I had the transmission rebuilt by a shop when they installed the LSD. This has to be a transmission issue? Right?? When I say I put the trams in first! I turned the shifting weight towards the front of the car! Changing gears! I can hear the gears move in side the trans. But shouldn't it be engaged with the engine now???
Im really disapointed cuz this has been a long project and Im almost done, but its like the engine is not engaging with the transmission at all???? In gear it should have the compression of the engine to turn over also..... Its an AEB engine, O2J trans, 1.8t flywheel, VR6 clutch and pressure plate... Any ideas what is going on??? Thinking back on it,.... I dont know ... Please help or any suggestions on what this could be?? Thanks
Corrado
This lead me to think I have no ground
Well I painted the transmission and the starter before installing them and came to the conclusion that I have a Shi**y ground due to my awsome paint job.
Well I sanded off all the paint where the two touch and Wallaaaaa
So thats what my problem was I painted the starter and trans and had no ground for the starter. I want to thank everyone for there reponces and all the ideas and help..
