Results 1 to 9 of 9
Thread: A8 19" turbines on c5 a6?
  1. 03-01-2012 10:48 PM #1
    Need to know what tire size I should run and what size spacers I would need.? 2000 quattro, summer is coming time to get the ball rolling. Also if anyone has pics of the same setup please post them. Thanks in advance.
  2. Moderator Mr. Rictus's Avatar
    Sep 24th, 2004
    Buchanan, NY
    2003 Silverstone Grey 2.9L 24v twin turbo VR6, 2002 S6 Avant
    03-02-2012 01:40 PM #2
    Offset and width of said wheels?
    Driversport|| Valley Dubs PM me for all your Fragola Fittings and Billy Boat Exhaust Needs!!!
    The Elite 24v VR6 Club: Member #4
    My Build Thread
  3. 03-07-2012 07:50 AM #3
    19x8.5 et45
  4. Moderator Mr. Rictus's Avatar
    Sep 24th, 2004
    Buchanan, NY
    03-07-2012 08:47 AM #4
    Regular tire size: 255/30 19
    If you're low or want stretch: 245/30 19 or 235/30 19
    Depending on how low you are, you could run a 20mm or larger spacer.
    If you've got a friend with some spacers lying around try test-fitting the wheel with the various sizes to see how it will look.
    My Build Thread
  5. Member MikkiJayne's Avatar
    Jan 1st, 2007
    UK
    A6 TDI Quattro wagon, A4 V8 Quattro racecar
    03-07-2012 03:11 PM #5
    You're definitely going to need spacers to clear the front suspension uprights with that offset. If its a narrow-body car then 20mm will be too big, but 10mm will probably work
    Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
  6. 03-07-2012 08:47 PM #6
    I figured 10mm spacers since I don't have a wide body c5, I believe my 18s were et35 with 225/40/18. As far as tires I thought they would be 235/35/19? Correct me if I'm wrong. Thanks againg for the help.
  7. 03-13-2012 10:25 PM #7
    am currently running 235/35 19 with 10mm on the rear and 5mm on the front ,the spacers only are requied if you have the 2.7 package or the bigger brakes .... lowered on st's ..
  8. 03-20-2012 12:36 PM #8
    Are you running the same wheels?
  9. 03-25-2012 12:04 AM #9
    yes i am
