Page 1 of 2 1 2 LastLast
Results 1 to 35 of 45
Thread: Official ABA 16V stroker engine thread
  1. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    81 Rocco,80 Rocco track, 81 Rocco Haldex twin charge Berg cup project, 84 Mk1 Jetta coupe
    02-26-2012 12:49 AM #1
    I know that a few of us are doing the ABA 16V with diesel crank.
    ACOW, & Mr Whalen are some...
    Lets get things started.
    I will post more tech details on my set up soon, but just wanted to post this up for now.
    The Beast:
  2. Member MikkiJayne's Avatar
    Jan 1st, 2007
    UK
    A6 TDI Quattro wagon, A4 V8 Quattro racecar
    02-26-2012 05:26 AM #2
    That looks like it will be a lot of fun
    Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    02-26-2012 11:23 AM #3
    I am running one in my Rabbit truck. Very similar looking to yours:
    84mm JE 11:1
    Collin head with the bigger intake valves, 276 schricks
    Weber 45s
    I strongly advise you to go ahead and fab up a breather setup and puke tank for the valve cover and another for the crankcase.
  4. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    02-26-2012 05:06 PM #4
    My set up:
    ABA block OBD1
    Tdi crank machined / lightened to the about the same weight of a 2.0L gas
    84.00 Wossner ABF pistons 12.5 CR machined to clear squish band (see above pic on lathe...)
    (final compression ratio is now 14.5:1 Running on VP C12 only)
    TT big vavle kit with springs & ti retainers
    Mk5 light weight hydraulic lifters
    Schrick 276-276 cams
    central coolant port blocked off on head; only running the side port
    Setrab oil cooler with Volvo thermo sandwich plate
    Distributor delete
    Running megajolt ignition with MAP for load : 3D programmable
    EDIS 4 coil packs
    TT race headers fully wrapped
    3 Row aluminum Honda radiator
    228 mm stage 5 clutch with 7 lbs chromoly flywheel
    Clutch cable set-up with Eurovan actuator
    Quaife 6 speed dog box with 4.17 F.D.
    Real VWMS clutch type LSD
    running with dual DCOE 45's : at the limit of the 45's
    last year at the dyno, before any tuning, and when it was at 12.5:1 CR
    216 WHP
    178 Tq
    I'm at the 4:02 mark
  5. Member Bubble Block's Avatar
    Sep 19th, 2009
    Manassas, VA
    '92 Cabby (daily) '80 S1 (project)
    02-29-2012 10:47 AM #5
    I have been debating what motor set up I want to build over the next year or so for the S1. This seems like a very good option. I'd like to know a little more.
    Currently
    '92 Cabby (Daily) | '80 S1 (project) | '01 Passat (wifey's)
    Owned
    '84 Rabbit | '83 Rabbit | '89 Cabby | '98 Jetta | '97 Jetta | '92 Golf | '89 Golf
  6. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    02-29-2012 02:57 PM #6
    I will be posting more deatils on the intricacies related to this recipe...
    probably during the week end, with a tasty beverage next to my keyboard
  7. Member leon whalen's Avatar
    May 27th, 2007
    truro n.s.
    94 gti aba16v stroker
    02-29-2012 10:03 PM #7
    a stroker thread.... great idea fredy
    i will try and get some pics up of mine, here are the specs.
    aba16v
    95.5 crank lightened & balanced
    9a pistons
    full port/polish head multi angle valve job
    276° schrick cams
    hd valve springs
    bbm fuel rail
    t.t. lightweight adj. cam gear
    aba ecu with t.t. aba16v chip
    raceland 4-2-1 header
    magnaflow highflow cat
    t.t. 2.25 exhaust
    4k trans with .71 5th gear ( i need an lsd)
  8. Member leon whalen's Avatar
    May 27th, 2007
    truro n.s.
    02-29-2012 10:16 PM #8
    old motor shot before new head
    my daughter getting ready to run it down the strip
  9. Junior Member JuniorWhalen's Avatar
    May 15th, 2008
    Truro N.S. Canada
    '90 Jetta coupe - ABA 16v, '92 Jetta 1.6td
    03-01-2012 08:24 AM #9
    Quote Originally Posted by Bubble Block View Post
    An S1 deserves an audi 5 cylinder 20v turbo
  10. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    03-03-2012 05:01 PM #10
    When I was doing this engine last year, I tried getting information in the "monster useless sticky" for the ABA 16V thread...
    Be serious, a sticky with hundeds of pages ? I took about 4 hours, trying to see if there was any pertinent information for what I was doing; The thread does have good information, but its worst than finding a needle in a haystack.
    So my point to this thread, is to give as much information about having an ABA / 16V (ABF clone) with a 95.5 stroker TDI crankshaft.
    There are many ways to skin this cat when it comes to pistons, which is the part that stands out , in this kind of engine.
    I remember reading on a few alternatives, but I will put forward what I did:
    First, the crank has to be machined to clear the squirters , (I put a ABA OBD1 with oil squirters) and also , making an engine like that, is usually for performance purposes, so light weight is a big factor. So I had the counterweights machined to clear the block, and asked for the crank to be lightened, even more than a gas crankshaft.
    I decided to use the ABA OBD1 connecting rods, had them re-bored, because I put ARP hardware, and I wanted to have the con rod bearings to the best possible tolerancing.I also balanced the rods.
    The balancing is not hard to do, check this video out :
    Now that the rods have been taken care of, the pistons (the angular stone of the build) need to be looked at:
    Since I got some Schrick 276's my main concern was piston to valve clearance.
    I also wanted to have a high compression engine. at fist I wanted about 12.5:1 static.
    but going to a dynamic compression ratio made more sense:
    The dynamic compression ratio, takes in account the overlap of the intake valve, after top dead center. So basically, its to adjust the compression, with your cams.
    I ordered Wossner 84.00mm ABF pistons with 12.5:1 compression
    With the stroker crank, these were a lot over deck, but it was OK: I wanted to play with the head gasket thikness, and I could also turn the pistons down on my lathe, with the 4 jaw chuck (which I did)
    I made the calculations with the CC's of the head (that did change from stock because of the oversized valves) and piston overdeck CC's in order to obtain the needed head gasket thickness. I delaminated ABA gaskets, and mixed, and matched the layers to obtain the desired thickness. If I remember correctly, I had about 0.106" at that time.
    I put plasticine on top of the piston, and assembled the head on the block, with the timing belt.
    Rotated the crank slowly, in order to measure valve clearance.
    Problems encountered:
    the 45 degree of the Wossner pistons, would hit the outside part of the squish band on the head, and the ABA gaskets were real close too.
    So I machined the 45 degree taper by about 0.047", and I also opened up the head gasket layers, with a small flapwheel, one by one, and thouroughly cleaned them afterwards.
    I also doweled the block to the head & head gasket layers, using custom machined dowels.
    The reason in the back of this, was to locate the gaskets diameters within a few thousands of an inch, because of the tolerance between the 84mm pistons and the head gasket.
    I will try to find my notes, for my CC calculations, and dynamic compression numbers.
    OK, enough typing, I will come back soon with more.
    Cheers!
    Fred
  11. Member
    Jun 14th, 2001
    Music City USA
    03-03-2012 09:00 PM #11
    My machinist sunk squirters 1-3 higher into the block as #4 is. This took care of the clearance.
    Remember hydro lifters will be pumped up a bit when running thus giving you slightly less piston to valve clearance than you will measure in a mockup.
  12. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    03-03-2012 10:36 PM #12
    Quote Originally Posted by antichristonwheels View Post
    I already ran this engine for a full season on the track, I'm just sharing my findings, and it will take quite a few posts, for me to render the full story, and ongoing upgrades of my engine...
    And I would prefer taking of material off the crank in order to reduce inertia, then sinking in the squirters...
  13. Member REPOMAN's Avatar
    May 3rd, 2001
    Portland OR
    1990 VW Corrado
    03-10-2012 12:56 PM #13
    500HP 1990 Cowrado
    Have a great Orwellian Day
  14. Member Bubble Block's Avatar
    Sep 19th, 2009
    Manassas, VA
    03-11-2012 11:50 PM #14
    Quote Originally Posted by leon whalen View Post
    Nice! what type of numbers are you seeing at the wheels? and what did she run down the track??
    Currently
    Owned
  15. Member Bubble Block's Avatar
    Sep 19th, 2009
    Manassas, VA
    03-12-2012 12:39 AM #15
    Quote Originally Posted by fredybender View Post
    My set up:
    ABA block OBD1
    Distributor delete
    EDIS 4 coil packs
    216 WHP
    178 Tq
    Fred This is pretty much the goal I would like to reach. I am looking to have a N/A between 170whp and 200whp if I can manage to get slightly more out of it I will be happy but I am not looking for anything extreme. I don't really want to run forced induction. I am looking to build a motor over the next year and probably be done (ready to drop it in the S1) some time around May 2013. Clearly you have "been there done that" & judging by this thread I am assuming you don't mind taking the time to explain things most people forget to mention. Would you mind if I pick your brain from time to time & give recommendations on what to use and what to stay away from?
    Great build by the way!
    Currently
    Owned
  16. Member leon whalen's Avatar
    May 27th, 2007
    truro n.s.
    03-15-2012 06:48 PM #16
    Quote Originally Posted by Bubble Block;
    she ran the car into the 15's before the schrick cams went in.
    15.2@91mph is cars best (without an LSD, traction is a real issue)
    car has never been on a dyno but i am very pleased with its performance
  17. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    03-16-2012 08:27 PM #17
    Thanks for the kudos!
    to get 200 WHP out of a NA 16V is somewhat of a challenge, and is also a wallet squeezer...
    170WHP is not that hard to do.
    The difference, is getting any of the HP's above 170 or so, not logical, considering the efforts and $ needed
    I will try to eventually put as much information in here, to help out.
    But then again, I think I rather get one on one communication, for the peeps that have the flame, and have the commitment to do such an illogical decision
    Hit me up anytime BB
  18. Member 71camaro's Avatar
    Apr 20th, 2009
    Cambridge, MD/Penn State
    MK4 GTI VR6(rip)/ Gen2 Camaro Z28/ MK2 Jetta(rip)/S2 Scirocco 16v/S2 Scirocco/D2 S8/ '95 GMC
    04-11-2012 07:29 PM #18
    Hey, I'm interested in getting some info here. I've got a 16v g60 setup using a 1.8l block, and I want to go to a 2.0/2.1L setup in the car, while staying at 10:1. If I were to do this, would I still use stock bore and just use the increased stroke to gain the displacement? And what CR piston would I run to get around 10:1? I'm planning on running a fairly large twin screw and feel the added displacement will be a huge help.
  19. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    04-12-2012 06:55 PM #19
    Need to check up on a few notes, but
    95.5 crank
    ABA block & rods (OBD1 preferably for boost app)
    Pistons : I would probably go with stock ABF pistons and double up on the head gasket:
    The head gasket is 0.063" and the added stoke gives 0.053" higher protrusion in the head...
    The stock C/R is 10.4, so with 0.009" more thickness, you would be close to 10 anyways.
    I would definitely suggest you verify combustion chamber cc's, and piston interference with plasticine, during the build.
    HTH
    Fred
  20. Member 71camaro's Avatar
    Apr 20th, 2009
    04-12-2012 07:08 PM #20
    95.5 crank
    HTH
    Fred
    I want at least 9:1 but want more. It seems like a lot of people are scared of boost and higher compression, I am not. Tuning makes it work if done correctly. I was thinking the ABF pistons would be close, and yeah, some playdoh during the build to check clearances would be smart. Thanks I'll update as I move forward.
    Also, does anyone know of a source for forged ABF pistons rather than cast? Thanks
  21. Member 71camaro's Avatar
    Apr 20th, 2009
    04-12-2012 07:41 PM #21
    http://www.bahnbrenner.com/vw_audi/p...mm_Bore_Std_CR
    I assume with the added stroke, these would end up at approximately 9:1?
  22. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    04-13-2012 02:38 PM #22
    you'll end probably with around 10:1 with stock abf's with 2 ABA HG
    this is piston height at TDC with 12.4 CR ABF pistons 84mm with ABA bloc & rods with 95.5mm crank:
  23. Member 71camaro's Avatar
    Apr 20th, 2009
    04-16-2012 12:50 PM #23
    Anyone here know if the ABA trigger wheel, or another one perhaps, will work on the 1.9 crank? I'm trying to run coilpacks, and do away with the distributor
  24. Member
    Jun 14th, 2001
    Music City USA
    04-16-2012 10:22 PM #24
    you could do it but drilling the crank to bolt on the wheel might be a pita
    I used an 034EFI 16V 60-2 trigger wheel and sensor, firing an Electromotive ignition.
    the 034 stuff is really nice and it bolts on.
  25. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    04-16-2012 10:32 PM #25
    I STRONGLY suggest you look at a Megajolt ignition:
    Real 3D programmable, and uses EDIS 4 module, & coil pack, and trigger wheel...
    Cheap, good reliable, programmable.
    I have heard horror stories on 034 with older stuff. Not a bad outfit, but 034 is made for the newer stuff IMHO...
    36-1 wheel is easily adaptable to crank pulley, no retrofit needed for a "stock" VW trigger wheel.
  26. Member 71camaro's Avatar
    Apr 20th, 2009
    04-16-2012 11:56 PM #26
    I may attempt it (have a machine shop available). I'm trying to keep everything as hidden as possible, bay is extremely shaved, and I'm trying hard to keep everything hidden
  27. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    Megasquirt 3x Powered 98 Jetta GT 2.0
    04-19-2012 02:32 PM #27
    The Beast:
    What plug wires did you use for that EDIS pack to fit in the 16v?
    98 Jetta 2.0 w/ Megasquirt 3/3x fully sequential
    ABA 16vT build thread
  28. Member leon whalen's Avatar
    May 27th, 2007
    truro n.s.
    04-19-2012 06:11 PM #28
    Quote Originally Posted by 71camaro View Post
    the ABA trigger wheel is a direct fit. i have one on my tdi crank. it can also be used with most stand alone systems.
  29. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    04-19-2012 06:22 PM #29
    Quote Originally Posted by SirSpectre View Post
    I bought the ford Escort wires and, took the 16V ends out of a set I had.
    Just made a set myself...
    Just got to be carefull: Lucky my Coilpacks are close enough, but I'm at the limit of length for cyl. #1
  30. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    04-19-2012 07:11 PM #30
    Ah bummer. I am going to do the same, was hoping someone made some, or found a set from Ford that matched nicely.
  31. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    04-19-2012 08:33 PM #31
    why bother with the EDIS stuff when you can use the factory 60-2 stuff.
  32. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    04-19-2012 08:34 PM #32
    Quote Originally Posted by bonesaw View Post
    Thats what I'm using. I use the 60-2 wheel, but use the coil pack for spark. MS drives the pack directly. I just need the plug wires.
  33. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    04-19-2012 08:38 PM #33
    i see. why not use bosch motorsports coil? use stock 16v wires. Can MS fire a high current coil directly?
  34. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    04-19-2012 08:56 PM #34
    It can. Which coil did you have in mind? I'd hate to have to rewire the drivers and power for a different type of coil. Changing the pigtail would be easy though.
  35. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    04-19-2012 09:34 PM #35
    Bosch Motorsports 2x2 Coil.
