Results 1 to 4 of 4
Thread: 11.1:1 16vT ?
  1. Member REPOMAN's Avatar
    May 3rd, 2001
    Portland OR
    1990 VW Corrado
    03-02-2012 10:48 AM #1
    Since i am building a new block I have a line on a set of JE 11:1.1 comp ratio pistons in 83.5mm
    I am looking for advice on what the issues to avoid are and if i can go this route?
    I have a 15lbs spring in my wastegate so a minium of 15psi and i can tune for anything.
    I assume if i run c16 only i might be able to pull this off.
    any advice whould be great.
    Thanks
    500HP 1990 Cowrado
  2. Member turbodub's Avatar
    Jul 6th, 2000
    garden state
    94 golf
    03-02-2012 12:33 PM #2
    Quote Originally Posted by REPOMAN View Post
    Thanks
    tune accordingly, my old 16v had a comp ratio around that. used to run pretty much at least 40psi on e85
  3. Member REPOMAN's Avatar
    May 3rd, 2001
    Portland OR
    1990 VW Corrado
    03-02-2012 07:45 PM #3
    Yeah i am looking at the Ethonal switch if i go this route.
    So how did you manage to break #3 wristpin?
    I assume i will tune to a lower PSI. I am not looking to make 700whp... My corrado is to
    heavy and my transaxle is to weak.
    Can Kevin Hook me up with an Ignition curve to start with?
    500HP 1990 Cowrado
  4. Member turbodub's Avatar
    Jul 6th, 2000
    garden state
    94 golf
    03-02-2012 08:55 PM #4
    not sure what happened with the wristpin. the clip may have came out. not sure. email kevin and ask. lugtronic@gmail.com. i also used to run c16 with the high comp pistons back in the day.
