VWVortex.com - Fuel gauge and temp gauge not working. 92 vw cabriolet
    Results 1 to 8 of 8
    Thread: Fuel gauge and temp gauge not working. 92 vw cabriolet
    1. 02-28-2012 01:11 PM #1
      I love my 92 VW Cabriolet, but my fuel gauge is stuck on E and refuses to move. I have been using the odometer to keep track of my fuel, but it is getting annoying ! Also, the temperature gauge doesn't move at all. Can anyone help me solve these problems? Thanks!
    2. Junior Member
      Feb 2nd, 2012
      1990 Volkswagen Cabriolet, 5 speed
      02-28-2012 01:26 PM #2
      It could be that your fuel level indicator on your instrument cluster could be bad.
    3. Junior Member
      Feb 2nd, 2012
      02-28-2012 01:28 PM #3
      Temperature gauge, do you mean the Oil temperature level, where it says Celcious?
    4. 02-28-2012 01:31 PM #4
      Yes, I meant the oil temperature gauge where it says celcious.
    5. Member MSTRBD's Avatar
      Dec 21st, 2005
      Hell Paso TX
      '92 16v Cabby, '84 BMW E30 Coupe, '03 Jetta Wagon, '07 Passat Wagon
      02-28-2012 02:05 PM #5
      check the fuel sender in the pump assembly, its under the rear seat, on the right side.
      change the coolant temp sensor, its on the coolant flange in the head, its the black one.
    6. Member CajunSpike's Avatar
      Mar 11th, 2009
      New Orleans, LA
      91 Burgundy Etienne(2), 06 Jetta 2.5, 08 GTI 2.0T FSI
      02-28-2012 02:51 PM #6
      I've read a bad 10v transformer on the back of the cluster..can cause this, leaving the cluster parts not working.
      Correction..if just the fuel gauge on the cluster isn't working, then i'd suspect the sending unit in the tank.
      If the oil temp gauge isn't working, I'd suspect its not plugged in to the sensor correctly or the gauge has died.
    7. Junior Member
      Feb 2nd, 2012
      02-28-2012 03:54 PM #7
      Quote Originally Posted by cab92 View Post
      Could be a bad gauge, or a sensor in the car. I bet its a bad sensor.
    8. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      02-28-2012 08:08 PM #8
      Quote Originally Posted by CajunSpike View Post
      DING DING DING... we got a winner here folks.
      There are 3 threads that deal with this issue that I wrote,
      How to test your Gauge with out having to remove crap from your car.
      Take the connection off the black sender in the water outlet flange, and use a 9V battery
      Jumper the wires fro the battery to the sender. The gauge will deflect 3/4 to full (key is not in the ignition.
      How to repair a flaky water temp gauge.
      http://www.toplessrabbit.com/forums/...hp?f=27&t=2042
      How to tell when your 10V regulator isn't getting voltage to power it.
      http://forums.vwvortex.com/showthrea...ght=mr.+wizard
      How to repair your cluster.
      http://www.toplessrabbit.com/forums/...cluster#p21710
      Your 10V voltage stabilizer is probably bad, or not getting the voltage off of pin 12 (black) on the back of the cluster.
      http://www.toplessrabbit.com/forums/...bilizer#p22145
      Grounds, Grounds, Grounds Replace them things.
      Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
      Another Useless Ground Thread
      HAVE YOU CHECKED THE FAQ's ABOVE..PAGE 3 Thread 75? Why bother no one else does.
      You can lead a user to a link, but you can't make them click.
