Results 1 to 26 of 26
Thread: Project VR666: A MK2 VRT build
    Jul 27th, 2010
    Albuquerque, New Mexico
    B5 S4, 04 STi, 87 Jetta coupe (current)
    02-26-2012 04:55 PM #1
    Hey everyone! After going through many ups, downs, and even almost parting out my build, I am closing in on getting this thing running so I thought I'd share some pics and info on my build.. I apologize in advance for the lack of pictures due to a broken phone.
    This is where I started.
    Looking for a project to build, I found a 1987 Wolfsburg Jetta coupe AND a 1993 Corrado VR6 donor car on Craigslist in the SAME day!
    My original plans were to do a Traditional OBD1 swap with everything from the Corrado and turbo it later..
    I ordered a bentely Manual and it was game on!
    I pulled the Corrado VR6 to have it rebuilt
    While the motor was at the shop I started to strip down the coupe
    Stock 8v that barely ran, going to the junk yard..
    I swapped the whole Front and rear subframes over from the Corrado for a full 5 lug conversion, sorry I lost the pictures when I broke my phone
    I threw on some new Raceland coilovers when I installed the subframes..
    Although it's not for everyone, I have always been a huge fan of stance! with the 5 lug conversion it opened up some wheel options. I found a set of salad shooters locally on craigslist for $100 bucks! They are 8.5 front and 9.5 rear
    test fitted just for fun
    Pic of my old car with a nice stance
    Ordered some Adaptec adpaters 5x100 to 5x120 and some federal tires. I went with 205/40/R16 all around because they are really inexpensive. If I could find them, I would have gone 205/40/R16 for the rear 9.5's and 195/40/R16 for the 8.5's in the front for a little stretch..
    Finally got the VR6 back from the machine shop after a month, I had it rebuilt with ARP headstuds, mainstuds, rod bolts, all new gaskets and seals, piston rings, rod bearings, and new timing chain kit. also had the head rebuilt oem. $1800 in labor, and $700 in parts later this is the finished product
    After becoming submersed in my project, the research told me that OBD1 was not the way to go for turbo applications, and I would eventually be converting to OBD2 regardless.. luckely for me a new donor car came up for sale. This was a low milage GTI VR6 (38k miles), it was also already turbo'd so I decided to pick it up and keep the motor I had rebuilt as a back up.
    PUBLIC SERVICE ANNOUNCEMENT!!
    Most of you reading this are probably experienced mechanics and have numerous builds under your belt, for those of you planing a first time build like myself, please do the following..
    Research, Research, make a game plan, know what parts you are going to need, stick to your game plan, trust me it will save you time, money and stress in the long run!!
    Here is the new donor car
    The setup includes the following
    stock bottom end
    Head 1mm overbore
    ARP headstuds
    EIP turbo set up
    aftermarket clutch
    quaiffe LSD
    Some other goodies I got with the new donor car..
    Unfortunately I do not think these are going to fit with my current wheel set up
    So I am now using the motor, trans, wiring/ecu, and dash from the low milage gti. With the coupe sitting as a rolling chassis we started to put everything together.
    The mk3 wiring harness
    We started to run the wiring throughout the car, dont worry it wont be this ugly for very long
    Corrado VR6 pedal cluster
    we fitted the mk3 GTI dash support by cutting the ends off and making brackets on the sides, we also welded some supports by the steering column ( because that's kind of important)
    Ordered one of these bad boys from vw- only
    here is his fs thread where you can order them
    http://forums.vwvortex.com/showthrea...8#post75906468
    as of right now here is how the car sits
    More updates to come
  2. Member Heidelberg2az's Avatar
    Aug 7th, 2009
    Kaiserslautern, Germany
    87 Jetta, 86 Audi 80, 84 Golf, 83 Bug, 78 Golf
    02-26-2012 05:18 PM #2
    coming along nicely. I had thought bout getting those same wheels for quite some time but then went with something else.
    Looking for a new custom tattoo? Check out my shop!!
    American owned and operated
    www.facebook.com/americanelectrictattoo2013
    Jul 27th, 2010
    02-26-2012 05:24 PM #3
    Thanks pal. If I had known they would have issues clearing my brakes I would have chose something else. I'm running a 20mm adapter and they will barely clear the stock corrado brakes that are on the car now..
  4. Member !!Wild Man!!'s Avatar
    Feb 17th, 2009
    CHILE Pepper KIrQue
    VRTits 01 metallic beige
    02-27-2012 05:00 PM #4
    Nice build thread... if I email you pics will you make one for me?
    Jul 27th, 2010
    02-28-2012 11:34 AM #5
    Here we almost have the mk3 gti vr6 steering column almost in place. We are going to adjust the length about an inch or two so it'll meet up with the corrado steering rack. More wires being ran as well
    Also since they won't fit without getting new wheels, I decided to trade the brake kit for some parts.
    Jul 27th, 2010
    03-04-2012 01:35 PM #6
    Haven't done much the past few days. Once my short runner gets here we should be well on our way to being running
  7. Member Mean 'n Green86's Avatar
    Dec 16th, 2006
    mount joy PA
    86 Golf Sgt VW (project status), 07 Passat Wagon
    03-05-2012 09:10 AM #7
    nice build. i would throw the rebuilt vr in the donor mk3 and sell it for project money
    VW's the older the better
    http://www.4everkustoms.com/ <=THE BEST
    BUY MY PARTS MKII MOSTLY
    http://forums.vwvortex.com/showthrea...7#post82154097
    Jul 27th, 2010
    03-05-2012 10:12 AM #8
    That thing was wrecked pretty bad and went to the scrapper
    Jul 27th, 2010
    03-06-2012 08:38 PM #9
    So i got a bunch of goodies in this week, Short runner intake manifold, 42lb injectors, C2 42lb chip, and my intercooler stuff came. As of right now i'm waiting on a MAF sensor and a few misc screws and bolts.
    I took the old eip intake manifold off (for sale $150 shipped).
    Upon doing this I descovered this motor looks like its running an old school eip headspacer with the copper gaskets
    does anyone know about these?? any input or experience with them would be greatly appreciated!!
  10. Senior Member Capt.Dreadz's Avatar
    Jun 3rd, 2003
    Long Island, NY
    VRT's & 2.7T's
    03-09-2012 12:52 PM #10
    'scribed. Looking great so far. I wonder if that mk3 was this one...
    Chosen Life Clothing. Streetwear for the car culture. Launch Party coming very soon!!
    Meet Long Island The place if you're looking for a euro GTG in the Long Isl./New York City area.
    FaceBook: Carlitus Christensen Sr. - Instagram: @ThatDreadLife - Twitter: @ThatDreadLife
    Kicks...Clothes...Cars...Ho's...THINGS I DO BEST!
    Jul 27th, 2010
    03-09-2012 08:08 PM #11
    I don't think the car ever had decals on it but you never know!
  12. Member zwogti's Avatar
    Jan 11th, 2004
    Deerfied Beach, Florida
    2000 vr6 gti, 2001 vr6 jetta, 96 gti vr6-T Haldex
    03-09-2012 08:57 PM #12
    I don't know but it doesn't look like a copper head gasket, it looks like it does have more than one lay for the old copper head gasket they had to o-ring the head for better sealing and i even used some nice green tractor head glue that i can't remember the name, if you can go with a regular head spacer like the C-2 or some like that, it will seal way better
    2000 VR6 GTI, 2001 VR6 Jetta, 96 GTI VR6-T Haldex
  13. Member zwogti's Avatar
    Jan 11th, 2004
    03-09-2012 09:02 PM #13
    that look like copper spray, if it is, that's fine, i also use it on my head spacer to seal better.
  14. Member
    Jul 27th, 2010
    03-09-2012 09:20 PM #14
    Woo that makes me feel better. It does look like spray because it's flaking off as you can see in the pic.
  15. Senior Member Capt.Dreadz's Avatar
    Jun 3rd, 2003
    Long Island, NY
    VRT's & 2.7T's
    03-09-2012 10:17 PM #15
    FYI, There's nothing special about C2's head spacers. They are all the same, made the same way. The spacer is reusable, the gasket is what you change.
    Another thing. The spacer overlap (whats pictured) is not the part you need to worry about. You gotta expect the copper to dry up. It's not bonding anything & its exposed to the hot engine. All spacers have overlap. If the compression is on point...don't mess with what ain't broken. If the mileage is low, i don't see why there should be a problem. If it goes, throw the spacer (with new gasket skins) on the rebuilt spare.
  16. Member
    Jul 27th, 2010
    03-12-2012 03:07 AM #16
    Picked up a journal bearing precision 6262, waiting for that and a maf sensor. Updates to come..
  17. 03-14-2012 09:31 PM #17
    cool build man1 i miss my old coupe, this makes me happy
  18. Member
    Jul 27th, 2010
    03-23-2012 11:46 PM #18
    Okay, sorry for the lack of updates! A lot has happened in the past two weeks, Andy got the short runner intake manifold installed and started to mockup the intercooler stuff. I broke another phone and have to use an old one so the pics are terrible for now.
    the new short runner and radiator support are blocking the oil dipstick.. we are going to have to cut an inch or two out of it..
    there is an inch or two cut out of the bumper support and the intercooler is welded to it..
  19. Member
    Jul 27th, 2010
    03-23-2012 11:48 PM #19
    Here is the new daily.. as if one project wasn't enough..
  20. 04-02-2012 10:39 PM #20
    this is an awesome build! keep it up
  21. 04-12-2012 08:45 AM #21
    mhhh
  22. Senior Member Capt.Dreadz's Avatar
    Jun 3rd, 2003
    Long Island, NY
    VRT's & 2.7T's
    04-12-2012 08:24 PM #22
    Move the stick tube in between the intake runner. Here's a pic of mine to give you an idea.
  23. Member
    Jul 27th, 2010
    04-13-2012 12:44 AM #23
    Quote Originally Posted by Capt.Dreadz View Post
    Thanks Dreadz, great solution!!
  24. Member
    Jul 27th, 2010
    04-13-2012 11:31 PM #24
    This week I installed the new injectors into that shiny billet fuel rail and we finished all of the intercooler stuff..
    Few problems..
    The first and most serious is that I droped a bolt down this hole in the transmission (just my luck) is their a way to get it out without dis-assembling the tranny??
    second, we started hooking up some of the connectors for the wiring, I'm going to delete ac, power steering, and abs. What other connectors are not crucial? I just want to make sure I have everything i need to get this thing running (which is a mk3 vr6 motor, mk3 wiring harness, and mk3 interior all from the same car).
  25. Member
    Jul 27th, 2010
    04-17-2012 03:16 PM #25
    Good news, got that stupid bolt out and pulled the plug for that hole off my other tranny. Hopefully that will never happen again. This week we are hooking up all the wiring that we can and hoping she fires up, from there we will be pulling out what wiring I don't need little by little..
  26. Member FLATBLACKMK2's Avatar
    Oct 10th, 2003
    Mickey Mouse's Trouwzah'z Dude.Guy
    92 Monstah 4Lugz6Slugz,84 GLI fo'door
    06-23-2012 08:57 AM #26
    Broke.Status.N.E.K<3F6squared<3GetLow<3VwFiends<3Fifteen52<3Ban chWerks<3sdobbinsphotography<3CreEp CuStOmZR.I.P.ALEXIR.I.P.Scott TaylorR.I.P. Moses
    DrivenApparelGengstout#SLAW#
