You're getting that message because the Importer Number in that module is '000', which would be unacceptable (or "uninitialized") to *some* modules.Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006221826
Coding: A18C4FA18014100000181800180000000039EE175C1100
Shop #: WSC 06314 000 08192
VCID: 40A190F71398E39
11.11 does indeed produce a warning for this, because it got real old explaining why various modules were rejecting codings when one or more of those fields (WSC, Importer Number, or Equipment Number) were left with nothing but 0's in them. You should have 3 choices at that point:
[Yes] to put in some default values
[No] to leave everything as is
[Cancel] to manually edit the values
Since you know for a fact that this module doesn't object to the 000 in the Importer Number field, you can click [No] and VCDS will try to make the coding change with the existing WSC/Importer/Equipment combination/
-Uwe-
