Results 1 to 18 of 18
Thread: Big cam with dual carbs question
  1. Member VWaddict01's Avatar
    Dec 12th, 2011
    Seattle Washington
    Type I's/II's/III's,Mark2,B1,Rabbits and Rocco's. But at this time-79 Rabbit ,90 Vanagon,77 Passat
    02-29-2012 02:49 PM #1
    I have a 1.6 rabbit, and I recently aquired a 1.6 carburator head that has been ported/polished/shaved,3angle grind, has big valves and HD springs and a 298 delta cam(as told by PO) already put together and ready to drop in.
    My question is, if I get dual 40 weber side draft carbs, will that cam still be too big for the street? I can deal with a super lumpy idle as long as my motor doesn't cut out all the time.
  2. Member B4S's Avatar
    Apr 16th, 2003
    Marionville, Ontario, Canada
    1997 Ford Aspire, 1989 Dodge Colt GT Turbo
    02-29-2012 03:07 PM #2
    Cut out?
    No cam is too big for the street, but it might be too big to be pleasant to drive. Especially if it's only tuned for WOT. A proper tune, with the proper internals in the carbs will go a long way towards making it driveable, but with a cam that big, you're going to have a very soft bottom end for sure.
  3. Member VWaddict01's Avatar
    Dec 12th, 2011
    Seattle Washington
    02-29-2012 04:58 PM #3
    Quote Originally Posted by B4S View Post
    Cut out?
    Cut out, like not bieng able to keep an idle. Yeah that's what I was thinking, it'll be fun in the freeway, but around town it might be a hassle. I'll probably go down to a 288 then...
  4. Member B4S's Avatar
    Apr 16th, 2003
    02-29-2012 08:15 PM #4
    Ah, ok. It would definitely require a higher idle to stay running I would assume. Might need to be ~1300-1500, but I have no experience with a cam that heavy.
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    02-29-2012 09:30 PM #5
    It gonna be an all or not much affair. Small displacement + really big cams means you will have a high idle and power is not gonna come on until about 5k. It will work but you will have to wring its neck to get it to respond well. A 4.25+ final drive would help. also you need as much compression as you dare. 12:1 and race gas.
    To me this would not be a daily driver choice but for a toy car you may as well go ahead and see what you think. It's easy enough to change the cam later.
  6. Member VWaddict01's Avatar
    Dec 12th, 2011
    Seattle Washington
    03-01-2012 09:39 AM #6
    Yeah, I figure I'd try it out, since it's already in there, like you said at least cams are easy to replace. Wouldn't of been my choice of cam though. A close ratio tranny is on list. I guess I was just hoping the dual sidedrafts would help compensate for the big cam.
    Thanks for the info!!
  7. Member B4S's Avatar
    Apr 16th, 2003
    03-01-2012 02:04 PM #7
    Well, they'll certainly make it a bit more liveable than a stock plenum-based intake on CIS would, lol. Unless you go for some tiny chokes, your bottom end will be soft as all get out. That'll kill the top end though .
    Apr 27th, 2003
    oregon city, oregon
    79 dual carb rabbit ( the dark green one )
    03-01-2012 07:19 PM #8
    probably the most important thing i have learned in my time with sidedrafts is to use the smallest chokes that will give you full power. you can go larger but as mentioned above, you will have a very weak signal down low and the only way to compensate for it will be to run much richer ( accelerator pump jets and or pump bleeds, idle jets , main jets and even a different set of emulsion tubes possibly). having the proper choke that is not too big will make low speed running alot more manageable with the proper jetting . i would probably stick with no bigger than a 32 set of choke tubes for your 40 webers if you try that 298 cam. with a 1.8 or 2.0 liter, you would need larger chokes but yours being a 1.6, a 32 probably will get you to full power and , with proper jetting, make driving on the street somewhat livable
  9. Member VWaddict01's Avatar
    Dec 12th, 2011
    Seattle Washington
    03-01-2012 11:49 PM #9
    Wow, thanks. I didn't even think about using small chokes, I will go that route. A lot of things to consider and great information. A lot of shops in my area don't even deal with tuning carbs anymore(water-cooled), it's almost a lost art. It's great to have the knowledge on hand here on Vortex.
    Cheers!
  10. Junior Member
    Dec 31st, 2011
    turkey
    1978 golf mk1
    03-20-2012 11:30 AM #10
    dont use dual weber use cv bike carbs, they have variable ventury , you will have very smooth idle.ı am on a similar project , this is my way. 36 mm mikuni carbs.is your head 8v or 16v ? can you put some photos of port polishing job?
    think about the old bikes 1000 cc and 140+ hp with an idle no more than 1K .they are also using wild cams. use bike carbs and have smooth idle+more responsive engine. and they are far easier to tune than webers.i can get some where 500 rpm idle with them no vibration, standart cam, now i am swithing to 272 web cam. use a FM,fd,fk code tranny, can use a 4.25 final drive from mk4 golf.
  11. Member VWaddict01's Avatar
    Dec 12th, 2011
    Seattle Washington
    04-04-2012 02:42 AM #11
    Quote Originally Posted by dr770 View Post
    it's a 8v head. Which manifold would you use for the mikuni's? Or is it custom? But still either way I would be stuck with the 298 cam that might be too big. But looking into bike carbs might be cheaper, just getting the right manifold might be a pain. Is 36mm the biggest they made back then?
  12. Junior Member jetta86GLI's Avatar
    Apr 1st, 2012
    El Paso, TX/ Juarez, Mexico
    1986/VW/Jetta GLI ABA 16v - 1995/VW/Jetta GLX
    04-06-2012 04:09 AM #12
    I tried to put a 306 cam on a 1.6, the car wont start it was to many compression and i changed to the 286, and you will need to use racing fuel or your going to have a lot of pre ignition, the 4.25 final drive, you can found it in the AVX transmission the only have it in the caddy 1.6 Diesel these transmission is very slow so you can change the internal gears from a quicker transmission, like 9A, 4K, 2H, 4Y for the bike carbs the bigger are from the Yamaha R1 they are 40mm, and Honda CBR blackbird the are 42mm
  13. Member Urwrstntmare's Avatar
    Feb 21st, 2011
    The Rockies
    1996 WolfyJetta....soon to be for sale! 1992K1500 Blazer-Ole faithful
    04-21-2012 03:08 PM #13
    I'm runnin a 306 cam in a decked JH big valve head on an ABA bottom end, 3A dizzie and knock sensor. No prob at all!
  14. Member Urwrstntmare's Avatar
    Feb 21st, 2011
    The Rockies
    04-21-2012 03:11 PM #14
    Oh yeah runnin dual DCOE Weber 45's
  15. Member
    Jun 14th, 2001
    Music City USA
    04-22-2012 09:06 PM #15
    a 2 liter engine will tolerate bigger cams much better than a 1.6.
  16. Member Urwrstntmare's Avatar
    Feb 21st, 2011
    The Rockies
    04-23-2012 03:33 PM #16
    Yes it will, still have the back compression on start, and you have to run premium with octane booster at least.
  17. Junior Member jetta86GLI's Avatar
    Apr 1st, 2012
    04-25-2012 04:12 AM #17
    When I tried to put the 306 cam on my 1.6 engine I was using racing fuel (115 octanes), I checked the timing, the carburetor was running good I checked everything in the car, just wont start it was too much compression.
    Right now I have the project of the ABA engine with 16v cylinder head, I was thinking to put in a bigger intake cam but I found out the you can put an exhaust cam, instead of the stock intake cam, the exhaust cam is bigger so it will give great torque and hp, and I will be running some mikunis carbs, headers, cylinder head ported and polished, Saab distributor, MSD ignition box, etc
  18. Junior Member
    Dec 31st, 2011
    turkey
    1978 golf mk1
    04-26-2012 03:09 AM #18
    well i made the manifold myself , but i can not upload the pictures at the moment. i used a diesel manifold cut from the 5th cm from the head, with inside diameter 0f 30 mm(diesel manifold). then i used lathe and made 16cm conical tubes with one end 30 mm the other 36 mm inside diameter, all made of 5083 aluminyum. then welded together. But it is not that easy ı had to make 2 jigs when welding. if you give me your e mail adres i can send you the build pictures. all the job finished in 2 days , but the work was nice. İ have also made a resonance tuning 3rd harmonic at about 6300 rpm with a %8 boost. İ used a suzuki carry fuel pump with a custom hand made pressure regulator. at first crank the engine started with no broplem.İf you are dealing with 8v head my photos would help you so much i belive.36 mm is way enough for 1.6 lt, i dont think you need bigger ventury. most of 40 mm webers have 32 mm ventury. what is your inlet valve diameter? for the maximum drivable performance stay under valve size when chosing ventury.
