Results 1 to 4 of 4
Thread: Looking at a 2008 2.0T Roadster. Need Advice
  1. Semi-n00b walkwg's Avatar
    Sep 14th, 2006
    North Alabama
    2011 Audi TT, 1995 BMW R1100RSL
    02-29-2012 10:17 AM #1
    Local dealer has an extremely clean 2008 Roadster with only 21k miles. It would replace my '03 GTI as my daily driver I'd like to get some advice from the collective wisdom.
    Can someone tell me what timing belt interval is on this car?
    Did all of the '08s come with the dinky little armrest? It is missing on this car.
    I would plan to have the satellite module installed. Are there any other updates that you feel are essential to make it comfortable daily driver?
    2008 was a generation change year. Are there any big things I need to look out for?
    Is it worth spending another $10 - $12k to get an '11? What would I get for the money that would make it worthwhile?
    Thanks in advance for the help.
    Bill
  2. Member damianp's Avatar
    Sep 8th, 1999
    Westchester County, NY
    2008 Audi tt roadster, 2009 A4 Q 6ps M
    03-02-2012 09:16 PM #2
    I actually got the same car about 6 months ago, with about 47k. Mine is not a daily driver, BUT I do drive it a LOT more than my older 2002 TT it replaced.
    Check the stereo, the amplifier in the trunk for the bose system tends to blow due to corrosion build up due to moisture. If not under warranty, you are looking at a 800-1000 dollar repair.
    Mine had to be replaced as it was draining the battery every day.
    Also, check to see if it has run flats. I forgot it didn't have a spare and mine didn't have run flats on the stock 18's, the fix a flat crap does nothing for a blown side wall.
  3. Semi-n00b walkwg's Avatar
    Sep 14th, 2006
    North Alabama
    03-02-2012 10:27 PM #3
    Thanks for the info. This one has about a year left on the original warranty and then the two year CPO. I'm also looking at a couple of '11s. Are there any other reasons not to get the '08 and save the extra $10k?
  4. Member sentari's Avatar
    Dec 3rd, 2011
    2008 Audi TT 3.2 VR6 Turbo/DSG and 2008 Audi A4 Cab 2.0
    03-03-2012 04:25 AM #4
    Mine does not have the little "arm rest" pad either. That must have been some option. I have a DSG/3.2 Coupe/Mag Ride. It's an 08 as well. I have no idea why one would buy something newer if there are good used ones to buy. Mine had 40K on it when I bought it 4 months ago and looks brand new.
    Sentari,
    2008 Audi TT 3.2 (HPA FT500 Turbo): Build: http://forums.vwvortex.com/showthrea...ts-Turbo-Build
    2008 Audi A4 2.0T Cab (Hi-Flow Cat and APR Tune!)
