Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 71 to 105 of 159
Thread: Sidemarkers !
    Feb 3rd, 2003
    Austin, TX
    '12 VW Golf R, CW base
    03-03-2012 01:41 PM #71
    Quote Originally Posted by Dutchmastr9 View Post
    and this is why i bought oem ones to be color matched
    Unfortunately I don't want mine color matched, I wanted clear, but at this rate, I'll stick with the oem amber ones.
    I'll see and report back what I hear from ECS, hopefully they will handle this professionally.
  2. Semi-n00b
    Dec 21st, 2011
    Maryland
    08 Ranger XLT, 12 Golf R
    03-03-2012 01:49 PM #72
    I also have quality and fitment issues with the ECS smoked side markers. And have actually had issues on both my first and second shipment. In all fairness, ECS has worked with me up to this point, but I did want to make people aware of the issues I have.
    In the first set, the right (passenger) lens was scratched:
    ECS immediately sent a replacement set, but the second left (driver) lens had foreign material embedded in it:
    So between the two sets, I ended up with one left and one right sidemarker that are cosmetically good. However, neither has very good fitment in comparison to the OEM parts.
    The left one sits pronounced and only loosely snaps in place:
    The right one is pronounced on the front lower corner but does snap more securely in place:
    And I also wanted to point out that the statement on ECS' webpage, "ECS light housings are ultrasonically welded to seal them tight", is misleading and/or inaccurate. Of the 4 pieces I received, none of them were air tight (simply blowing into the light bulb opening to test).
    At this point I am leery to try a third set from ECS. APTuning is working on fitment issues with theirs. So far I have only seen positive comments about the ones from OEMPlus (johannes post #25):
    http://forums.vwvortex.com/showthrea...r-Side-Markers
  3. 03-03-2012 02:14 PM #73
    My clear ones do not fit perfectly either - especially around at the front corners. Not as bad as some people posted - no wobble or anything, but they are not perfectly flush like the OEM amber ones.
    When I've purchased smoked or clear Hella and Valeo markers in the past, the fit has always been perfect. Perhaps an OEM manufacturer will offer these for the Golf R - I would guess the ECS ones are fab'd in Asia by an aftermarket company.
    I'm hoping ECS might have gotten a bad batch and can replace these with ones whose fitments is closer to stock.
    If these are as good as the aftermarket ones get, I may consider getting stock ones color matched instead.
  4. Member usurpers26's Avatar
    Sep 23rd, 2011
    CT
    2012 Golf R
    03-03-2012 02:49 PM #74
    Bahhhh...I thought the "scratches and embedded debris" look was because mine were still wrapped. Took them out and sure enough, same thing. Also have a small chunk missing around the edge of the left one
    I sent ECS an email to begin the RMA process...
    Looks like OEM is the only way to go. Guess I'll go color matched or maybe try the laminix route.
    Quote Originally Posted by Greg_VIR View Post
    2012 Rising Blue Golf R
    APR Stage 3 - RSC - HPFP - IC - RFD / DXD-3E / BSH PCV
  5. Member SCHWAB0's Avatar
    Dec 6th, 2004
    Midwest
    Golf
    03-03-2012 03:45 PM #75
    I ordered a set of clears, just got them yesterday, I will go and install them right now ... I'll take pictures
    Previous: '95 Eagle Talon TSI AWD 2.0T | '98 GTI 2.0 | '00 Jetta 2.0 | '02 GLI 2.8 | '07 GTI 2.0T | '09 GLI 2.0T | '00 A4 2.8 | '04 R32 3.2 | '12 R 2.0T
    FS: (1) VMR 718 19x8.5 Wheel - $100 shipped
    Quote Originally Posted by Chmeeee View Post
    Has anyone really been far even as decided to use even go want to look more like?
  6. Member CALICSGR's Avatar
    Jan 24th, 2012
    Bay Area, CA
    2012 Golf R 4 door CSG
    03-03-2012 03:59 PM #76
    Just got mine but haven't opened them. Guess I'll be sending them back.
  7. Member SCHWAB0's Avatar
    Dec 6th, 2004
    Midwest
    Golf
    03-03-2012 04:22 PM #77
    well I just installed mine and it's not 100%, maybe like 95-99% fit ...
    Left side:
    http://www.youtube.com/watch?v=2RQKbDJQ3FM
    Right side:
    http://www.youtube.com/watch?v=eJcNQQ_HmvI
    Front view:
    http://www.youtube.com/watch?v=5wCkTlJ4Jfk
    I think for myself, they fit great ... it's not 100%, but it's good enough if you look at the close up video.
  8. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    03-05-2012 01:31 PM #78
    All of the side markers we have tested with no issues. This could be variations in bumpers.
    Please anyone with issues please contact:
    customerservice@ecstuning.com
  9. Member Bakerrrr's Avatar
    Aug 14th, 2008
    Maryland
    MkIV Jetta, MkVI Golf R
    03-05-2012 02:48 PM #79
    How are these coming out -_- I only looked quickly, but I don't have the little access panel in the fender well. Do I have to pull the liner back to get to them?
    United Motorsport Tuned Golf R || 42 Draft Designs
    Flickr || Bookface || Instagram@Bakerrbakerr
    lol, sup?
  10. Member Dutchmastr9's Avatar
    Sep 13th, 2004
    Boston
    2 Door bugatti coupe...er, i mean Golf Racecar
    03-05-2012 02:52 PM #80
    Quote Originally Posted by Bakerrrr View Post
    you need to pull out a couple of screws in the fender liner, then pull the liner back so you can reach in and grab the lights
    You Aint About That Life | ETYolo
    Ruined Blue Golf | 42 Draft Designs
  11. Member Bakerrrr's Avatar
    Aug 14th, 2008
    Maryland
    03-05-2012 03:00 PM #81
    Ah. I'll do that when I get it back I suppose.
    lol, sup?
    Sep 29th, 2000
    Chicago
    2012 R CW 4Dr
    03-05-2012 03:40 PM #82
    Quote Originally Posted by ECS Tuning View Post
    All emails sent to the above address bounce back undelivered.
    I tried, Gmail, hotmail and my Corp email...
    -Peter
    // OEM Recaros // RNS-510 // RVC // RLS // OPS // OEM Auto-Dimming Auto-Folding Exterior Mirrors // OEM Homelink // OEM LED Tails // OEM Golf R Black Headlights // OEM Door puddle lights // OKADA Plasma Coils // APR Stage 3 // 034M Catch Can
    RNS-510 Guru // VWNavi.com // Instagram: PeterDNA
  13. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    03-05-2012 03:43 PM #83
    Quote Originally Posted by Peteski View Post
    -Peter
    Sorry about that, one extra g got typed in
  14. Member usurpers26's Avatar
    Sep 23rd, 2011
    CT
    2012 Golf R
    03-05-2012 03:43 PM #84
    I am guessing their email domain is ecstuning.com and not ecstunging.com
    -Peter
  15. Member CALICSGR's Avatar
    Jan 24th, 2012
    Bay Area, CA
    03-05-2012 03:43 PM #85
    -Peter
    The package my markers were shipped in say they are for a MKV golf. Do we know the MKV and MKVI are the same?
    Either way, it's disconcerting that so many people are having issues.
  16. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    03-05-2012 03:56 PM #86
    Quote Originally Posted by CALICSGR View Post
    MKV models and the Golf R do take the same side markers.
    Anyone dissatisfied please PM me or sent an email and we will get you taken care of!
    Andy
  17. Member VWPDX's Avatar
    Jul 7th, 2011
    Portland, OR
    2012 Golf R (2012-) 1997 GTI-VR6 (1998-2007)
    03-05-2012 04:17 PM #87
    I ordered the ECS tuning lights and installed them this weekend. The bond between the reflector and the base is not perfectly uniform. This appears to be the primary cause of the uneven nature of the installs we have been seeing. Unfortunatley, I didn't take pictures before the install. The base however snaps in tight and is perfectly secure. My left is slightly more noticeable though both sides don't seat as flush as the stock reflector. With my CSG car, the smoked signals blend in very well though. On the magged picture, you can tell the lower edge has a little lip. Again the left side is a little more noticeable, but it's more of the same. Overall I don't think it is noticeable enough to worry about. If I had a different color combo though, I might not be satisfied.
  18. Member
    Feb 3rd, 2003
    Austin, TX
    03-05-2012 08:47 PM #88
    Andy
    I emailed at 10AM CST on 3/3/2012 and still haven't gotten anything but an automated reply. How long do you all take to respond to an email?
  19. 03-05-2012 09:16 PM #89
    Andy
    Perfect... GTI MKV and 12 GOlf R uses the same side markers ??
  20. Member SCHWAB0's Avatar
    Dec 6th, 2004
    Midwest
    Golf
    03-05-2012 09:42 PM #90
    similar part numbers but not the same ... I don't know why OEMplus sidemarkers fit better .. but I'd hit them up with info. I would have ordered another set from OEMplus, but their ridiculous shipping charge of $16 for a $45 item, makes it
    $45 shipped from ECS and fit is 95% ... I'd say good enough ..
  21. Member groverone's Avatar
    Feb 27th, 2002
    West Side
    Black A4 B8 2.0T manual
    03-06-2012 02:43 AM #91
    Quote Originally Posted by VWPDX View Post
    Please tell me they didn't drill your bumper for the plate holder... Or you asked them too...
    I like people, just ask my cats!
  22. Member VWPDX's Avatar
    Jul 7th, 2011
    Portland, OR
    03-06-2012 09:11 AM #92
    Quote Originally Posted by groverone View Post
    They did drill my bumper. I didn't ask them to and I didn't ask them not to.
    Sent from my DROIDX using Tapatalk
  23. Member groverone's Avatar
    Feb 27th, 2002
    West Side
    03-06-2012 07:48 PM #93
    As long as you don't care, that is what matters! Car looks great by the way!
  24. Member CALICSGR's Avatar
    Jan 24th, 2012
    Bay Area, CA
    03-06-2012 08:07 PM #94
    Thanks for posting. I have a CSG and I'm really looking forward to installing some sidemarkers. That said, I won't install the ones from ECS because that fitment is just not acceptable. Everything else I've gotten from ECS has been fine, but then again they were just marked up OEM parts so there's no reason they shouldn't be fine.
  25. 03-06-2012 09:39 PM #95
    Has anyone just smoked the stock ones?Since no one can seem to find smoked one they are happy with.
  26. Member
    Sep 4th, 2011
    North Bethesda, MD USA
    2000 VW Golf (Sold) | 2002 VW GTI (Sold) | 2007 VW GTI (traded) | 2012 VW Golf R
    03-06-2012 09:55 PM #96
    Quote Originally Posted by retired View Post
    Or how about Lamin-X?
    http://www.lamin-x.com/VW-Golf-R-10-...-p/vw427-1.htm
  27. Member GenMan's Avatar
    Oct 31st, 2010
    Grandville MI
    2012 Golf .:R 2DR CGM MK4 Jetta TDI RC3 T4 nozzles
    03-06-2012 09:55 PM #97
    Never used it but thinking of giving it a shot. I have a spare set of OEM ones to try it on.
    http://www.vhtpaint.com/products/niteshades/
  28. n00b
    Feb 27th, 2012
    2012 Golf R CSG Base
    03-07-2012 12:07 PM #98
    I put them on last night. The quality was fine (no scratches, no imperfections) but the fit is not great. The color is better than the straight yellow but if I had to do it over again I'd wait until someone offers a better fitting version, and I'd go clear or color-matched.
    And yeah yeah I know, she needs a bath.
  29. Member
    Oct 24th, 2011
    Boston, MA
    2012 Golf R ; '11 Xterra Pro-4x
    03-07-2012 02:11 PM #99
    Quote Originally Posted by JosephHatfield View Post
    I Lamin-X'd the stock markers last month. Works fine for me and kept that OEM fit. Cost like $7.
    There is the slight ring of orange around the edge, but I am pretty sure I could prevent it next time by not being as aggressive with the razor-blade when trimming excess.
    B.
  30. Member CALICSGR's Avatar
    Jan 24th, 2012
    Bay Area, CA
    03-07-2012 02:32 PM #100
    Quote Originally Posted by OaktownDad View Post
    No offense, but those look really bad. The color is tinged, and the fit is totally off. I'm trying to send my unopened set back to ECS, but they still haven't replied to my customer service inquiry. I ordered a set from OEM Plus, since I've heard better things about their product. If those suck too, I'm just going to run them until I can get the OEM orange markers color matched.
    Why did VW even put these ugly markers on our cars? Ugh.
    BTW, does anybody have a picture of the smoked sidemarkers with the lights on? Thanks.
  31. Member Dutchmastr9's Avatar
    Sep 13th, 2004
    Boston
    03-07-2012 02:46 PM #101
    because the US government requires amber sidemarkers
  32. Member CALICSGR's Avatar
    Jan 24th, 2012
    Bay Area, CA
    03-07-2012 03:30 PM #102
    I've seen plenty of cars without any sidemarkers in the bumper, which leads me to believe the sidemarkers are not required by law, but if they are installed, they must be amber or clear. So I'm still asking, why did VW install those sidemarkers at all?
  33. Member MonkeyMagic!'s Avatar
    Dec 1st, 2011
    NJ
    2012 Golf R (On Order)
    03-07-2012 03:45 PM #103
    They are required by law. It would have been cheaper for VW to not have manufactured a new bumper with cutouts for side markers, they didn't do it to make US cars look worse
    For cars without bumper side-markers you will see they are built into the headlight housings.
  34. Member Dutchmastr9's Avatar
    Sep 13th, 2004
    Boston
    03-07-2012 03:45 PM #104
    these cars prob have an amber reflector built into the side of the headlight. why the germans dont do this is beyond me but i assure you all cars in the us are required to have some sort of amber reflector on the side
  35. Member lovecarsDrV's Avatar
    Oct 27th, 2011
    Atlantic Canada
    2010 Audi Q5 & 2012 T-RED Golf [R] APR 2+
    03-07-2012 03:55 PM #105
    My Audi has the amber reflector built into the headlight assembly - I hate it
    Born into a VW family, what can I say?
