#211
#212
#213
#214
#215
#216
#218
BSH Speedshop | INSTACLAM #43f | 4/3 FILMS on FACEBOOK | BLUEWATER | IBOARDWALK VW (California)
2012 Golf .:R {DBMP-4DR}
#219
Are you going with stock fenders rolled or are you going to get the extended ones like TEFF?
#220
Sorry i haven't read my thread in a while. The new fender is a stock one but rolled completely flat and then painted.
I haven't updated in a while but i have done several things over the last few weeks.
Installed Scorpion Catted/Res TBE (Love it!)
Updated tune to APR Stg 2+
Installed Audi TT-S Engine Cover, Then removed it and sent it off for paint.
Installed Euro Cup Holder
Installed Forge FMIC
Installed new drivers fender
Installed OEM Dash Cubby
Installed KSport FSB Endlinks
Im really happy with my car right now. Stage 2+ is awesome it pulls much harder and longer then with just stage 1+. My engine cover should be back by next weekend, in time for Wekfest Texas!
#222
#223
#224
#225
A few pics from Wekfest Texas this past weekend.
#227
Every day I see the front of my car I see my Forge Twintercooler glaring at me through the bottom Grille. Yours looks damn fine as well. I'm really glad I ended up going with it.
GIAC Stage 2+ | GIAC DSG Tune | Forge Twintake | 3" SPM Downpipe | Revised Diverter Valve | Autotech Fuel Pump| BFI Mount | Eurojet FMIC | R8 Coilpacks | Valeo LED Tails | Whiteline 24mm RSB | BSH PCV Revamp | Whiteline Anti-Lift Kit | K-Mac Custom Springs | OSIR O-Pod Mono GT, NewSouthPerformance Indigo Boost Gauge, OSIR Carbon Headlight Surrounds - Coming Soon!
#228
#229
#230
#231
BAGGED CW GOLF R APR STAGE 2+, APR HPFP, SCORPION TBE, FORGE TWINTAKE, FORGE TWINTERCOOLER, FORGE DV, custom engine cover, Image Billet 102 , OEM LED TAILS, + http://forums.vwvortex.com/showthrea...life42-R-build
#232
What are those wheels?
#233
#234
Well another 12/11 build date car with clutch issues... just over 6k miles. Came out of a parking lot on friday and got on it pretty heavily. Shifted to second no problem. Tried to shift to 3rd and no dice at high rpm. Now shifting to 1st 3rd and 5th even at low rpm is very gummy and difficult to engage. I have felt it slip a few times at high rpm in 4/5th but no issues like others have had until this. Will take it to the dealer next time i have a free day.
#235
Ew. I think my build date is 12/11 or 11/11.
2012 CSG 2 DR NAV/SR | Tuning: 4 Seasons | Paint: Dave the Painter | APR STG 2+ (w/program switching) | STG 3ish Clutch | HPA Gen 4 Switchable Stock/Race/Eco Controller | Autotech HPFP | Billy Boat Down Pipe | Volant Golf R intake | Neuspeed short shifter | Neuspeed Torque Arm Insert | Badge-less grill + notch fill/paint | Some rad stickers | Gloss Black Stock Wheels | VWR Sport Springs | ESC hack | ("Build" Thread) | #731 ( :
#236
Over the last few weeks I have been to the dealer several times. The problem with my shifting turned out to be due to the shift cable getting kinked. The technician said it was caused by the downpipe smashing the cable against the frame. The issues has worked it self out by either the cable straightening back out or bending the surrounding casing to accommodate the newly reshapened cable. At the same trip to the dealership I had them look at my kessy issue I have been having since April.
They said the same thing as the first dealership I took the car to. That they couldn't communicate with the kessy module to reprogram it. Nor could they reset the ecu to stock to eliminate that as the cause. As apr's chips can only be removed by an apr distributor. So I was forced to get the ecu put back to stock. Then they started blaming the wiring i had done to the cecm. Which is all oem led taillights wiring. The dealership was very quick to blame mods for everything so I will no longer be going there for service. I returned to the first dealership and was fortunate to get the best technician they have and was even able to talk to him in great depth. Discribed the issues I have been having and he took a more unbiased look into the issue and replaced the kessy module. Problem solved...
So nice to have kessy back. I have an appointment today to get the chip reinstalled. After being stage II+ and going back to stock is miserable... 5th and 6th is damn near useless aside from cruising.
#237
glad to hear that you got the issue fixed. sucks that the dealer was such a scumbag. Make friends with that tech and only go to him. He will let alot slide if you get on good terms and he likes your car
#238
Glad you got it sorted.
Out of curiosty which were the two dealers you went to?
#239
Demontrond was the first dealership i went to and they told me the chip was causing communications issues. I took the car to Clearlake and they told me the same thing. I called APR and they confirmed that the chip would have no detrimental effect on the kessy module. Just wanting to alleviate the extra headache i had Pete at ELM remove the chip and took the car back to demontrond as it is the dealership closest to my house in The Woodlands.
When i arrived the guy at the front recognized me from Wekfest Texas and helped me out. They didnt have any availability all day and he went back and talked to the Tech and told me to come back in the afternoon and the tech would make time for me. When i went back the guy let me go back and talk to the technician myself and discribe the issues and what troubleshooting steps i had gone through previously. He told me that the Kessy system is on a completely different canbus system and that the chip would have nothing to do with the issue (Just as i thought).
On a lighter note i wont Best MKVI and Best in Show at a local Euro show this weekend Dubsicles. Didnt get any good pics of my car though
The trophy and plaque i won on the right and the trophy i won at the CLVW show back in april for best of show. The plaque on that is the trophy i won for 1st place best VW at wekfest in Austin.
#240
#241
#242
Nice mods!Not a fan of the dumped look, but that's the craze right now. lol. You gonna upgrade turbo in the future or staying stock turbo?
12' CW 4Dr Loaded Golf R
Mod List: CTS FMIC, CTS Intake, APR Catted Downpipe, APR High Pressure Fuel Pump, APR Stage 2+ Tune, Michelin Pilot Super Sport 225/40/18
Golf R addiction: I work for incremental PSI and the more I work the faster I go!!
#243
Haven't really decided tbh. I'm happy with stage II+ at the moment. Ill see how big tax returns are and then decide what I'm going to do then. Few more mods to come between now and then though. W/M kit is in my garage waiting for me to get around to installing it. Still debating weather to install it and upgrade to the apr 100oct file or go with maestro7 for a tune more custom suited to the mods I have, vs the box tune. Not being able to switch back to 93oct or even stock if something were to go wrong concerns me. With maestro I believe I should be able to flash back to the stock file or custom 93 file at home. Maestro dyno tune will run me an additional 1k thou. /shrug we shall see after the holidays.
#244
Car looks great. Do you notice that the paint on the fender doesn't match?
#245
