Results 1 to 6 of 6
Thread: Which of these tire setups will provide more cornering grip - all else equal?
  1. 02-29-2012 11:34 AM #1
    225 R-Comp or 255 Star Spec (or similar)?
  2. 03-01-2012 02:16 AM #2
    Depends on what type of R comp and under what use conditions, track or autox. Then comes track temperature and conditions. Why not just do a wider R comp?
  3. 03-01-2012 04:20 PM #3
    Road race use.
    The two options are "scoring neutral" in NASA. A larger r-comp means I probably have to move up a class which I don't want.
  4. Member 4ceFed4's Avatar
    Apr 3rd, 2002
    Long Island, NY
    '10 JSW, '02 GTI, '08 MCS, '12 Fusion
    03-01-2012 11:21 PM #4
    It's really condition dependent, like rex said. Unless you have 9"+ wide wheels to mount the 255s to, your contact patch isn't going to be the full 255. I run 225 star specs when it's cold and/or wet, and 265 f/225 r r-comps when it's warm.
    Evolution Euro Militia
    Tons of MK4 Stuff For Sale HERE
  5. Member Ryan E.'s Avatar
    Oct 1st, 2002
    Huntington Beach
    2008 CW R32, 2003 1.8T GTI, 1974 2002 tii
    03-18-2012 11:29 AM #5
    I'd run the r-comps, they can take more heat and are usually lighter with a stiffer sidewall.
    Rigi Cola.
    "The VR6 was an orchestra of well-tuned cylindrical delights." - jalopnik.com
  6. 03-31-2012 06:38 PM #6
    Id run the r-comps (hoosier, BFG, or V710). They will have equal or better grip, take hard track abuse/heat , and they will weigh less. Problem would be the tire wear.
