VWVortex.com - steering column
    Results 1 to 4 of 4
    Thread: steering column
    1. Semi-n00b
      Aug 6th, 2011
      Columbus, Ohio
      85 Scirocco 8v
      02-27-2012 08:06 AM #1
      So my steering column developed a pretty good wobble. Upon inspection there is what appears to be a plastic needle bearing and thin plastic ring that has slid down out of the bottom of the column tube. The bentley refers to this as a 'bushing' is this right? What is supposed hold this up in the column tube? Can I replace this without removing the steering column? And if I do remove the column should I consider replacing any other wear parts.
      Thanks,
      Ian
      This is an 85 8v
      Oct 26th, 2003
      The not so United Kingdom
      S1 2.1 8v
      02-27-2012 08:28 AM #2
      Fredybender on here makes a special retaining ring. Here is his ebay ad - it has a pretty good explanation of what happens
      http://www.ebay.com/itm/VW-Mk1-Lower...#ht_650wt_1156
    3. Member sciroccohal's Avatar
      May 4th, 2005
      Infrared AZ.
      2each'78s,81S,TTQ,S2 8V, race Corvette
      02-27-2012 09:49 AM #3
      Take a SS hose clamp....grease and push the bushing/bearing race back up the tube. Clamp in place.
      Cut the free 'ear' off of the clamp.
      total cost .37 cents
      It's the upper bearing that needs complete replacement usually....fortunately you can get the part and replace that one without removing the entire column.
      The feeling of immortality extends right up until the moment of impact.
      I cannot teach you how to be a Zen mechanic, grasshopper.
      The VW Scirocco, the worlds fastest ECONOMY car.
      I drive a 36 year old YORK with a Scirocco attached.
    4. Semi-n00b
      Aug 6th, 2011
      Columbus, Ohio
      85 Scirocco 8v
      03-04-2012 09:28 AM #4
      Thanks for the info!
