Results 1 to 13 of 13
Thread: nitrous question
  1. 03-02-2012 11:05 AM #1
    hoping maybe i could get some insight from you people running nitrous. i'm running a 75 wet shot on my vr6.. starting with a 35 for testing purposes to make sure everything is working properly. anyway its almost done and ready to be used. had a quick question tho. how many of you go back to the stock chip? i have an aftermarket one in right now and im aware nitrous+advanced timing does not mix too well. but its a smaller shot so i was thinking i might be okay with leaving it in...either way its not a big deal to swap in the stock one any info would be appreciated pic of the car for clicks
  2. Member XXX008XXX's Avatar
    Mar 25th, 2002
    2000 GTI 1.8t, 72 Standard Beetle, 95 Eagle Talon TSI Auto, 2002 Chevy Tahoe
    03-03-2012 12:19 PM #2
    i would run the performance chip with a different spark plug IE: hotter or colder. gotta read them (search pictures on line) and see what works best for your setup
    10.30@145 .68 35R
    10.08@141 / 148
    Force Fed Engineering
    Lugtronic
    Boost Factory
  3. Member turbo mike's Avatar
    Dec 7th, 2005
    Wharton, NJ
    97 Turbo GLX
    03-03-2012 02:50 PM #3
    get a bottle heater. doesnt look like you have one, and its one of the most important parts of your nitrous system.
    Mike
    supercharged glx - 12.0 @ 113mph (12psi)
    turbocharged glx - 12.7 @ 108mph (7psi), 11's coming soon
    S362 .88 a/r
  4. 03-10-2012 11:12 AM #4
    Quote Originally Posted by XXX008XXX View Post
    will be running a colder plug.. do you have any personal experience with running nitrous and an aftermarket chip?
  5. Member lil8v's Avatar
    Jun 28th, 2002
    Jersey
    03 20th ann..retired 97 gti that was a lil bit of everything
    03-10-2012 08:08 PM #5
    bottle warmer...and a window switch so you only spray it during certain rpm increments...i used to go thru two 10lb bottles a night on my vr6 this was with a 100 shot...use the chip id splash some 100 octane in for the just incase scenario
    2003 mk4 20th anniversary 10.60 at 140...full weight
    for all your vw fabrication and custom parts hit up
    ED at FFE racing he is the best in the business
    me-551 208 8850
  6. 03-11-2012 12:12 PM #6
    Quote Originally Posted by lil8v View Post
    howd you like the 100 shot? i do have access to some 100 octance also im using a progressive controller so the spray will be controlled throughout the different rpm ranges
  7. Member lil8v's Avatar
    Jun 28th, 2002
    Jersey
    03-12-2012 02:03 PM #7
    loved it car went 12.1 at 119 on a 225 bf drag radial on the second pass ever.....
    me-551 208 8850
  8. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    03-13-2012 05:06 PM #8
    Quote Originally Posted by CruZnVduBvr6 View Post
    All the time but only on a little (door) shot.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  9. 03-13-2012 05:13 PM #9
    I wish someone did a nice progressive setup.
    Racing Improves the breed..
    "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
    CrossroadsLI
    MY ALL MOTOR BUILD THREAD
  10. Member gtizzle67's Avatar
    Mar 9th, 2008
    union,nj/slippery rock,pa
    all motor vr6, 85 mustang
    03-14-2012 01:10 AM #10
    Quote Originally Posted by fourthchirpin View Post
    dont worry, thats coming soon
    Lugtronic.com, Force Fed Engineering, Boost Factory, Caste Systems Performance
    all motor vr6
    "Hell I am proud to be a member of the All-motor/Jersey A-hole/whatever CLIQUE." - vw1320
  11. Member forcefedjetta's Avatar
    Aug 14th, 2003
    metrowest
    02 jetta 1.8t
    03-17-2012 08:20 PM #11
    Check out dyno tune they make great kits and controllers @ good prices just installed one on a customers volvo wagon
    i wish my grass was emo so it would cut it's self
  12. 03-18-2012 11:30 AM #12
    Quote Originally Posted by forcefedjetta View Post
    true dat
  13. 03-23-2012 04:06 PM #13
    I ran 125 shot on a stock VR with a chip and C16 never had any issues oh and a colder plug.
    JFFFJF If you don't know don't ask
