Results 1 to 11 of 11
Thread: Suspension question
    May 11th, 2011
    right near da beach boii
    88 Cabby
    02-26-2012 05:29 PM #1
    Just curious, I'm looking to lower my car soon on H&R race springs. Simple setup for now. Well I noticed a few people selling different struts like S6 struts and RS6 struts.. What is the difference? Would I be able to install them on my struts or is aftermarket manditory for a safety feature?
    Low and slow rollin oem fresh
  2. Junior Member
    Jan 18th, 2012
    Boise, Idaho
    2000 Audi A6 2.7T
    02-27-2012 12:57 AM #2
    I'd go with after market to be safe. They're made to be that low. Either koni yellow or eibach pro dampers. If you already have h&r though I'd stick with their struts as well.
    May 11th, 2011
    88 Cabby
    02-27-2012 09:11 AM #3
    Ok so even the S and RS aren't recommended?
  4. Junior Member
    Jan 18th, 2012
    Boise, Idaho
    2000 Audi A6 2.7T
    02-27-2012 10:04 AM #4
    I'm honestly not too sure. I haven't seen anything about people dropping on S or RS's. Depend on how low thee ride off the manufacturing line I guess.
  5. Member MikkiJayne's Avatar
    Jan 1st, 2007
    UK
    02-27-2012 04:13 PM #5
    Factory sport struts (including the S6, don't know about the RS) only ride an inch or so lower than stock, and they do that by moving the spring platform. Afaik the H&Rs tend to sit pretty low so they'll probably bottom out the stock struts and kill them fairly quickly. I'd go with aftermarket ones that are designed for lower ride height like the Bilstein B8s
    May 11th, 2011
    88 Cabby
    02-28-2012 10:56 PM #6
    Thanks a lot for the info
    May 11th, 2011
    88 Cabby
    03-04-2012 10:58 AM #7
    Also I was told by a Raceland represenetive that 02 A4 Quattro front struts fit on the front of an A6.. Just wanted to know if anybody has done this of if there's any truth to it. Thanks
  8. Member MikkiJayne's Avatar
    Jan 1st, 2007
    UK
    03-04-2012 03:25 PM #8
    Yes they will. A4, A6 and B5 Passat are all the same at the front. A6 and Passat are different to the A4 at the rear though.
    May 11th, 2011
    88 Cabby
    03-04-2012 03:37 PM #9
    wow thanks alot for the awsome info
    May 11th, 2011
    88 Cabby
    04-04-2012 11:21 AM #10
    So I would assume that the 2000 A6 front struts are the same as the 02..? Are the rears the same too?!? Quattro of course
  11. Junior Member
    Jan 18th, 2012
    Boise, Idaho
    2000 Audi A6 2.7T
    04-04-2012 02:17 PM #11
    Yes.
