Results 1 to 8 of 8
Thread: 2001 Jetta 2.8
  1. Member jetdavdub's Avatar
    Mar 13th, 2006
    Mark 3 Vr Turbo, Mark IV vr6, b5 passat
    02-25-2012 09:26 PM #1
    Do you think the following problems could be related?
    Windshield wipers work slower than normal on all settings.
    Cranks over slow.
    Heater is strong then not strong.
    Thanks,
    Sent from my ADR6300 using Tapatalk
    98 Jetta VR6T
    01 B5 Passat w/ v6 30v
  2. Junior Member
    Apr 28th, 2007
    2001 GTi GLX, 2009 Astra XR
    02-26-2012 12:16 AM #2
    Seems to me like low voltage. Alternator losing power or battery has a bad cell. Start by getting them tested to begin, don't replace unless confirmed bad.
  3. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    Mk2 GTI VR6... .......................Mk5 Rabbit 2.5
    02-26-2012 01:52 AM #3
    Quote Originally Posted by mojavebeige View Post
    x2 - also check the connections on top of the battery inside the little black fuse panel. There are some strip fuses, the fuse with the large black cable attached is for the alternator.
    /// VRSociety Member #298 /// Mk2 Milita-VR6 Battalion-2dr Regiment /// Instagram @scottyvr6 ///
    My 2.9L BVH build and the machine shop #%@- up that almost ruined it all.
  4. Member jetdavdub's Avatar
    Mar 13th, 2006
    02-26-2012 10:26 PM #4
    I ran a charger on it for a few minutes and it started up. Let it idle to charge, if it could, it started back up right away. Came back hour later barely cranked over this time but did start. Turned it off then on again and it was fine. The battery date is 9/10 pretty new.
    98 Jetta VR6T
  5. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    02-26-2012 10:31 PM #5
    Quote Originally Posted by jetdavdub View Post
    .... The battery date is 9/10 pretty new.
    Meaningless. Def sounding more like a voltage problem. Get the battery and charging system tested before going any further.
  6. Member jetdavdub's Avatar
    Mar 13th, 2006
    02-28-2012 11:40 PM #6
    Changed the battery and so far so good. The wipers are still slow must be separate issue.
    98 Jetta VR6T
  7. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    02-29-2012 12:19 AM #7
    ..... The wipers are still slow must be separate issue.
    Sounds like the pivots on the linkage are seizing up. They tend to dry up and corrode. You'll most likely need a new linkage. To know for sure, remove the motor/linkage assembly from the car. With the motor disconnected from the pivot arms, the linkage should pivot effortlessly.
    Aug 14th, 2007
    Illinois
    2000 jetta glx
    02-29-2012 06:09 AM #8
    2X on the wiper problem.There is a DIY thread around here,did mine about 6 months ago.They work normal now.
