Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 106 to 140 of 244
Thread: DIY: 2.0T Ignition Upgrade for 1.8t
  1. Member Niagara_V_Dub's Avatar
    Sep 25th, 2007
    Las Vegas, NV / Lemoore, CA
    hoopty on air
    03-25-2012 12:23 AM #106
    Did you notice any change in vacuum? Any change in drivability?
    Insert witty quote
  2. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    03-25-2012 01:35 AM #107
    Quote Originally Posted by Niagara_V_Dub View Post
    Nothin
    Sent from my Desire HD using Tapatalk
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  3. Member Andrew149's Avatar
    Jul 10th, 2009
    Modesto CA
    2005 VW GTI 1.8t 5speed
    03-25-2012 05:10 AM #108
    Quote Originally Posted by Zach! View Post
    Nothin
    same i have capped mine off with out doing the 2.0t coilpacks and the car runs just fine
    2005, Mk4, GTI, 5peed, 1.8T, ebach coilovers, ebach 25mm rear sway bar, k&n air-filter, Billy-boat 2.5i DP mangaflow exhaust, sachs clutch, Mirro 111 rims, apr r1 dv, boost gauge, %35 tinted windows, Stage 1 dog-bone, Shifter bushings, Apr TIP, E bay intercooler, Custom tune from Absolute.
  4. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    03-25-2012 05:12 AM #109
    Quote Originally Posted by Andrew149 View Post
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  5. Member fourdubs's Avatar
    May 26th, 2008
    Boring, Va.
    2003 IY 20th #2995
    03-25-2012 06:10 PM #110
    The res is part of the emissions system. I just unboltwd it and capped off the hardline that it runs to, and put a vacuum cap
    Yo Zach! Can you post a picture of said delete? I'm gonna be doing this on my 20th this week hopefully and need to do something with the reservoir.
    All items sold are as is with no warranty/refund implied
  6. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    03-25-2012 07:02 PM #111
    Quote Originally Posted by fourdubs View Post
    I can't haha I hair deleted all my emissions
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  7. Member xjasongli814x's Avatar
    Jun 6th, 2011
    NWPA
    OEM GLI
    03-29-2012 11:44 AM #112
    Now that you've been running a couple weeks on the 2.0 coils, do you notice any more of a difference than the initial one?
    Sent from space using a satellite
  8. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    03-31-2012 04:24 AM #113
    Quote Originally Posted by xjasongli814x View Post
    Feels as good as when I first installed them!
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  9. Member McFadyen-'s Avatar
    Jun 25th, 2011
    Alberta
    97 GF8 STI Ver 4 / Mkiv Jetta 1.8t
    03-31-2012 09:59 AM #114
    Thanks again Zach
    CANADIAN EH?
    Quote Originally Posted by eastcoaststeeze View Post
    bras are meant to be taken off
  10. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    03-31-2012 03:37 PM #115
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  11. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    04-02-2012 08:26 PM #116
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  12. Member Tofik's Avatar
    May 6th, 2007
    908 - Jersey
    Bagged Galactic Blue Wolfsburg
    04-02-2012 08:47 PM #117
    ^not sure why bump required in a diy thread?
    anywho.. i ordered my coils from 1stvw a few days ago..still waiting
    |Build Thread| Awesome New Picture Thread| AccuAir | Air Zenith | Airlift | Bag Riders |
  13. Banned rodgertherabit's Avatar
    Apr 16th, 2009
    Southern Michigan / Raleigh, North Carolina
    Jazz Blue #0802
    04-03-2012 08:26 AM #118
    Quote Originally Posted by Tofik View Post
    Was thinking the same thing
    thanks for the info Zach! Looking to do this soon for my engine build!
  14. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    04-03-2012 02:47 PM #119
    Just bumping it to share the info
    Quote Originally Posted by rodgertherabit View Post
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  15. 04-03-2012 02:54 PM #120
    People looking to benefit most from this are large turbo, high boost vehicles.
    I'm tired of running an .026 to .028 gap on a 62mm turbo. If I can just run .032 I'd be very happy. I'm not too keen on the whole GM LS2 conversion, lotta work.
    This might be my birthday present for myself.
  16. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    04-04-2012 02:13 AM #121
    Quote Originally Posted by ncsumecheng View Post
    Yep, as discussed in the thread I linked to, the ability to run this with a BT set up causes less fouling and a much better idle, let us know how it goes!
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  17. Member
    Sep 8th, 2010
    04-04-2012 04:08 AM #122
    BOYCOTT ebay...............................VRalliance#69 VRSociety#279
    FS: *RARE* 17x8.5 Mercedes Markabs....Feeler: Vintage 1988 Mongoose Stylist
  18. Member
    May 7th, 2011
    Black hills
    03 indigo 1.8t golf
    04-05-2012 12:38 AM #123
    Did it tonight. alot smoother idle and pull even tho my other ones were working fine.
    i glad i did it.
    now i have a check engine light
  19. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    04-05-2012 05:45 PM #124
    Quote Originally Posted by blankie View Post
    i glad i did it.
    Nice! Good luck with the CEL, just check all the connections and grounds, what gap did you use/
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  20. Member Tofik's Avatar
    May 6th, 2007
    908 - Jersey
    04-05-2012 06:00 PM #125
    i glad i did it.
    more specific? whats the code?
  21. Member
    May 7th, 2011
    Black hills
    03 indigo 1.8t golf
    04-05-2012 07:35 PM #126
    Well.. silly thing.
    When we first fired up the badboy after installing the coils i kinda sorta forgot to plug one in
    and it was missing pre hard and the light came on. then figured it out and tried it again and everything was smoooooooooooooth.
    so i just assume its from that and it hasnt been reset yet.
  22. Member
    May 7th, 2011
    Black hills
    03 indigo 1.8t golf
    04-05-2012 07:37 PM #127
    i needa upgrade my grounds for dimming headlights anyways gapped at .40 like it said.
    i know what its from its alllll good. unless something bad happends next time i fire it up.
  23. Member Tofik's Avatar
    May 6th, 2007
    908 - Jersey
    04-05-2012 08:55 PM #128
    Well.. silly thing.
    smh hah and glad nothing else was wrong
    on a side note my coils get here tomo =]]]]
  24. Member
    May 7th, 2011
    Black hills
    03 indigo 1.8t golf
    04-05-2012 08:56 PM #129
    went for a little drive abit ago.
    check engine light went off all by its self. im so proud.
  25. Member Tofik's Avatar
    May 6th, 2007
    908 - Jersey
    04-05-2012 09:06 PM #130
    usually in the vw world its abnormal if it goes off on its own
    acceptable default state of the CEL is On
  26. Member dirtyvw's Avatar
    Jun 1st, 2008
    MA
    04 Jetta 1.8T
    04-08-2012 06:16 PM #131
    Did mine today and everything went smoothly but when I took my old coils and spark plugs out they were covered in oil. Is that normal?
    I leave wheel gap for fat chicks
    PSN: ladouche730
  27. Member speedkillz's Avatar
    Jan 26th, 2005
    Statham
    '05 GLI, '99 Herbie
    04-08-2012 06:18 PM #132
    Quote Originally Posted by dirtyvw View Post
    no you have a valve cover leak.... new gasket time
  28. Member Teh_Chris's Avatar
    Dec 30th, 2007
    Central VA
    04' MkIV TR .:R32 /04.5' MkIV BMP GLI/ 96' MkIII VR6 GTI
    04-08-2012 06:22 PM #133
    Quote Originally Posted by speedkillz View Post
    What speed said
    _R-1-3-5 _2004 BMP GLI 2.0T 20V
    _└-┼-┼-┤_Stage 2 Unitronic Tuned
    -__2-4-6____Sprayn Meth
  29. Member Teh_Chris's Avatar
    Dec 30th, 2007
    Central VA
    04-08-2012 06:26 PM #134
    Sooo just ordered the adapter plates and a set of mk5 coilpacks .... Gona grab a new set of plugs soon what are u guys running and what gaps are u setting them at .... Im currently running denso iriduims gapped at .028 .
  30. Member Brightgolf's Avatar
    Jan 13th, 2008
    Pittsfield, MA
    01 Wolfsburg Jetta
    04-08-2012 08:05 PM #135
    Why was this thread even required. We listed all the parts needed and how to install them last year when we got issam at INA to make the first adapters to begin with.
    01 Wolfsburg Jetta 5 Speed | Apr Stage 2 | Stage 1 Clutch + 14lb flywheel | Neuspeed Short Shifter | 3" turboback exhaust | Forge 007 | Forge TIP | Eurojet Discharge piping | Sidemount | Eurojet pcv hoses | Blackforest Stage 1 Mounts | Raceland Coilovers | Newsouth Boost Gauge | Neuspeed P-Flo | 4 Pot Brembos
  31. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    04-08-2012 10:34 PM #136
    Quote Originally Posted by Brightgolf View Post
    Getting a nice set of pictures for a DIY and providing all the info in a short sweet post was the main reason.
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  32. Member David_Tedder's Avatar
    Oct 23rd, 2005
    Tdot/Barrie
    MKIV awp
    04-08-2012 10:59 PM #137
    if you havn't found the link to the delete thread here it is
    http://forums.vwvortex.com/showthrea...-N249-PCV-EVAP
    Quote Originally Posted by groggory View Post
    Put the money in a jar. When you have $5k post on here..
    "I have $5000, help me spend it"
    and we'll lead you down the right path. :-)
    PAG PARTS
  33. Member dirtyvw's Avatar
    Jun 1st, 2008
    MA
    04 Jetta 1.8T
    04-09-2012 04:56 AM #138
    well that's just great
    PSN: ladouche730
  34. Member Teh_Chris's Avatar
    Dec 30th, 2007
    Central VA
    04-09-2012 05:27 AM #139
    Lols its an ez fix dont sweat it .
    Sent From Mah iPhone4 Using Teh Tapatalk B!tches
  35. Member fourdubs's Avatar
    May 26th, 2008
    Boring, Va.
    2003 IY 20th #2995
    04-09-2012 10:08 PM #140
    Quote Originally Posted by David_Tedder View Post
