Page 1 of 2 1 2 LastLast
Results 1 to 35 of 36
Thread: Stubborn P0441 code
  1. Member bbong73's Avatar
    Sep 12th, 2002
    2006 MKV GTI
    02-28-2012 09:13 PM #1
    I've been troubleshooting this code for a while now with no luck. So far I've replaced the gas cap, N80 valve, the new updated hose for the N80 valve and even the carbon canister. No matter what the code has always come back.
    I've ran Basic settings 70 with vagcom and ran the evap test and it fails when it gets to 66.8%. Don't know what these numbers are telling me though. Anybody know?
    In another forum somebody mention checking the double check valve (in red below) with a vacuum. I was not able to pull a vacuum on it. I don't know what its suppose to do. This double check valve is to the left of the N80 valve
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Control Module Part Number: 1K0 907 115 B HW: 1K0 907 115 B
    Component and/or Version: 2.0l R4/4V TFSI 0040
    Software Coding: 0403010A18070160
    Work Shop Code: WSC 65728 1018 854933
    VCID: 254B9B83ECFA27B
    1 Fault Found:
    001089 - EVAP Emission Control Sys
    P0441 - 002 - Incorrect Flow - MIL ON
    Freeze Frame:
    Fault Status: 11100010
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 205092 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:41:35
    Freeze Frame:
    RPM: 742 /min
    Load: 20.8 %
    Speed: 0.0 km/h
    Temperature: 81.0°C
    Temperature: 18.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 13.970 V
    Readiness: 0000 0000
    Jul 10th, 2011
    California
    02-29-2012 12:21 AM #2
    Quote Originally Posted by bbong73 View Post
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 205092 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:41:35
    Freeze Frame:
    RPM: 742 /min
    Load: 20.8 %
    Speed: 0.0 km/h
    Temperature: 81.0°C
    Temperature: 18.0°C
    Voltage: 13.970 V
    Check the leak detection pump, lines, clamps and anything related for leaks. Hoses can become porous and cause a leak detection failure code P0441. The code is pointing at a small (0.020) leak detected. Most of the time it's the cap seal. Did you buy an OEM cap ?
  3. Member bbong73's Avatar
    Sep 12th, 2002
    2006 MKV GTI
    02-29-2012 10:06 AM #3
    Yes it was an OEM cap. I believe I'm on my third cap actually.
    Does anyone know how the double check valve work. Should I be able to pull a vacuum on it from the hose that attaches to the left side of the N80 valve?
    I've looked over the hoses but didn't see anything. I might have to figure out how to smoke them.
    What about the Basic setting 70 test? Anyone have info on that?
    Thanks, this is really getting annoying now
  4. 02-29-2012 04:06 PM #4
    This code doesn't point to a small LDP leak or a gas cap related DTC DR.
    The N80 could be faulty or you could have a vacuum leak.
    An exhaust leak can also cause this DTC if diluting the reading of the OXS.
    This error is directly related in some cases to a rear OXS sensor sometimes going faulty or removed by a sloppy tuner.
    Try spraying some light lube in the N80 and run outputs to exercise it.
    FACT
    Codes relate to evap N80 function have no relevance to the gas cap, tank being faulty, or a line to LDP after junction and check valve under the hood area.
    You can run test 01-04-070 in any car and have the gas cap removed and it pass.
    The thing that screws everyone up is that fact of how the codes are labeled and that the N80 evap test and LDP share a readiness bit. The repair information is really vague here almost to a fault on purpose to sell gas caps. LOL
    Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
    7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
    European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
    Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
    vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
  5. Member bbong73's Avatar
    Sep 12th, 2002
    2006 MKV GTI
    02-29-2012 08:39 PM #5
    Yeah LOL
    I've been told a lot to change the gas cap.
    I've exercised the N80 valve recently and its relatively new also.
    Any idea if I should be holding a vacuum on the hose that attaches to the left side of the N80. The one that goes to the double check valve or pressure limiting valve?
  6. 02-29-2012 10:16 PM #6
    Nope you shouldn't be trying to hold a vacuum at the TV side.
    Vacuum should be present when at idle to draw vapors in when switched via the N80
    Yeah and you don't need a gas cap.
    Jul 10th, 2011
    California
    03-01-2012 02:15 AM #7
    Quote Originally Posted by Jack@European Parts View Post
    The information available through All Data points to a small leak detected. I never said it was a LDP issue. P0441 indicates a "system" leak detected and some aftermarket caps will fail to seal the system.
    Jul 10th, 2011
    California
    03-01-2012 02:18 AM #8
    OP. You should find a smoke machine and perform a system leak/integrity test
  9. 03-01-2012 09:53 AM #9
    If pointing to a gas cap you are in fact stating its an LDP leak.
    You have them confused just like everyone else.
    EVAP tests for 070, require no gas cap to pass, and have no relevance to leak for N80.
    The repair information, if states this, is wrong.
    The Gas cap is only tested via the 071 for LDP.
    Do the tests with VCDS directly you will see I'm correct.
  10. Member bbong73's Avatar
    Sep 12th, 2002
    2006 MKV GTI
    03-01-2012 10:00 AM #10
    What does EVAP 070 test?
    trying to figure out what the numbers mean. Mine fails at 66.8%
  11. 03-01-2012 10:29 AM #11
    070 tests the evap N80 for vapors.
    071 tests the LDP for tank and cap.
    Jul 10th, 2011
    California
    03-01-2012 10:47 PM #12
    That's what the actual test performs, but the DTC is for a system leak. It's not looking at only N80.
    It reports as a "SYSTEM LEAK", so it could be anything.
  13. 03-02-2012 09:11 AM #13
    No doctor, I believe you are incorrect.
    http://wiki.ross-tech.com/wiki/index...5/P0441/001089
  14. Member
    Feb 25th, 2010
    Wilkes-Barre, PA
    03-02-2012 10:20 AM #14
    If you clamp the purge valve hose and run the test you will get the P0441 code. If it’s stuck closed you get the code.
    If you have a leak after the LDP you get a P0442
    I am going with Jack on this one.
    Good Luck
  15. Member
    Jul 10th, 2011
    California
    03-02-2012 12:19 PM #15
    Probable cause/possible symptoms also points to leak issue's in both All Data and Ross-Tech information as seen here.
    16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    Possible Causes
    • Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
    • Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
    • Evaporative Emission (EVAP) Canister Sealing faulty
    • Pipes between Tank Breathing and Throttle Body leaky/blocked
    Possible Solutions
    • Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
      • Perform Output Test
    • Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
      • Perform Basic Setting
    • Check Pipes between Tank Breathing and Throttle Body
    Special Notes
    • When found in the NAR 1.8T Audi A4 1.8T check TSB 24-08-78 or 2010268/3 or Pass-Thru equivalent TSB
    • When found in the NAR 1.8T VW Passat 1.8T check TSB 01-09-09 or 2005554 or Pass-Thru equivalent TSB
      • Note: The Passat 26E5 or "R5" recall includes the same software update
    • Make sure the quick release lines for the N80 valve and vacuum line to LDP are not crossed.
      • This can also make the engine hard to start after filling up the fuel tank.
    Category: Fault Codes
    They are looking for leaks, especially from the canister lines to the evap-purge valve N80.
    I bet it's a leak near the canister and only a smoke machine will find it
  16. Member
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    03-02-2012 01:44 PM #16
    Are you saying that the N80 valve shouldn't hold vacuum on the TV side when tested out of the car
    Dr Diesel, I also believe you incorrectly stated to check the LDP in your first reply. This code indicates a problem between the canister and N80, not the LDP.
    As I understand it, 16825 (P0441) is a problem between the canister and throttle body (including N80), tested in 070. So, a leak or blockage in the line from the canister to N80 would cause this code, as would a faulty N80.
    16826 (P0442) indicates a leak involving LDP, or the tank side (including the gas cap), tested in 071.
    The difference is easy to see when you watch the blocks while running the basic settings.
    I have to agree with Dr Diesel on one general aspect though...smoke is instrumental in finding EVAP leaks, wherever they may be hiding. They can be very difficult to diagnose without a smoke machine.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  17. 03-02-2012 03:23 PM #17
    Why "Dr. D. " , the information you site, and everyone posts is incorrect in regards to this.
    How many times do I have to say that the repair manual is WRONG!
    Thats the factory OE manual and as for All Data you might as well have NO DATA!
    Smoke is for morons which cant read a gage, or a book proper for visual like picture books for kindergärtners! To be fair, there are some uses for smoke, and here its just plain stupid with two vacuum hoses. OH BOY! where are those razor blades?
    I think its time RT teaches a EVAP and LDP advanced readiness test class.
    This one will cost big bucks though!
    On the bench Brian YES with the noid active NO.
    There should be no vacuum held between the TV and the valve itself as this would indicate FOD.
  18. Member
    Jul 10th, 2011
    California
    03-02-2012 05:10 PM #18
    Uhh Hmm! That's your information you provided in your link in your post #13
  19. 03-02-2012 05:48 PM #19
    Respectfully No! Dr. Dummkopf...... FAIL
    What I'm saying is, what your saying, and the repair information is wrong.
    No where in that repair information, does it say small leak.
    You of course want to antagonize me, rather then try to learn.
    Good for you!
    Poster if interested in real technical information contact me via the PM.
    I'm done here today, its dinner time.
    P.S. Smoke vs a gage I will take a mighty vac gage any-day.
    You sir need visuals, I guess.
  20. Member
    Jul 10th, 2011
    California
    03-02-2012 11:51 PM #20
    Good for you!
    Well. I can't verify your claim of information accuracy, so until that time it's the information I use.
    If it wasn't correct, why would Ross-Tech have it posted in the WiKi ????
    Yes, I like the visual smoke test because it shows the leak. Yes, I could use the vacuum decay test to verify the leak, but you still haven't located it. Smoke shows you where it's at, right now. It's verified while testing. I use my smoke machine for many other tests too. It's a quick way to find intake leaks and pirate air behind the MAF. Quick, accurate and simple. I like the KISS method when available. If you choose to remain a Dummkoff parts changer, that's your prerogative. Good luck
  21. 03-03-2012 10:12 AM #21
    Actually I like to isolate a zone with a vacuum gage and then just remove and replace the zone for inspection.
    Further I will tell you why I don't like smoke. It's not under PSI or vacuum.
    So what I do is pressurize the zone with air and intake spray then use a halogen AC detector to find small leaks.
    Large leaks if you cant find them needing smoke or carb cleaner you have to be an idiot.
    It is very rare I replace anything. Most of the time I do a repair with a double braided vacuum line.
    Your just assuming I change parts. This is something I hate to do. I am more about finding the problem and conducting functional tests, vs wasting money on garbage costly equipment such as a smoke machine or AVR.
    Running tests in VCDS to verify what I said costs nothing but time.
    I told you how to run the test to prove it to yourself.
    Take a gas cap off and run the 070 test you will see it will pass without it. Then maybe the light bulb will go on in your head.
  22. Member
    Jul 10th, 2011
    California
    03-03-2012 01:52 PM #22
    Smoke is under pressure.
    I like to use it for that exact reason. When going into a repair facility to find and fix problems, it's a quick and handy money making tool. I have no idea what someone else has done to most of the problem child's, I get stuck with. Having a quick and simple diagnostic tool at my disposal makes perfect sense for me. If you're removing and isolating sections of the Evap system to verify if it leaks or not, you're wasting time and burning hours that could have been spent making money. If you're using carb spray to find a leak, you're a step away from major liability issue's.
    Having diagnostic tools and knowing how to use them to save time and money makes perfect sense, even if you don't agree with it. As long as you keep it civil and refrain from the name calling or trying put others down for the tools they use to simplify diagnostic, we might actually be able to learn form one another. You don't know everything there is to know about automotive repair, so just chill out and allow others to have and express their opinions and knowledge without being rude, arrogant and ignorant, just because your don't agree with it. This is a public forum with hundreds of user's that have different idea's and opinions, just like you. They don't act like a horse's behind with rudeness and ignorance, so why do you find the need to act like you know everything and everyone else is just stupid. That's as STUPID as STUPID get's.
    Thanks for sharing your knowledge and expertise. I'll most definitely remember to use that strategy the next time I run across and Evap issue, along with my smoke machine
  23. 03-03-2012 02:46 PM #23
    I never said you weren't entitled to your opinion. Your the DR. How more arrogant do you get with that title.
    Are you really a doctor?
    You just mix up the items of the evap system because your so well versed, I can only guess.
    I diagnose an evap LDP, or N80 breather issue in about 10 minutes, without the cost of a smoke machine, is what I'm saying.
    Smoke in many cases cant get passed check valves, or additional N series noids. This is why it is superior to isolate zones with a might vac, while using output diagnostic test modes, or basic setting tests to be initiated. Smoke doesn't find stuck valves, it just finds an open hole for your visual experience.
    To each his own, but you should know how the system works, before recommending a part such as 3 gas caps, or 3 LDP pumps like a recent dealer. Oh yeah, guess what? The smoke didn't help them, because they were to busy smoking the pipe.
    You are the one who is being short sighted. Put on your glasses.
  24. Member
    Jul 10th, 2011
    California
    03-03-2012 03:14 PM #24
    Are you really a doctor?:)
    You just mix up the items of the evap system because your so well versed, I can only guess.:P
    You are the one who is being short sighted. Put on your glasses.:thumbup:
    See! That was much better. My screen name isn't related to who I am or what I do. It was my diesel truck platform "DR" back in 1996, so I used it as a log in name and it stuck.
    I'm sure you are very knowledgeable and have tried and true diagnostic strategy methods that work very excellent. I'm new to the Euro stuff and always willing to learn from others. You sound a like someone that knows a lot. It's just difficult to deal with your online personality, or should I say lack of. Don't take it the wrong way. I'm not trying to say your wrong or don't know what you're talking about. Don't jump on the defensive right out of the gate. I respect what you say as far as automotive information, but not the disrespectful manner you find necessary to use towards other people. Take the EGO down a few notches and you'll find it's a better way to communicate with others. We can stay on topic and avoid the ignorance.
    Like I said. Thanks for sharing your expertise. I appreciate your input. I enjoy learning something new.
    THANKS.
  25. 03-03-2012 03:32 PM #25
    I take it you did the test in VCDS in 01-04-070 with the gas cap off finally.
    Look man, its nothing personal, I'm just a big prick, I guess.
    I apologize if I come across this way....... It is intentional though. ZOINKS!
    You do in my belief try to antagonize me, then you get what you get.
    If you haven't done the test, please do so, so you can accept your error in post #2, in your mind.
    This always hurts more. See now I'm being a jerk again, sorry.....BANG BANG!
  26. Member
    Jul 10th, 2011
    California
    03-03-2012 11:57 PM #26
    Thank you, Sir. Next time I get a chance to, I'll perform that test.
    Thanks for the help and educational guidance Knowledge is power
  27. Member
    Feb 25th, 2010
    Wilkes-Barre, PA
    03-04-2012 10:37 AM #27
    Very nice argument guys! Glad to see it’s settled with everyone on good terms!
    Dr. you’re alright not many hold a respectable argument with Jack and learn something in the end. They usually blow a head gasket and learn nothing.
    Jack is one of the best on this forum and puts a lot of time in the forum. His people skills need some work but this is not a personality contest.
    What matters here is VAG problems and solving them. I learned a lot from this post and so will others. I have no idea where the original posted went or what he did about his problem? But I enjoyed reading it all and I LMAO at times.
    I also agree knowledge is power! Good argument Guys!
    Good Luck
  28. Member bbong73's Avatar
    Sep 12th, 2002
    2006 MKV GTI
    03-04-2012 07:20 PM #28
    So...now that that is settle, I think.
    I'm more confused then ever as to how troubleshoot this code.
    Anybody want to get me back on track
  29. 03-04-2012 09:06 PM #29
    Did you run the test for 01-04-070 and follow the pinch line procedures in the repair manual for N80 tests?
    Have you replaced the N80?
    Have you attempted lube of the N80 and exercise of the outputs to verify the valve doesn't stick with a mighty vac?
    Any intake leaks? If there is a slight leak the test will never complete.
    Air mass must also be on target.
  30. Member bbong73's Avatar
    Sep 12th, 2002
    2006 MKV GTI
    03-05-2012 07:54 PM #30
    Are those under Basic Settings?
    I've ran the 070 test and it fails at 66.8%
    I've exercised the N80 valve and it seems to be functioning and not sticking. It holds a vacuum too. It is kind of new.
    I don't know what 01-04-070 is? Didn't see any test under Basic Settings 001 or 004
  31. 03-05-2012 08:37 PM #31
    Yes under basic settings.
    Do this.
    01 engine electronics - 04 basic settings - 070 evap test GO ON
    If there is a slight intake leak, double or single check valve, or false air of any kind the N80 test will fail.
    If the air mass is out of calibration it will fail.
    If the rear OXS sensor is faulty, unplugged, exhaust leak, or deleted it will fail the test.
    If the throttle valve is not adapted, faulty or dirty it will fail the test.
  32. Member bbong73's Avatar
    Sep 12th, 2002
    2006 MKV GTI
    03-05-2012 09:02 PM #32
    ok, yeah that's the one I've ran plenty of times and it fails when it reaches 66.8%
    Interesting that you say it will fail if the throttle body is dirty. Would this code come up if the intake valves were caked up. My car has 130k miles and they are bad. I'm getting like 26mpg lately. I'm ready to clean them actually. I need to take a look at the throttle body as well.
    I don't know what else it could be.
    You don' think its the pressure limiting valve after the n80 valve?
  33. 03-05-2012 09:40 PM #33
    Sure if they are caked.
    Limit should also be checked.
  34. Member bbong73's Avatar
    Sep 12th, 2002
    2006 MKV GTI
    03-05-2012 09:42 PM #34
    sorry, how do I do that?
  35. 03-05-2012 09:45 PM #35
    RTFB.
    Time to start doing some reading and applying tests.
    It is most likely a vacuum leak. I would start spraying with intake spray at idle and watch the misfire detection in VCDS to isolate.
    Any leak anywhere in the intake side will cause this problem like you describe.
