Results 1 to 30 of 30
Thread: GTI 1.8t problem with acceleration
  1. n00b
    Jan 25th, 2012
    mexico
    2002 vw gti 1.8t
    02-24-2012 07:46 PM #1
    I have a problem with my mk4 golf GTI 1.8T. The car has just had an 80,000 mile service. The problem is difficult to describe correctly, but basically when accelerating hard, the power is lost (as if I were taking my foot off the pedal) and then will come back gradually.
    What could it be?
    I have change the fuel filter and i´m thinking it could be the injectors maybe there dirty but relly don't no
  2. Member 20thGTIMAN's Avatar
    Feb 2nd, 2012
    Puyallup, Wasington
    2003 BMP GTI 20th Anniversary Edition, 2006 Aspen White STI
    02-24-2012 08:14 PM #2
    Quote Originally Posted by N@cho View Post
    What could it be?
    Could be your coilpacks, call the dealership to see if there's a recall. i was also told it could be that you need a ECM update.
  3. Member NH-JK's Avatar
    Feb 24th, 2011
    New Hampshire
    2001 Wolfsburg
    02-25-2012 09:47 PM #3
    Does it feel like your turbo is not even working? Sounds like bad coil packs.
    Jun 21st, 2010
    Darlington
    02-25-2012 11:10 PM #4
    Could be anything from an exhaust leak to a MAP sensor.
    Have you scanned for codes? If not, do so, even if the CEL is not lit.
  5. Member BRANT#2766's Avatar
    Oct 31st, 2011
    North Al
    2003 20th anniversary GTI, '87 Cabby. 2003 Chevrolet Z71, KTM SMC 690
    02-27-2012 01:45 PM #5
    Throttle Positioning Sensor?
  6. n00b
    Jan 25th, 2012
    mexico
    2002 vw gti 1.8t
    02-27-2012 08:19 PM #6
    I FIGURE IT OUT IS THE MAF SENSOR, I ILL TRY TO CLEAN IT WITH CRC MASS AIR FLOW NO.05110 SPRAY HOPE IT WORKS
  7. Member Ducaud's Avatar
    Nov 18th, 2011
    Miami
    GTI 337
    02-28-2012 09:42 AM #7
    im having a similar problem. But it doesnt happen everytime i accelerate hard
  8. Junior Member
    Oct 16th, 2011
    mansfield,MA
    2005 gli
    02-28-2012 02:06 PM #8
    I would check the throttle positioning sensor getting the coil recall done can't hurt either
  9. Member SuckerPunch's Avatar
    Jul 20th, 2003
    LBC, CA
    1986 951, 1978 Rabbit, 1957 T1
    02-28-2012 07:58 PM #9
    i like how 1/2 the people scream coilpacks, lol
    coilpacks either work or they dont, there is no "i think my coilpacks are going bad"...they are either bad or they are not
    this is the typical symptom of a bad MAF
  10. n00b
    Jan 25th, 2012
    mexico
    2002 vw gti 1.8t
    02-28-2012 09:11 PM #10
    Its the MAF when I was ready to cleaned I figure that was missing a metal vend like (U) so any way I cleaned and the car was working fine about 5 min and then start the problem again I try all the way accelerator all the way in and the car didn't respond, by the way i´m going to clean the Throttle Body I thought will be better to have it clean after a new MAF.
  11. Member Ducaud's Avatar
    Nov 18th, 2011
    Miami
    GTI 337
    02-29-2012 07:59 AM #11
    so today i was driving and i did a third gear pull starting from 2k rpm WOT. when i got to about 3-3.5k i was flooring it and the car was barely accelerating, i let off ht gas and the car jerked... any ideas?
  12. n00b
    Jan 25th, 2012
    mexico
    2002 vw gti 1.8t
    02-29-2012 11:09 AM #12
    I started like that but wasn't all the time you can try to clean you're MAF sensor with CRC mass air flow no.05110 for sale in autozone give it a shot.
  13. Member MTVolks's Avatar
    Feb 11th, 2007
    Montreal
    337, Bagged Cabby
    02-29-2012 03:17 PM #13
    Get a new MAF. Should be the problem.
    N75 maybe?
    Low&Slow
    I <3 Booost
  14. Member Ducaud's Avatar
    Nov 18th, 2011
    Miami
    GTI 337
    03-01-2012 09:44 AM #14
    plugged it into a reader last night an no codes..
  15. Member SuckerPunch's Avatar
    Jul 20th, 2003
    LBC, CA
    03-02-2012 07:56 PM #15
    there are no codes for a faulty MAF, only a code if you disconnect it, you will never get a code that says "maf reading beyond XXXX"
    if the car runs like crap long enuf you will get
    system one bank too leam
    random multi misfire
    and then 4 more codes for random multi misfires on all 4 cylinders, so in total you can get 6 codes, and not a one of them will mention the MAF
    what is basically happening is the maf is reading an incorrect airflow, the map is reading a different #, so the car goes WTF, its not sure what is happening so it limits boost, leans the mixture to prevent damage to the CAT and pulls so much timing that you get the misfire codes
  16. 03-02-2012 09:49 PM #16
    could be an intermittantly bad ignition coil (Ive personally had this problem) or it could be pulling a lot of timing for some reason. It could be seeing really high intake temps, which would certainly cause the problem your having. Or it could be boosting high and recieving much colder air then its used to, causing it to lean out and pull timing.
    its going to be hard to know for sure until something breaks, you start replacing parts, or you data log it with vcds.
    337
  17. 03-02-2012 10:48 PM #17
    I'm having the same problem and sometimes when this loss of power happens it will backfire as well, changed the MAF and helped some but still does it once and a while.
  18. Member
    Jun 21st, 2010
    Darlington
    03-02-2012 10:52 PM #18
    If you unplug your MAF sensor and the problems go ahead, it's either a leak or a bad MAF sensor. If it gets worse or stay the same, your problem is elsewhere.
  19. Member ina04gli1.8t's Avatar
    Sep 23rd, 2010
    Coral Springs, Fl.
    2012 United Gray K04GTI 91 triple black Carrera 2
    03-04-2012 11:11 PM #19
    Quote Originally Posted by SuckerPunch View Post
    This ^
    | 2012 United Gray|Two door | MT | Eurojet Catless TBE | Carbonio Intake 1&2 | APR K04 |.APR Intercooler| BBS LM's | H&R Ultra Lows|VWR short shift | Southbend Stg.2 Endurance Clutch| Red Footwell lighting|Autotech Insert |Rear Wiper Delete | Vag-Com Tweaks courtesy of Mike |Podi boost gauge|euro switch|
  20. Member Ducaud's Avatar
    Nov 18th, 2011
    Miami
    GTI 337
    03-08-2012 10:25 AM #20
    im not backfiring at all tho, just sometimes experience a sudden short power loss while in boost, then it comes it comes back
  21. Member mshaker's Avatar
    Dec 2nd, 2007
    2003 / VW/ 20th AE
    03-08-2012 03:16 PM #21
    Its not your coil packs, or your injectors.
    Ive had my 20th for 6 years now.. And let me tell u, i know just about anything that this car could have problems with.
    If your losing power, on acceleration, aka going into a "limp Mode" its either your N75 vavle, or you have a boost leak somewere.
    Most likely though i think its the N75 Vavle.
    Goodluck!
  22. Member Jigga Jay's Avatar
    May 1st, 2003
    Levittown,Pa
    2000 Jetta GLX, IY 20th AE #1270
    03-08-2012 06:15 PM #22
    sounds like fuel to me, but if it was injectors you'd have a fault. or boost leak.
  23. Member Jigga Jay's Avatar
    May 1st, 2003
    Levittown,Pa
    03-08-2012 06:17 PM #23
    its deff not coils. but IF ANYONE ISNT SURE IF THEY HAVE HAD THERE RECALLS DONE, COILS SUNROOF DRAINS, BRAKE SWITCH ETC, PM ME ILL BE HAPPY TO RUN YOUR VIN AND SEE
  24. Member SuckerPunch's Avatar
    Jul 20th, 2003
    LBC, CA
    03-09-2012 12:55 AM #24
    Quote Originally Posted by Ducaud View Post
    who said anything about backfiring...
  25. Member KurtCav's Avatar
    May 7th, 2010
    MKV R32; 337 RIP
    03-09-2012 02:07 AM #25
    Well if the wiring harness is badly cracked it could give the illusion that the coil packs are bad when it's extra damp out but fine when it's dry out.
    .:Roxanne
  26. Member tbaeastcoast's Avatar
    Nov 8th, 2008
    2008 GTI, 2003 IY 20th AE, 99 Wolfsburg Jetta
    03-09-2012 10:41 AM #26
    You have a boost leak somewhere thats the problem
  27. n00b
    Mar 13th, 2012
    Ogden, Ut
    2003/VW/Jetta 1.8T
    03-13-2012 11:56 PM #27
    My 2003 jetta started to sputter under heavy acceleration on the way home from work today. Its very mild in 1st gear, but you really notice it in every other gear (2nd-5th). It almost feels as if the traction control is kicking in but the light is not flashing and it does it regardless, traction control on/off. the Check engine Light has not come on at all. Almost seems like a loss of boost or ecm controlled delay in the timing. I unplugged the pressure control valve (n75) and the shutter was gone but the car was definitely under powered. The car has 85,000 miles, I replaced the Timing belt at 83,000miles and is stock other than a blow off valve. (just sounds cool ).
    I am thinking its the n75 pressure valve, and from what I have read they fail often. But before spending $55 on one I am wondering if there is any way to test it to make sure that is my problem?
    Any Help would be awsome
  28. Junior Member
    Nov 19th, 2009
    NYC
    02 GTI 1.8T
    07-10-2012 12:26 AM #28
    Just bought my 02 GTI recently and same symptoms. I would step on the gas and it would sputter and flutter around 3k rpm with no boost. Found that the rubber hose (about 2.5" diameter) from the turbo (engine area, assuming) has popped off the plastic U shaped pipe going into the passenger side of the FMIC slightly and was leaking air. When I accelerate it sounded like the wind was blowing more on my passenger side compared to drivers side with the windows open. Reattached the plastic hose with a fitted metal clamp ring and fixed the problem.
    Theres oil inside that rubber tube going into the FMIC, is that an issue that i have to look into?
  29. Member KurtCav's Avatar
    May 7th, 2010
    MKV R32; 337 RIP
    07-10-2012 03:27 AM #29
    Quote Originally Posted by dudestranded View Post
    That oil is from the PCV recirculation system. There's a hockey puck type looking thing attach to your turbo intake pipe between the turbo and air filter (not the diverter valve). That thing is spitting the oil in there. It's common among these engines.
    You could get rid of that oil build up by adding a catch can in line to that connection, before the plastic hockey puck valve.
    .:Roxanne
  30. 01-01-2013 10:29 AM #30
    i have the same problem where mine is back firing.. and in neutral if i give it gas the rpm's won't go up.. something is wrong..
