Results 1 to 30 of 30
Thread: How many square feet can one "float" flooring?
  1. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    02-27-2012 05:19 PM #1
    I have about a 650 square foot area (on slab) that we are planning to install some engineered flooring. It is tongue and groove style vs click lock, so I realize that we will have to glue the boards together.
    I want to float the whole floor vs glue to the slab, but I remember hearing somewhere that you can only "safely" float about 400 square feet without any kind of glued down transition. TIA for any advice!
  2. Member barry2952's Avatar
    Jun 13th, 2007
    Farmington Hills, MI
    02-27-2012 05:22 PM #2
    In for an answer. Probably has to do with expansion and contraction.
    Garmin Is My Pilot.
  3. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    02-27-2012 05:36 PM #3
    Barry, I figured you would have had the answer!
  4. Member Mk1Racer's Avatar
    Apr 16th, 1999
    NJ
    '99 B5 wagon (RIP), '01 B5.5 wagon, '81 Scirocco, '04 FXDWG
    02-27-2012 05:43 PM #4
    Check w/ the mfg. of the floating floor that you're going to use, I'm sure they have that kind of information.
  5. Member barry2952's Avatar
    Jun 13th, 2007
    02-27-2012 06:02 PM #5
    Quote Originally Posted by jerseygli View Post
    Actually, the only time I've used an engineered wood product was to line the cabin of my toy hauler in bamboo. I would never use bamboo for a real floor, though. Found it very easy to damage.
    Garmin Is My Pilot.
  6. Member
    Dec 17th, 2007
    Littleton, CO
    02-27-2012 07:03 PM #6
    Not floated, but we installed 1300sg ft of carbonized strand bamboo and it is invincible...which is a good thing, because you can see the few scratches due to the darker color. It took over a month to acclimate to our house because it's so dense.
  7. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    02-27-2012 10:15 PM #7
    Lurking around on a few diy boards has yielded some folks talking about floating large square footage areas (600-1100) but no one ever mentions glue down transitions aside from carpet reducers, etc. I'm leaning toward it's ok, but still on the fence.
    Also, called the manufacturer and they were closed for the night. Will try tomorrow.
  8. Junior Member
    Sep 18th, 2006
    MD
    MKVI GTI, MKIV VR6T (RIP)
    02-27-2012 11:00 PM #8
    I floated over 1200 sq ft of click-lock flooring over a slab. Spans 6 rooms - figured I could always cut it at the entrance to each room later and install a transition if there ever was a problem, but in over 7 years I haven't had any issues.
  9. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    02-27-2012 11:02 PM #9
    That is the kind of experience I was looking for! I'm going to go for it. Thx!
  10. 02-28-2012 10:45 AM #10
    Not as big as some of the other jobs, but I did a click and lock install with a few glued seams near the walls and tight spots. The room was 26 feet by 12 feet. No problems yet. It has been 6 months.
  11. Member barry2952's Avatar
    Jun 13th, 2007
    02-28-2012 11:31 AM #11
    Whatever you do, leave a substantial gap around the perimeter for expansion. I would even raise the base molding so that the floor could expand underneath it if necessary. Don't secure it to the sub-floor anywhere. Don't put anything super heavy, like a piano on the floor as the weight will keep the floor from moving and could bunch up on both sides in a high-humidity situation, if that applies.
    Garmin Is My Pilot.
  12. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    02-28-2012 12:32 PM #12
    Heaviest thing going on the floor is a couch.
    I was reading all about expansion last night. 1/2" - 3/8" is the general consensus for perimeter gaps on a floating engineered. The plan was to take the baseboards off for the install (vs adding a shoe molding). Then either reinstall the original baseboards, provided I can remove them without utter destruction, or install new, larger baseboards.
  13. Member barry2952's Avatar
    Jun 13th, 2007
    02-28-2012 12:37 PM #13
    Just remember that the expansion is directly proportional to the number of seams, so you might want to consider installing the flooring along the longer of the sides of the room. End to end expansion is less than side to side, I believe.
    Garmin Is My Pilot.
  14. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    02-28-2012 10:10 PM #14
    Good advice from all!
  15. Member
    Dec 17th, 2007
    Littleton, CO
    02-29-2012 08:48 AM #15
    I'd also make sure that if this is going on a sub grade slab, that you look into a moisture barrier. I've seen a few floors that had moisture come up from underneath and it curls all the edges and is almost unrepairable.
  16. Member barry2952's Avatar
    Jun 13th, 2007
    02-29-2012 09:22 AM #16
    You make a very good point. However, all that moisture under the vapor barrier can easily cause mold to form. Concrete wicks moisture from below all the time. We resolved this issue by installing a vapor barrier under the insulation that we poured the concrete floor on top of.
    Prove it to yourself with a 10 x 10 plastic tarp on your garage floor. In most parts of the country moisture will form overnight.
    This is truly one of those damned if you do and damned if you don't situation.
    Garmin Is My Pilot.
  17. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    02-29-2012 09:55 AM #17
    I haz no basement
    The install will be above grade, whole house is on a slab. This is going in the living room, hallway and kitchen.
  18. Member barry2952's Avatar
    Jun 13th, 2007
    02-29-2012 10:06 AM #18
    I haz no basement
    I would check with the manufacturer on the vapor barrier issue. If it's a laminate I doubt it would warp. If it's engineered wood, it could. There may be warranty issues, so it's best to check.
    Garmin Is My Pilot.
  19. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    02-29-2012 11:25 AM #19
    It's engineered. Plan (generally) is:
    Remove baseboard and current flooring
    Clean subfloor & check for level and moisture content (slab)
    Lay down moisture barrier/underlayment padding (still have to pick that product out)
    Install flooring as a floating installation (glue in the tongue and groove); with 1/2" - 3/8" expansion gap around perimeter
    Replace baseboards and install transition pieces
    Thinking to treat the kitchen and the living room as two separate projects and work them start to finish since this will be a weekend thing and I don't want to walk around in a construction zone if the weekends available aren't concurrent. Living room is currently carpeted, kitchen has some gross Pergo laminate.
    Sounds easy right?
  20. Member
    Dec 17th, 2007
    Littleton, CO
    03-01-2012 07:31 PM #20
    Sounds easy right?
    yeah, just like all house projects. no gotchas anywhere...
  21. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    03-01-2012 07:42 PM #21
    Quote Originally Posted by Papa Dras View Post
    According to HGTV it should only take about 30 minutes
  22. Senior Member FlashRedGLS1.8T's Avatar
    Apr 17th, 2001
    Ohio
    03-02-2012 10:40 AM #22
    I expect a "Everything went worse than expected" post but hope it's the opposite.
    Fun project.
  23. 03-02-2012 01:37 PM #23
    In for results as well. I have about 900 square feet of flooring to do between three adjacent rooms. We want to do it in a higher grade laminate, but also looking at some floatable engineered wood (High humidity region.)
  24. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    03-03-2012 11:34 AM #24
    So I'm thinking THIS for the underlayment. Anyone have opinions/experiences/cautions?
  25. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    11-04-2012 10:15 AM #25
    Well, it's done (was done in July). Took longer than 30 minutes - 2 full weekends to be specific with some serious friend help.
    Removed all the baseboards for the install. Ruined a couple on removal so we have to recut. But, it made for a nice finish. Floor went down pretty nicely. We floated everything, but there is a low transition piece in between the kitchen/dining (300 sq ft) and the living room/hall (~350 sq ft).
    I'm much happier with this than carpet all over the place. Dog is sliding all over the place and less enamored than me, but it's hilarious.
  26. Member Gale__'s Avatar
    Aug 28th, 2005
    Fairfax
    2012 GTI
    11-05-2012 10:21 PM #26
    Any pics of your baseboards? Are you getting any gaps? I'm about to dive in to the same situation (floating engineered on a slab).
  27. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    11-05-2012 11:13 PM #27
    Not really gapping, we ended up using quarter round so we could put the baseboards back in their original location. To get the baseboards to sit flush with the floor we would have had to nail them back lower on the wall. Then I would have had to paint all the walls around the trim again and I didn't want to go there. House was built in early 1960's so there has certainly be some settling over time.
    Surprisingly, I really like the quarter round as a finished product. I usually don't like it. We puttied the nail holes, the top of the baseboard to the wall and the seam between the quarter round and the baseboard.
    Hall pic (this is probably the largest gap I see over everything):
  28. Member drhavoc's Avatar
    Mar 1st, 2001
    Calgary
    11-07-2012 06:22 PM #28
    I covered 1500 sqft of my house in Floating floor, when we moved into the house is was carpet over particle board i didn't have the money for a new Subfloor so the next logical thing to do was a Floating floor. picked up 2000 sqft for 1.20 a sqft and spend 3 weeks of evenings and weekends putting the floor in.
    Its been 2 years now no buckling anywhere. I made sure i left enough of a gap for the walls which i'm going to be covering up with baseboard.
    these days true hardwood (Pine is not hardwood) is horribly expensive, this had the look and feel of walnut at 1/10th the cost.
    from this
    to this
  29. Geriatric Member firefighterjunkie's Avatar
    Mar 26th, 2004
    Silverdale, WA
    '04 GTI and '03 Passat Wagon
    11-09-2012 01:31 AM #29
    What brand and color is that flooring? Looks nice.
  30. Member jerseygli's Avatar
    Mar 16th, 2011
    Sicklerville, NJ
    2008 GLI
    11-09-2012 07:56 AM #30
    Thank you, it has lots of really cool color variations that aren't completely represented in that picture. It is Home Depot brand Home Legend Distressed Kinsley Hickory.
    Here is link.
