Page 2 of 2 FirstFirst 1 2
Results 36 to 57 of 57
Thread: Questions about lowering springs
  1. Member cheapa55TDI's Avatar
    Sep 30th, 2011
    2012 Passat TDI SE
    05-03-2012 11:37 PM #36
    Quote Originally Posted by Myfirstvdubb View Post
    What size wheels and tires? Looks very nice.
    http://forums.vwvortex.com/showthrea...1#post76785472
    Apr 19th, 2007
    CT
    05-04-2012 10:57 AM #37
    Quote Originally Posted by Perio5 View Post
    Ok so what would be the best option for pairing the h&r springs, what brand/model of struts???
    There isn't anything available yet as the car is too new for general replacement shocks. For a couple of years (especially with a "family sedan" like the Passat) the options will be either springs or full coilovers. Bilstein has a Sport shock (shorter case to accommodate lowering) in Europe for the latest German Passat, but there's no guarantee they'd fit, and Bilstein US might not be willing to import them.
    By the time the stock struts and shocks wear out, Bilstein and Koni will have several options, and Eibach and H & R will have their ProSystem and Cup Kit matched spring/shock (shocks for both made by Sachs) setups.
    The next step may be for someone to see if a B6 Cup Kit would fit.
    Jan 13th, 2004
    H-Town,TX
    05-04-2012 03:43 PM #38
    I am pretty sure anything off the B6 will fit, I have even heard any suspension off the gti/jetta will work.
    Apr 19th, 2007
    CT
    05-06-2012 09:53 AM #39
    Quote Originally Posted by Coolcrush View Post
    This was found to be the case with the Tiguan, except that some spring/shock (not coils) combos couldn't handle the weight and while they looked awesome, bottomed out when running over coins.
  5. Member TDI Brad's Avatar
    Nov 12th, 2011
    SC
    2012 Passat TDI SEL
    05-11-2012 05:23 PM #40
    Got my H&Rs put in today.
    Euro switch, 30% 3M nano ceramic tint, Chinese BiXenon headlights and LED tail lights, H&R springs, paddle shifter steering from V6, 20" Giovanna Kilis wheels, 225/35ZR20 Conti DWS tires
  6. Member cfurman's Avatar
    Feb 4th, 2008
    Michigan
    99 Jetta Dsl;96 GTI;05 Jetta 1.8T;10 Jetta 2.5;11 Tiguan SEL;11 GTI;11 Golf TDI;12 Passat 3.6SEL
    05-11-2012 06:23 PM #41
    Quote Originally Posted by TDI Brad View Post
    So how's the ride? put a full load of adults in it yet?
    ________________________
    2012 Tiguan SEL
    2013 GLI Autobahn Nav
  7. Junior Member shredX's Avatar
    Apr 18th, 2012
    ABQ, NM
    2012 Passat VR6 SEL Premium
    05-11-2012 06:58 PM #42
    Nice.
    How's the ride?
    '12 Passat VR6 SEL
  8. Member TDI Brad's Avatar
    Nov 12th, 2011
    SC
    2012 Passat TDI SEL
    05-11-2012 06:59 PM #43
    My wife two friends and our baby went for diner tonight and it was fine just a little rougher over train tracks but other than that it seems good so far.
  9. Junior Member MCKSHNL's Avatar
    Mar 15th, 2011
    Los Angel-ish
    2012 Passat TDI SE, Platinum Gray, Sunroof & Nav
    05-12-2012 12:30 AM #44
    Nice! I have the same color and wheels. Thanks for the pics, I like seeing how mine could look!
    Andy
  10. Member TDI Brad's Avatar
    Nov 12th, 2011
    SC
    2012 Passat TDI SEL
    05-12-2012 01:04 PM #45
    I don't remember seeing anothe gray SEL lowered with bristols on it here on the forum. Correct me if I'm wrong.
  11. Junior Member shredX's Avatar
    Apr 18th, 2012
    ABQ, NM
    05-14-2012 07:11 AM #46
    Any additional parts needed to go with the H&R springs?
    With the GTI there were several "one time use" nuts and bolts.
    (needed for the lower control arms I believe)
    Thanks again!
    '12 Passat VR6 SEL
  12. 05-14-2012 12:06 PM #47
    Hmmm....I put the Eibach Pro-System on my current MKV GLI and found the lowering was very modest from the GLI suspension. My guess was that that since the stock GLI bits are already lower than the Jetta parts, the measured drop Eibach listed was less than I actually measured. That being said, I wonder if my OE GLI suspension would bolt up without too much trouble? I would prefer to go that route and keep VW parts on a VW car. Anybody done this?
  13. Junior Member shredX's Avatar
    Apr 18th, 2012
    ABQ, NM
    05-25-2012 09:06 AM #48
    Quote Originally Posted by shredX View Post
    Thanks again!
    Bump to see if there were any additional parts needed.
    Thanks!
    '12 Passat VR6 SEL
  14. Member TDI Brad's Avatar
    Nov 12th, 2011
    SC
    2012 Passat TDI SEL
    05-25-2012 10:33 AM #49
    No I don't think there were any additional parts used. If so the mechanic didn't charge me for them. I took it to the shop gave them the springs and they put them on and aligned.
  15. Member
    Jan 30th, 2006
    2012 Passat TDI
    05-25-2012 11:40 AM #50
    There are a bunch of bolts that are TTY that should be replaced
  16. Member TDI Brad's Avatar
    Nov 12th, 2011
    SC
    2012 Passat TDI SEL
    05-25-2012 01:12 PM #51
    That makes me wonder if they reused the TTY bolts on mine now.
  17. Member
    Jan 24th, 2012
    Phoenix, AZ
    2012 Passat V6 SE
    05-25-2012 02:59 PM #52
    ShredX-
    Thanks, I agree about the gap of the stock set. This is not the first car that i have lowered, but it is the first that i only swaped the springs. I am still waiting for KW to bring their coilover set up to market or even for Bilstein or koni shocks. The current ride is nice, just floats a few too many times before settling down after a good bump.
  18. Junior Member shredX's Avatar
    Apr 18th, 2012
    ABQ, NM
    05-26-2012 07:58 AM #53
    Quote Originally Posted by mtoger View Post
    ShredX-
    Thanks.
    Would you say it bounces/floats more than stock? I feel the stock suspension is a little floaty after the GTI. I don't want to get these coils and end up going in the wrong direction.
    Also could be unfair to continue to compare the two cars. GTI was pretty special.
    '12 Passat VR6 SEL
  19. Junior Member shredX's Avatar
    Apr 18th, 2012
    ABQ, NM
    05-26-2012 08:00 AM #54
    Quote Originally Posted by redneckracing View Post
    Thanks!
    '12 Passat VR6 SEL
  20. Junior Member
    Feb 21st, 2012
    2012 VW Passat SE
    05-26-2012 11:28 AM #55
    if you drop the car and change the springs, does that void the warranty on the suspension and such?
  21. Member
    Jan 24th, 2012
    Phoenix, AZ
    2012 Passat V6 SE
    05-29-2012 10:24 AM #56
    the rebound is floaty- I had a 2006 GLI, stock it was much stiffer and more resonsive than current GLI. and makes the passat feel like a boat. Reality is you can always make improvements and dial in your wants and needs. Thats why we have aftermarket parts...lol
  22. Junior Member wakkigy's Avatar
    Jul 25th, 2004
    Temple City, CA
    2012 Passat TDI SE
    05-29-2012 02:09 PM #57
    Quote Originally Posted by 2012psst View Post
    Its my understanding that with stock shocks it's only a matter of time before they wear out and blow because of the added stress of the lowering springs. If you do it right the first time there should be no regrets later on down the road.
    http://
    Doesn't look like that many folks are going for the H&R CO, how did you feel on the ride when you drop it all the way to the bottom/is it the adjustable CO? I just want to do it right on the suspension so I dont' have to worry about camber and tire wear issues later on.
