Results 1 to 17 of 17
Thread: FS: O2M 02M 6-speed manual trans, 42k miles South Jersey
  1. Member GTI...VRsicks's Avatar
    Jun 17th, 2004
    Pennsauken, NJ
    1999.5 GTI R32 Turbo, 1999 BMW e46, 2003 GTI VR6 Turbo RIP
    02-28-2012 11:32 PM #1
    This is a VR6 02M transmission for sale it had 42k when pulled from my old car its in great condition, shifts smooth, I'd keep it if I honestly had the room. This was custom built with R32 gears, shifter forks, and shift tower which are all 02Q parts, this means stronger and lengthened gears! I'm just trying to get it sold to someone who can use it right now. Only problem with it is it hit a manhole cover when I blew out my oilpan and two small spots on the bottom are ground down by bolt holes but it never leaked a drop of fluid and still shifted and drove perfect. I'd rather not ship it but would if need be, Local pickup in South Jersey is preferable.
    $550 OBO picked up
    $700 SHIPPED within the 48 states
  2. Member GTI...VRsicks's Avatar
    Jun 17th, 2004
    Pennsauken, NJ
    03-01-2012 08:34 PM #2
    BUMP!
  3. Member GTI...VRsicks's Avatar
    Jun 17th, 2004
    Pennsauken, NJ
    03-07-2012 01:08 AM #3
    BUMP.... pickup special 500 this week ONLY want this out of my garage I have toooooo many projects not enough room!
  4. Member GTI...VRsicks's Avatar
    Jun 17th, 2004
    Pennsauken, NJ
    03-09-2012 01:21 AM #4
    Get it gone bump great 6 speed!
  5. 03-11-2012 11:38 AM #5
    What exactly is different about r32 gears?
    I am here: http://tapatalk.com/map.php?dk0pgh
  6. Member GTI...VRsicks's Avatar
    Jun 17th, 2004
    Pennsauken, NJ
    03-11-2012 12:14 PM #6
    I believe fifth and sixth is longer they'll get you to 180
  7. Member GTI...VRsicks's Avatar
    Jun 17th, 2004
    Pennsauken, NJ
    03-11-2012 12:17 PM #7
    And all the 02q stuff is just stronger
  8. Junior Member
    Jan 25th, 2012
    Alexadnria, VA
    2003 Volkswagen Passat
    03-12-2012 03:20 AM #8
    WILL THIS GO ON A PASSAT b5.5?
    AyeTee
  9. Member GTI...VRsicks's Avatar
    Jun 17th, 2004
    Pennsauken, NJ
    03-12-2012 05:29 PM #9
    Prob would if its a vr motor
  10. 03-12-2012 08:22 PM #10
    Can you please post some pics of the ground down spots on the tranny.? And why are you selling the tranny? Also, does it have the stock differential in it?
    I am here: http://tapatalk.com/map.php?xuynod
  11. Member GTI...VRsicks's Avatar
    Jun 17th, 2004
    Pennsauken, NJ
    03-12-2012 10:35 PM #11
    Yeah stock diff is in the trans that's the reason I'm running a different trans bc I got an 02m with cryogenic gears and a peloquin.... A Turbo requests these upgrades
    Here's some pics
  12. 03-13-2012 10:13 AM #12
    Thanks for pics. And ya I'm making 550 in my VRT and I have killed two trannys in about a year and a half lol. How much was it for you to put cryo'd gears and a peloquin in? What's your opinion on the LSD?
    I am here: http://tapatalk.com/map.php?p5lo05
  13. Member GTI...VRsicks's Avatar
    Jun 17th, 2004
    Pennsauken, NJ
    03-13-2012 07:27 PM #13
    Cost 2gs for trans and all... Haven't driven it yet
  14. Member VR6duBBr's Avatar
    Mar 22nd, 2005
    SF Bay Area
    2004 GTI 24v
    03-14-2012 02:54 PM #14
    Interested in this tranny. Are you sure it doesn't leak at all? I have an '04 with 190k on it and the tranny has been whining for damn near 90k miles so Im about ready to get rid of it. Send me a pm Thanks.
  15. 03-14-2012 05:22 PM #15
    Can you please give me more information about the built tranny you are running. 2gs is like free for a tranny like that.
    I am here: http://tapatalk.com/map.php?po5qd2
  16. Member GTI...VRsicks's Avatar
    Jun 17th, 2004
    Pennsauken, NJ
    03-15-2012 07:09 AM #16
    Sold
  17. Member VR6duBBr's Avatar
    Mar 22nd, 2005
    SF Bay Area
    2004 GTI 24v
    05-30-2013 04:00 PM #17
    Bought this tranny over a year ago. As soon as I got around to putting it in my car it was nothing but major problems. Those supposed light scuffs from a manhole cover were huge hits that caused it to leak fluid from everywhere pouring out. The speedo sensor was shoved in the sensor hole with a ton of RTV sealant trying to make it look like it was working which it clearly wasn't. The input shaft seal was destroyed which blew fluid all over a brand new clutch that I had to throw away. And he failed to mention that although it may have R32 internals it is a 4-cylinder case sealed up to a 6-cylinder bell housing and was done half-ass so they cut a hole into the case side to make it bolt up. oh! and before I forget, the holes for the dogbone mount were both stripped out completely! All in all it was a huge nightmare. Bottom line is that this guy is a LIAR and I say this to protect all others from getting screwed. Watch out for this scammer.
