VWVortex.com - 2011 TDI service light
    Results 1 to 7 of 7
    Thread: 2011 TDI service light
    1. Member KAWIMAN35's Avatar
      Jan 19th, 2010
      Columbia SC
      2011 Jetta TDI, 2012 Beetle 2.5l
      02-25-2012 08:31 PM #1
      Can anyone tell me how to reset the service light on the dash? I am past the 30,000 mile service thing and I don't fell like paying 500 for an oil change. I already changed the oil and filter, just wanting to know how to reset the light. If I can't reset the light, who should be able to?
    2. Junior Member pinkertonfloyd's Avatar
      Oct 25th, 2003
      Roseville, CA
      2012 Jetta TDI
      02-25-2012 10:14 PM #2
      Quote Originally Posted by KAWIMAN35 View Post
      1) On a TDI I hope you used 507.00 oil, it's a special blend for the diesels, anything else will cause issues later. The oil is about $8-10ltr.
      2) You need a tool, Ross-Tech's VCDS/VagCom is the most common one out there, there is no button sequence you can press/hold to reset the light.
    3. Member CDN TDI's Avatar
      Jan 25th, 2012
      Canada
      2011 TDI Jetta 6MT, 1991 Turbo Diesel Jetta 5MT
      02-26-2012 11:02 AM #3
      On the instrument cluster, you will see two buttons, one on each side. With the key off, reach in and press/hold the button on the right, keep holding while you turn the key to "on", release that button and press the one on the left.
    4. Member KAWIMAN35's Avatar
      Jan 19th, 2010
      Columbia SC
      02-26-2012 12:43 PM #4
      Quote Originally Posted by CDN TDI View Post
      I use VCDS/vagcom, but someone posted the following instructions on another forum. There's no confirmation that it works, so perhaps you can try it and report back.
      Another post had the following:
      With the car off, press and hold the "0.0" trip reset button at the bottom right of the instrument cluster.
      Insert the key and turn it to "ON" but don't start the engine.
      Let go of the "0.0" trip reset button.
      It should still say "Service Now". Press the button for adjusting the clock minute, "M" on the bottom left side of the instrument panel. If that doesn't work, hold the trip reset button while pressing the clock minute button.
      Thanks, I wil try that, and yes I did use that 507.00 stuff.
    5. Semi-n00b
      Jan 31st, 2012
      Ontario
      2012 Jetta TDI
      02-26-2012 12:54 PM #5
      This is why I love this site. I litterally logged on to look for the same solution to this problem as I just changed my own oil lastnight and had no clue how to get that service light off.
    6. Junior Member AirmanTDI's Avatar
      Apr 26th, 2011
      Eastern Ontario-CANADA
      02-26-2012 02:15 PM #6
      The reset instructions are in the manual, I just reset mine, I would type it out but I cant remember what I did
      Pain is just weakness leaving the body
      http://www.fuelly.com/sig-metric/70042.png
    7. Member KAWIMAN35's Avatar
      Jan 19th, 2010
      Columbia SC
      02-26-2012 08:05 PM #7
      Quote Originally Posted by AirmanTDI View Post
      Thanks I just checked and your right. Heres how you do it.
    « Back
