anyway.
    Projectors... LED's etc.
    Besides on the MK6 GTI and Golf TDI its an option so I would think the MK7 would be the same way.
  13. Member dankvwguy's Avatar
    Jul 23rd, 2005
    Dublin, GA
    07 BMP GTI
    02-24-2012 04:58 PM #48
    Quote Originally Posted by windhys View Post
    Im gonna weit for Golf 8
    THE CBOX KREW
    There's always time for a GI Joe orgy
  14. 02-24-2012 05:22 PM #49
    The longer wheel base gave the designers wings. The car apparently has a cab-forward design allowing a steeply sloped windshield which in return leads to lower roofline. Also, the cammo cannot hide the strong sholder lines. I like what I see.
    I am a VW Fan, but above all I am a Car Fan.
  15. 02-24-2012 05:35 PM #50
    I do not like the body of the mk V and mk VI compared to my Mk IV. The back of the hood is way too tall, making it look pudgy. The lights/front face on the Mk VI is better than the Mk V, however.
  16. Member FaithInMkIII2.0's Avatar
    Jul 10th, 2008
    Cape Cod
    '91 GTI TDI powered, '97 B4GLXTDI, Vitus 979, Schwinn Traveler Fixie
    02-25-2012 02:32 PM #51
    Quote Originally Posted by MeineFolks'wagen View Post
    My thoughts exactly - the MKVI are only about two or three years old right?? I can't afford a new VW anymore, so I haven't been keeping up with the new ones as much, but I didn't think they had been around long enough to do a remodel already.....
    THIS^ I care more about the older shyt
    Cost cutting eh? Ya makes me want to fork out the dough for all that plastic and electronic crap
    Can new golf haz Moar Plasticz?
    Kidding though, the new welding technique is intriguing!
    For VW diesel tuning, parts, and service check out SCHNELL SNAIL TDI PERFORMANCE yes, we do gassers too!
    static low friendly floor
  17. Semi-n00b JDub713's Avatar
    Feb 25th, 2012
    Los Angeles
    Audi A4 1.8TQM Motorcycle: Ducati Sport 1000
    02-25-2012 06:58 PM #52
    The GTI's gonna need more than 230hp to keep up power-wise with the other leading hatches. It should be in the 250-270hp range standard. I've driven the new Golf R and it's nice, but no quantum leap by any means. The car is superior to it's competitors in every other category. An 'R' model should be around 300hp+ by now. The MKIV's came out in the NAR in 2004 (holy sh*t, almost 10 years ago already), and even with a different power plant, they're only making +/- 10 more hp than that model. Come on Volkswagen, 'mo powa!
  18. Member XM_Rocks's Avatar
    Jan 29th, 2005
    Austin, TX
    02-25-2012 08:19 PM #53
    Quote Originally Posted by FaithInMkIII2.0 View Post
    Cost cutting eh? Ya makes me want to fork out the dough for all that plastic and electronic crap:
    Cost cutting for production.
    The MK5 was too expensive to build.
    The MK6 Golf was quieter, had a better interior and was cheaper to make than the MK5.
    My wife's MK6 golf was much nicer than my MK5 GTI.
    Here is a good video explaining.
    Here is another good mk5 vs mk6 vid.
  19. Member FlyBy's Avatar
    May 27th, 2004
    OH/NY
    2002 Jetta Wagon
    02-26-2012 07:09 AM #54
    Quote Originally Posted by KahviVW View Post
    With the MkVI looking as good as it does, I think it would be hard to mess up the MkVII.
    It can't be that hard, look at how Toyota keeps f-ing up the looks of the Camry.
  20. Member 87socorro's Avatar
    Oct 30th, 2011
    florida
    99 jetta 07 GLI >924s mk2gti
    02-26-2012 10:27 AM #55
    Word yo I need a jetta coupe in my life that thang is so sexy
  21. Member remedyz12965's Avatar
    Sep 30th, 2007
    Central IL
    2002 Volkswagen Jetta 1.8T
    02-26-2012 01:00 PM #56
    The jetta coupe would destroy all other models in sales
    Quote Originally Posted by gxblade View Post
    I think you actually have to show a full nipple.
    Doors for sale! MKIV Jetta!
  22. 03-01-2012 12:19 AM #57
    From the "What we know about the 2013 Volkswagen Golf, next-gen GTI" at the AutoECommerce story: http://autoecommerce.org/what-we-kno...-next-gen-gti/
    Because of the new manufacturing and material processes, parts costs will be cut by around 20 percent and manufacturing costs will be reduced by one-third, meaning the next Golf should be less expensive than the current model, while packing even more content, providing more power and even better handling. Sell that alongside the current GTI and people will ask, “Why upgrade?” We wouldn’t either, but then again, we’d wait for the next GTI anyway, or maybe that oil-burning GTD…
  23. Member quailallstar's Avatar
    Dec 2nd, 2001
    Aus Liebe zum Automobil
    @LuvGermanCars
    03-01-2012 09:19 AM #58
    Quote Originally Posted by narcoossee View Post
    I pray the GTD makes it to the US this time around Volvo got me all hot and bothered with the new V40 debut, but it's NOT coming to the USA (yet).
    2Ø11 Candy-Weiß Golf 6 2,0 6-Gang DPF TDI BLUEMOTION Technologies™ Highline 4-Türen ▀ 2Ø11 Tornadorot Jetta 6 2,5 Highline 4-TürenØ8 Deep Blau Perleffekt Golf 5 .:R32 3,2 DSG 4-MOTION™ 3-Türen ▀ Ø8 Tornadorot Passat 3C Variant Highline 2,0 TFSIØ6 Tornadorot Golf 5 GTI 2,0 DSG TFSI 3-TürenØ2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen
  24. Member XM_Rocks's Avatar
    Jan 29th, 2005
    Austin, TX
    03-01-2012 10:45 AM #59
    Quote Originally Posted by quailallstar View Post
    VW sells 500,000 Golfs a year in Europe.
    If we had those numbers here we would be getting one.
    We are going to start realizing that China and India will start getting the good stuff... US is no longer an emerging market.
  25. 03-05-2012 12:09 AM #60
    Been off the vortex for quite a while, could this be the next Golf 7?
    http://www.wheels.ca/columns/article/805362
    Apologies if this is an old rendering, I only saw it today. :I
  26. Member XM_Rocks's Avatar
    Jan 29th, 2005
    Austin, TX
    03-05-2012 08:14 AM #61
    That looks like an Alfa or a Honda Civic.
    No way would that be the Golf.
    No corporate styling cues and too edgy and drastic for VW design.
  27. 03-05-2012 08:18 AM #62
    I do remember seeing that awhile back in one of the mags, and at the time, it was attributed to VW.
  28. Member XM_Rocks's Avatar
    Jan 29th, 2005
    Austin, TX
    03-05-2012 08:31 AM #63
    Quote Originally Posted by jhanna1701 View Post
    Maybe some Scirocco concept?
    Personally I hope it stays as a concept.... its ugly imo.
  29. 03-05-2012 08:50 AM #64
    No, it was the golf. Not saying that's what the new golf will be, just what the article said. If I remember correctly, it was about the time when VW took over ItalDesign. Might just be a "study".
  30. 03-05-2012 09:56 AM #65
    Agree with you, I found it quite hideous. If that's even close to the final, I'm getting the R32 MK6 and call it a day
  31. 03-05-2012 07:15 PM #66
    You can rest assured that that sketch is not accurate. I see several things straight away that are either inconsistent with the spy shots and/or would never make it to a practical production vehicle.
  32. 05-07-2012 02:41 PM #67
    ^ Looks more like a Ford Fiesta than anything.
    I'm not sure what to think about the spy shots. Doesn't look bad, but I'm scared that they will get rid of the rounded headlights and create something similar to those awful renderings of the car.
    Also I'm disappointed that they didn't get rid of the shoulder line. The c-pillar looked so much better without it, and it's what gave the MK2 and MK4 such a solid German look.
  33. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    93' SLC VR6 90' G60 99' Jetta
    05-07-2012 04:20 PM #68
    Quote Originally Posted by DaWolfsburg View Post
    lower it.
    Lol Moar low!
    [B] INSTAGRAM: europeein
    Facebook: facebook.com/addmichael
