Results 1 to 6 of 6
Thread: Help: p0346 Camshaft Position Sensor "A" Circuit Range/Performance...
  1. Member Cabrio1.8T's Avatar
    Jan 6th, 2003
    ATL
    '95 Toyota Celica, '93 Isuzu Pickup, '73 CL350 Scrambler
    02-28-2012 09:36 AM #1
    I am trying to get rid of this code for a customer. Anyone had any experience with it? I don't have a VAG specific scanner, just a generic which does make it hard to get the real facts on this error. Swapping cam sensors left to right doesn't change anything. Searching brought nothing as well.
    The dealer swapped motors (I guess someone blew up the original), then swapped intakes. They messed up the intake flaps so that's where I come in. I fixed the flaps (and decarbonized it) and now its has much more power. Right now its hard to start, with a generic P0346 as well.
    Cliffsnotes:
    P0346
    BKH 3.2l FSI
    Junkyard motor.
    HELP!!
    P.S. I forgot: Car is '07 A6 3.2L FSI BKH
  2. 03-18-2012 03:05 AM #2
    Bad timing. You need to check timing with VAG-COM.
    - 94' Audi 100 CS Quattro 2.8L Sc
    - '07 Audi A6 3.2L FSI Quattro Stage 1
    [Various Auto Parts, Co.] [Automotive parts & Audi / VW Retrofit and coding services]
  3. Member Cabrio1.8T's Avatar
    Jan 6th, 2003
    ATL
    03-20-2012 01:59 PM #3
    Yup, I think the variable valve stuff is gummed up. We sent the car on because It had more power then when it came, but the customer didn't want to put anymore money into it (I suggested maybe a nice Honda or Toyota)
  4. Member Cabrio1.8T's Avatar
    Jan 6th, 2003
    ATL
    03-23-2012 05:25 PM #4
    Guess who's back. I've swapped the vvt actuators around and even partially taken apart the core motor that got swapped out. HOW DO THESE THINGS WORK??? I don't see how the variable timing comes in.
  5. Member The Sage's Avatar
    Jul 30th, 2004
    Mobile, AL
    13 AW 328 M-Sport 04 DBP R32, 01 RS VRGTI, 04 CW TREG
    04-05-2012 12:08 PM #5
    robby is that you? i think they sent me the car you are working on, and im pretty sure the timing is off.
  6. Member Cabrio1.8T's Avatar
    Jan 6th, 2003
    ATL
    04-06-2012 07:48 PM #6
    Yup, we ended up setting the car on fire. Problem Solved!
    ps: Jessie sucks
