Page 1 of 12 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 410
Thread: Euro R springs
    Sep 28th, 2011
    Texas
    Rising Blue Golf R
    02-23-2012 04:52 PM #1
    One of the things I like best about the R is the suspension's balance between comfortable ride and handling performance. VW really nailed it, and the stock suspension makes for a great daily driver. That being the case, I've been extremely resistant to the idea of modifying my suspension in any way.
    On the other hand, we're all very well aware of how much wheel gap the stock US-spec R has. We all have different ideas as to what the optimal ride height is aesthetically, and I really don't want to restart the beating of that dead horse in this thread, but I think most of us would agree that the stock ride height is not it.
    So, I've been going back and forth in my mind as to what I want to do, and I keep coming back to the idea of swapping the springs out for ROW-spec R springs. Given that several sources have stated that the only difference between NA-spec and ROW-spec suspension components are the springs, I keep thinking that this should noticeably improve the aesthetics without significantly impacting the suspension performance. It also would be in keeping with my general M.O. for modding, which has been to stick with OEM for everything other than my wheels and APR goodies. Unfortunately, no one appears to have done this mod yet, so there's no information available. I decided to research this further.
    First, I wanted to confirm what I could expect in terms of a change in ride height. Everything I've read indicates that the NA-spec R sits approximately 1 cm higher than the ROW-spec R, but I wanted to confirm this. I found a post from an Aussie who measured his R with OEM standard (non-ACC) suspension and 18" wheels. With a full gas tank and on level ground, he measured the distance between the bottom lip of the wheel to the edge of the wheel arch at its highest point and got 605 mm for the front and 610 mm for the rear. I did the same measurements under the same conditions and got 614 mm for the front and 619 mm for the rear. Accounting for measurement error, this appears to confirm that the ride height is approximately 1 cm different.
    This should be just what I'm looking for aesthetically. I will be replacing the stock 18" wheels and 225/40 tires with 19" wheels and 235/35 tires, which will close the wheel gap by approximately 5 mm. The diameter of the stock wheels/tires is 637 mm, and the diameter of the new wheels/tires is 647 mm. Half of that 10 mm difference will be below the hub and won't affect the wheel gap. Thus, the ROW-spec R springs together with the new wheels/tires should close wheel gap by a combined 1.5 cm (0.6"), which will be a noticeable improvement.
    Second, I wanted to confirm that the ROW-spec springs would not cause any rubbing or fitment issues. I found posts from numerous ROW owners running 19x8.5" wheels with 235/35 tires on stock and mildly lowered suspensions with no issues (even with more aggressive offsets than I will be running). This chart here also confirms that fitment should not be an issue.
    Third, I wanted to determine whether switching to this setup would create too harsh of a ride. Obviously, this is one of those things that you really can't know until you try it for yourself, but I read numerous comments and reviews of ROW owners riding on 19" wheels and the standard suspension, and they were almost unanimously favorable. I'll provide a detailed comparison of my own.
    I'd also like to know: (1) what the spring rates are on both the ROW-spec and US-spec springs; (2) whether the bump stops are different on the two versions and, if so, how (I noticed that the ROW-spring kit that OEMplus sells includes bump stops); and (3) what the suspension travel distance is on both setups. If anyone has this information, please post it here.
    I decided to be the guinnea pig on this mod, and ordered the ROW-spec R spring kit from OEMplus, which is available here. It's on backorder, so I'll have to wait a few weeks before they come in. The price is a little steep ($595), so if you're looking for the best bang for the buck in terms of lowering, this is not it.
    I will take measurements and pics of everything before and after and thoroughly document everything, along with my driving impressions.
    2012 Rising Blue Golf R (Build Thread)
    2012 Night Blue Tiguan SEL w/ Premium Nav
  2. Member autofi's Avatar
    Nov 24th, 2011
    NY
    urquattro,Golf R,4000q,EvoIX
    02-23-2012 05:16 PM #2
    The front and rear bumpstops are the same for all markets so no need to order those.
  3. Member MonkeyMagic!'s Avatar
    Dec 1st, 2011
    NJ
    2012 Golf R (On Order)
    02-23-2012 05:19 PM #3
    Very interested in this thread, thank you for being the first to take the plunge!
  4. Member
    Sep 28th, 2011
    Texas
    Rising Blue Golf R
    02-23-2012 05:46 PM #4
    Quote Originally Posted by autofi View Post
    Thanks for the confirmation. I suspected that OEMplus simply included them for owners of other Golf variants who want to use the R springs.
  5. Member GRB's Avatar
    Aug 24th, 2003
    Miami, FL
    2012 Golf R 2-Door
    02-23-2012 06:07 PM #5
    I've been debating this myself. TLud and I have the same modding philosophy.
    I'm not sure whether to bite the bullet and get OEM Euro springs and call it day (since the dampers are the same), or upgrade to H&R sport springs with Bilstein sport shocks. This setup would also cure the wheel gap (perhaps just slightly lower than the Euro springs), but also provide more agressive damping.
    I've been holding out so as not be a guinea pig.
  6. Member DaLeadBull's Avatar
    Feb 14th, 2011
    Whitehall, PA
    2012 RB Golf R
    02-23-2012 06:42 PM #6
    TLud, we have the same philosophy my friend. My only performance mods will be wheels/tires and APR software.
    I thought about the euro springs too but at close to 600 bucks, I don't think its worth it. If you have a Golf or a GTI, then it may be worth it. But 600 bucks for 1cm lowering is a little much. But I'm looking forward to see some before and after pics.
    I'm just going to upgrade to 19's which like you said reduce the wheel gap a little and call it a day. Plus I'll keep the 18's for winter when the wheel gap is actually beneficial.
  7. 02-23-2012 06:46 PM #7
    I look forward to seeing how this turns out. This is the only suspension route I am considering.
  8. 02-23-2012 07:10 PM #8
    Is it definite that the ROW cars have the same struts? If so this is a no brainer. Can someone confirm with pictures of part numbers?
  9. 02-23-2012 08:17 PM #9
    I went this same route with my 04 R32.
    I ordered the oem euro springs and the stated drop was similar. 3/8".
    you really won't notice much of anything. ride and handling will be similar.
    and by eye, you probably won't really see any height difference.
    but Im in to see what this looks like.
  10. Member
    Oct 23rd, 2006
    2012 Golf R
    02-23-2012 09:07 PM #10
    Has anyone confirmed spring rates yet? Without knowing those you're just guessing. Aren't the euro springs mated to electronic dampers as well?
  11. Member johannes's Avatar
    Oct 25th, 2004
    Plymouth, MI
    2012 Golf R
    02-23-2012 09:38 PM #11
    Quote Originally Posted by webcrawlr View Post
    TLUD is doing much the opposite of guessing. He is paying a premium to place the springs VW Engineers chose to use for the for the standard sport suspension ROW Golf R Should be a very subtle aesthetic and possibly also a very small performance improvement
    Sep 28th, 2011
    Texas
    Rising Blue Golf R
    02-23-2012 09:45 PM #12
    Quote Originally Posted by UncannySkill View Post
    I'm your huckleberry.
    Hopefully I can give you the information you need to evaluate one of your options. It would be awesome if others in Houston or the central Texas area with different aftermarket suspension setups could meet up and we could do back-to-back comparisons and post our impressions.
    Unfortunately, these springs are backordered at OEMplus, so it will probably be the second half of March before I get them on my car.
    Quote Originally Posted by DaLeadBull View Post
    I hear ya. Like I said in my initial post, this certainly isn't the best bang for the buck. It's really for those who are willing to pay a little extra to fine tune and get exactly what they want. I'm not thinking about the $/cm drop value; I'm thinking about this from the larger perspective of the theme of my R build.
    Quote Originally Posted by Yunque05 View Post
    Having talked to a few R owners and having read a lot on the 'tex, I figured there were at least a few others who, like me, were interested in this option, but were waiting for someone to take the plunge. I don't mind being that guy.
    Quote Originally Posted by slackin' at work View Post
    Big thanks for your input. It's nice to hear you confirm that, at least with an earlier model, there weren't drastic changes to the ride and handling feel. I agree that there also won't be a real noticeable drop. While not obvious, I've been checking out a lot of pics of Euro Rs, and they do look significantly better even though the drop is so small.
  13. Member ook's Avatar
    Apr 30th, 2004
    Texas
    Hillarious old 1998 Jetta, 2002 GTI, MKIV R32, 2005 Jetta, 2012 Golf R!
    02-23-2012 09:48 PM #13
    I'm in the exact same boat looking at going to 19s and the Euro springs. Thanks for taking the plunge TLug!
    Subscribed!
    - ook
  14. Member
    May 23rd, 2011
    Montreal
    02-23-2012 10:21 PM #14
    Thanks TLud! You are "the Lone Star" I will be watching with great interest
  15. 02-23-2012 10:42 PM #15
    Tlud, on behalf of the rest of us Texans, bless you and good luck.. We are all counting on you.
    (mine's here now too, so I can legit say that)
    Lurking Vortex Since '99
    Former: '00 VR6 GTI/'04 MKIV R32/'07 Audi RS4
    Current: Only owner of 1980 CJ7, 07 Range Rover Supercharged
    Now Showing: Golf R - White (now w/ "accessories")
  16. Member
    Sep 28th, 2011
    Texas
    Rising Blue Golf R
    02-23-2012 10:55 PM #16
    Thanks for the encouragement. I've been following scottgpt88's thread here describing his new H&R sport springs. He's not too far from me, and I think it would be really helpful for people to see a side-by-side visual comparison and to hear our impressions on their relative ride and handling characteristics.
    Hitman, congrats on the new R. How do you like her so far?
  17. Member brakedust's Avatar
    Dec 6th, 2004
    Midwest
    Golf
    02-23-2012 11:00 PM #17
    Hmmm I was debating about this myself ... I'd like to see the differences for sure and that is the exact same wheel setup I was going with myself ...
    Keep up the good work and post plenty of pics
    Previous: '95 Eagle Talon TSI AWD 2.0T | '98 GTI 2.0 | '00 Jetta 2.0 | '02 GLI 2.8 | '07 GTI 2.0T | '09 GLI 2.0T | '00 A4 2.8 | '04 R32 3.2 | '12 R 2.0T
    FS: (1) VMR 718 19x8.5 Wheel - $100 shipped
    Quote Originally Posted by Chmeeee View Post
    Has anyone really been far even as decided to use even go want to look more like?
  18. 02-24-2012 07:23 AM #18
    Quote Originally Posted by TLud View Post
    Just picked her up last night. I need a couple of weeks to really give a fair assessment. Coming from a MKiv R32 and then RS4, the differences between instant torque of bigger engines and a turbo 2.0 are something I have to get used to. The car is beautiful, and really the most practical marriage of all the things I want in a daily driver. (something the RS4, was most definitely not).
    I'm really into watching what you and others do with suspension because the wheel gap is pretty gaping, but I know the OEM setup is prime. On my '04 R32 I did the swap to the OEM Euro suspension and it made such an outstanding difference in the car. It really transformed it. I suspect that the R's US setup isn't as bad a difference from ROW in terms of performance compared to the MKiv's differences, but in that case I did the whole deal, not just the springs.
    I personally would love to see your car not just for that mod, but the others you've done as well. All things I would consider or already want to do.... (RVC!!!)
  19. Member Tailwagger's Avatar
    Nov 30th, 2008
    Boston, MA
    2012 R 2dr Base CW 3/27/12
    02-24-2012 07:46 AM #19
    Here's one advantage of not yet having a car. Get to have others fumble about finding the best solution.
    So does anyone know if the stock springs are fixed rate or progressive? And would it not potentially, depending on the answer, be cheaper to find a good race shop and simply cut the stock springs down?
    Regardless, for ascension to forum God status, if you're not doing the install yourself, perhaps there is a race shop in your area with a spring dyno that would be willing as a part of the changeover to measure the two sets of springs for a quick comparison. That would get you the rates and end the speculation once and for all.
    2012 R CW 2DR
    2011 F150 SCrew 5.0
    2009 WRX
    2000 911 C2 Aero Brumos Special Edition 'B59'
    1970/73 911 RSR residing within a 2011 ATC 24 ft VNose
  20. Member SHO'NUFF's Avatar
    May 12th, 2006
    Calgs
    '12 Golf R
    02-24-2012 10:36 AM #20
    '83 GTi (gone) | '90 Corrado (gone) | '96 GTi VR6 (gone) | '08 GTi (gone) | '12 R
  21. Member Siliconrane's Avatar
    May 19th, 2009
    Camp Bullis, TX (San Antonio)
    2012 Golf R - Black
    02-24-2012 10:44 AM #21
    I will be keeping an eye on this thread as suspension balance is extremely important to me. If the Euro springs give enough benefit, I will easily take the plunge and get a set. Good Luck my Friend.
    2012 Golf R - Black WETDUB
    HPA Softwares, APR HPFP, Scorpion TBE, Forge Twintake, HPA Mount, APR Flap Delete, Dieselgeek SS, RNS-510, 9w7 Bluetooth, JL 10w6 W/ Stealthbox, JL XD600/1, JL Cleansweep, P3cars.com Boost Gauge, Backup Cam, Color Matched Side Markers w/ bulb delete, LED Everything.
    (Build Thread)
  22. Member
    Sep 28th, 2011
    Texas
    Rising Blue Golf R
    02-24-2012 11:54 AM #22
    Quote Originally Posted by Hitman View Post
    We'll definitely have to meet up. I'm up in DFW fairly frequently (2 of my brothers live up there). When I first got the R, I too was initially a little underwhelmed by the power, having come from a much faster car with the grunt of a V8. Less than 500 miles later, I had my R flashed with APR's stage 1 tune, and I became a very happy man. Although I'll be going at least Stage 1+, I'd be completely content to keep my car as is.
    Quote Originally Posted by Tailwagger View Post
    Great call about getting the spring rates analyzed. I know just the place. Draco, the largest custom spring manufacturer in the world is right here in Houston, and I'm sure they can help me out.
    Quote Originally Posted by Siliconrane View Post
    Lol. You'll probably hear the results straight from me before I even post them up here.
  23. Member autofi's Avatar
    Nov 24th, 2011
    NY
    02-24-2012 01:02 PM #23
    The difference in spring rates euro versus usa is ~ front 45lbs. lighter for euro and rear ~ 85 lbs. lighter for euro.This explains the ride height difference euro versus usa!
  24. 02-24-2012 01:38 PM #24
    Very interesting..
  25. Member 20VConvBug's Avatar
    Jan 16th, 2004
    Sharon, MA
    '97 Jetta GLX, '12 R, '03 New Beetle Convertible 1.8T Big Turbo, '96 911 Cabriolet, '95 BMW 530i
    02-24-2012 01:41 PM #25
    You read my mind! I want to do the same thing when I get my R. I have ROW springs in my 911 and Bilstein HD coilovers (911s have been coming with coilovers from the factory for a while for corner balancing) and I noticed a nice drop although it is not slammed. On the other hand, I didn't want to do coilovers on the R like I did on my Bug because the ride is so harsh (pss9's), so I was thinking that ROW springs would be a good compromise.
  26. Member
    Sep 28th, 2011
    Texas
    Rising Blue Golf R
    02-24-2012 02:00 PM #26
    autofi, you have supplied some very helpful information in this thread and elsewhere on the forum. Thank you for your contributions. If you know the differential in spring rates between the Euro and US springs, does that mean you also know the actual rates for both? If so, that would be extremely helpful to have. Also, do you know whether they are linear or progressive?
    Quote Originally Posted by 20VConvBug View Post
    You and I are thinking alike.
  27. Member Tailwagger's Avatar
    Nov 30th, 2008
    Boston, MA
    02-24-2012 02:19 PM #27
    Interesting. Just curious, do you happen to know if the spring rates the same for conventional versus mag shock equipped cars?
    2012 R CW 2DR
    2011 F150 SCrew 5.0
    2009 WRX
  28. Member autofi's Avatar
    Nov 24th, 2011
    NY
    02-24-2012 03:08 PM #28
    The only info I have are axle load numbers that VW gives out for each spring.As TechEd had confirmed the US springs have a higher spring load.I do not have actual spring rate measured off the car yet!
  29. Member
    Oct 23rd, 2006
    2012 Golf R
    02-24-2012 03:27 PM #29
    So switching to the euros will get you a softer ride along with the drop...
  30. Member
    Sep 28th, 2011
    Texas
    Rising Blue Golf R
    02-24-2012 03:54 PM #30
    Based on autofi's information and assuming they are both linear springs.
  31. Member autofi's Avatar
    Nov 24th, 2011
    NY
    02-24-2012 03:55 PM #31
    Taking into consideration MKV euro springs which I used on '07 Gti the coil was wound differently however the ride was the same.The big difference was the turn in,set time in the rear was direct with no delay and the ride height was also dropped 10 mm compared to US spec.
  32. Member autofi's Avatar
    Nov 24th, 2011
    NY
    02-24-2012 03:59 PM #32
    The R in my mind went one step further in tuning the springs.As TLud explained the chassis is good right out of the box and I too am trying to avoid the euro spring but would be the only way to go.But those 10 mm sure make it look right!
  33. Member
    Oct 23rd, 2006
    2012 Golf R
    02-24-2012 04:02 PM #33
    If they tested axle load I don't think it'd make a difference if it was progressive or not.
  34. Member Siliconrane's Avatar
    May 19th, 2009
    2012 Golf R - Black
    02-24-2012 04:04 PM #34
    If the springs are the same for the Mag Car and they would have to be softer, it would make sense in a way. VW would have to set the spring rate to the softer of the 2 programs so that the car would have the smoother ride with the Mag setup in Soft mode. In Sport mode, the Mag Shock would have to compensate to give it the stiffer ride. Makes sense in my mind at least - Please correct me if I am wrong.
    (Build Thread)
  35. Member
    Sep 28th, 2011
    Texas
    Rising Blue Golf R
    02-24-2012 04:34 PM #35
    Yes, but that's different than "ride softness," which I guess I misunderstood what you meant.
    Also, I gave some more thought to the numbers that autofi posted. Based on that, and all other things in the suspension being equal (as we've been told they are), won't the Euro R have less roll resistance on the rear axle relative to the roll resistance on the front as compared to the US R? And wouldn't that result in more understeer on the Euro setup?
